Old 03-11-2017, 01:31 AM   #1
81 MexCella's Avatar
Kelseyville , California
Isuzu Turbo Diesel 350 I.D. & Parts
Thank you Smartstream for turning me on to Hamilton Engine Sales in Portland Oregon (503) 280-1353. I spoke to Chad who was very knowledgeable and very straight forward when he said "I can't get you anything for your Motorhome but can get you everything for your engine."
Before you call identify your engine by finding out the Model and Serial No.
The model can be found on both the ID tag and serial stamp. See picture of tag below. Mine is a Model: 6BD1
The serial number is located on the left front lower part of cylinder block. You will have to get under with a flashlight and possibly some brake cleaner or sand paper to clean off the area. See pictures below. My serial stamp reads Model - Six Digit Serial: 512557
Once you get Chad this I go it's smooth sailing.
ID:	281175   Click image for larger version
"Electra"
1981 Airstream Excella 28' Turbo Diesel
Northern California
81 MexCella is offline   Reply With Quote
Old 03-11-2017, 05:35 AM   #2
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
This would be a great thread to start posting bits and pieces that people buy for the Isuzu, along with part numbers, location and prices.
Yes, you have a 6BD1A, not a 6BD1T as your turbo was an aftermarket BAE system with a Rajay turbo I do believe. After 1984 AS used the 6BD1T with its beefed up internal parts but with the same aftermarket turbo system for packaging purposes (lower dog house).
As for a replacement turbo I know that one of the housings has to be turned to match and John has clearance issues with his replacement. I'm sure John(Shepherd57) will have the manufacturer and part number of the turbo he used.
Cheers
Tony
Old 03-11-2017, 06:50 AM   #3
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Oh wow! I didn't realize John had replaced his Turbo
mayco is offline   Reply With Quote
Old 03-11-2017, 07:54 AM   #4
Cheers
Tony
You're right Tony, it looks like it is a Rajay Turbo system. I'm replacing the water pump and learned that the 6BD1 models were built with 3 different water pumps depending on the serial no. I'll place pictures and parts numbers once they come in, great idea!
Erny
ID:	281194   Click image for larger version
"Electra"
Northern California
Old 03-11-2017, 11:44 AM   #5
Dazed and Confused
Isuzusweet's Avatar
Yup! John took off his K&N filter and found NO filter material left; nada, zip; which explained all the very fine sand he found in the intake tract from the turbo to the engine; so he took a look at the compressor part of the turbo and sent me a picture of a turbo compressor fan blade that had been sand blasted down to a point that the fins of the turbo were just nubs. New turbo installed and voila! he has power.
Tough beatch of a motor that it's still running after injesting sand for a while. (PO drove in Arizona and New Mexico quite a bit). However everyone needs to inspect filter regulary.
I'll let him know to post pictures, part numbers and experience.
His motor is not original so it maybe a T model.
Cheers
Tony
Old 03-12-2017, 11:23 PM   #6
Does anyone have an online go to vendor for engine belts and hoses (radiator, water pump etc.)? I'm striking out on my web searches and I even have part numbers for the belts....
ID:	281360   Click image for larger version
"Electra"
Northern California
Old 03-13-2017, 01:35 AM   #7
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
The alternator belts are Isuzu #1136711430 or SPB 1220 metric v belt (17x1220mm) the A/C is a standard auto v belt but I don't have the number handy.
I don't have the hose numbers handy but some of my hoses still have the labels on them, I'll see if I can get them in the next couple of days.
Cheers, Dan
~ Margaret Thatcher ~
Old 03-13-2017, 04:30 AM   #8
mayco's Avatar
I buy mine online from V-belt supply. SPB 1280 I believe. Had good luck with these guys.
Double check your belt length, the 1280 is the length in mm. They are metric belts, about $9 a belt.
The SPB designation is the proper width and depth.
http://www.vbeltsupply.com/
Old 03-13-2017, 10:16 AM   #9
Thanks Guys! I'll try those numbers, I found the maintenance sheet below in my "bag" of paperwork which I have since then sorted out into 3 different folders with original manuals from the satellite antenna to the built in food processor if anyone is looking for those. Hopefully you can read the item lists on my folders.
The maintenance numbers on that sheet seem to be old enough to be hiding under 36 years of replacement numbers, so they are challenging to find online.
-Erny
ID:	281393   Click image for larger version
"Electra"
Northern California
Old 03-13-2017, 11:55 AM   #10
mayco's Avatar
-Erny
That is AWESOME! My rig came to me through a family members estate with nearly -0- records or paperwork.
Old 07-08-2019, 05:12 PM   #11
Vero Beach , Florida (FL)
Hello I have a 1983 Isuzu 6BDi4 with a talk like structure above exhaust I don't know what it is. any help ? Thank you, dennis Vero Beach Fl.
SmoothNeil is offline   Reply With Quote
Old 07-08-2019, 05:17 PM   #12
hey there
Old 07-08-2019, 06:20 PM   #13
Dazed and Confused
Isuzusweet's Avatar
Please repost with better information. Check your spell check or auto correct before hitting send, as we're not sure what a talk like structure is.
Post pics?
Cheers
Sidekick Tony
Isuzu Turbo Diesel Fred Airstream Motorhome Forums 15 11-05-2018 05:19 PM
1982 turbo diesel 310 :: 2013 Airstream turbo diesel 310 mayco Airstream Registry Discussions 1 07-28-2015 11:58 AM
1982 28' Isuzu Turbo Diesel mcplaidpiper Classic Motorhomes 9 02-05-2009 08:29 AM
Isuzu Turbo Diesel Q&A's stuart2 General Motorhome Topics 0 04-03-2004 11:20 AM
Isuzu Turbo Diesel stuart1 Mechanics Corner - Engines, Transmission & More... 0 10-28-2002 01:23 PM
