Re: 6BDI or 6BGC1-T engines. Please give you likes and dislikes. How is the power on these engines. I was told a C6 Ford automatic wouldn't have enough gears to do the job. How do they do with the TH-400. What vehicles had a C6 with this engine. thanks.
Re: 6BDI or 6BGC1-T engines. Please give you likes and dislikes.....
You did not state what the intended use of the engine was, but since you're here in the Forum I assume the question relates to an Airstream MoHo.
I looked very hard at all options for re-motoring my 345 a couple of years ago -
The Isuzu 6BG series engines (396 cubic inches) seem to weigh in at about 1080 lbs (some more, some less), the Chevy "Big Block" engines (454 cubic inches +) weigh about 680 lbs - again, some more (or less) than others.
Generally speaking, you are looking at a 400 lb weight penalty to go with the Isuzu unit.
I quickly discounted a diesel re-engine option on my unit due to the fact that the 345 was very close to being overweight on the front axle when it left the factory - you may want to get some actual weights on your particular vehicle situation prior to investing any money.
Just a thought.
Dennis
Not knocking the Isuzu as it is quite reliable, but the cost of maintenance would outweigh the savings on gas if any. The only thing you might gain is longevity as compared with the 454, but then again the Chevy will do lots of mileage with the right maintenance, and a little bit of luck.
Rallys twice a year..Lots of fun, food, and aluminum.
Okay. We have a 345 with the Isuzu Diesel. I have no idea what ALANSD means by maintainence costs. It does take more oil to change oil yes, but I only need change it every 10,000 miles so the cost per mile vs gas engines for oil is a lot less. There are no spark plugs to change, or points or condensers or ect.
There is no other maintainence unless something breaks, and the engine is very reliable. I have rebuilt the alternator, but that has nothing to do with the engine.
As far as power goes, I have been at red lights beside gas powered units and on the green accelerated normally and was surprised that I walked away from them. I tow a full sized car,(have for years), and usually can't tell the car is there except for the rear view tv.
Our transmission is an Allison 4-sp. It handles the engine very well.
As far aw weight goes, all the tanks are in the rear along with the bed room and storage. What additional weight would you load on the front axle anyway.
We love our unit and think the engine is great. I get on good days 16mpg. If I tow it drops to 10-12 mpg.
Our engine is a 6bd4 with the improved crank and pistons that were introduced in 1985. It also has a factory installed turbo-charger.
I would answer any other questions you might have.
AKA THE GUNNER There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
I have a new Isuzu 6bdti engine. Manufactured in 2003 and installed in 2004. We have put on a little over 20,000 miles on this new engine and have found it to be more than satisfactory. There is adequate power for our 28' motor home, excellent acceleration, and the engine is very quiet. The required maintenance is an oil change at 10,000 miles! So even though that costs me $100.00 the maintenance cost is better than a gasser that requires tune ups and more frequent oil changes. I average 15MPG regardless of road conditions or what I am carrying or towing. I had a block heater installed and so far have had no problems starting the engine in the wintertime. As of now I have yet to use the glow plugs or had a need to use them for starting.
I would be happy to answer any other questions you have pertaining to this engine.
Did you replace a diesel engine or gas engine and what transmission are you using. I am curious what the changes are from the 6bd4 to the 6bdti? I am also curious what the engine cost although that may be too personal.
Thanks for all the info and input. I am researching the idea of installing one in my Ford Bronco. The weight seems to be the only drawback so far other than bellhousing /transmission issues. Thoughts?
The engine was replaced due to a mechanic using a wrong oil filter on the original engine. The insurance co. paid the bill. The cost was almost $20,000. I believe the only difference in the 6bd4 and the 6bdti is the numbering. T stands for turbo or factory installed. The transmission is the same as what AS put in and I am not certain what it is. I know there are significant technical changes between the two engines and I should have paid more attention when the mechanic excitedly explained them to me. What I have experienced is the quietness, acceleration, winter starting, lack of diesel odor. I know I am experiencing more wonderful things that I do not realize but that is what engines are supposed to do, operate quietly and make no noise.
In most diesel nomenclature, the "T" stands for Turbo, and the "I" stands for Intercooled. This is a kind of "air radiator" that cools the air before it enters the engine. An engine can hold more cool air than hot air, because, of course, cool air takes up less space. Your new engine may or may not have an intercooler, as it was a replacement. An intercooler looks like a radiator in the air intake hose.
Terry Change is inevitable, except from a vending machine
AIR#2611
I ran mine in a F250 4wd with dana 44 front axle and Clark 285 trans. It held up quite well but had a tremendous appetite for universal joints.My current plan is to run it in my 3/4 ton Club Wagon with an auto trans which should relieve some strain on them,but will still upgrade to larger yokes.I'm sure that I will also need air bags in the front coils.Tom
Jim, with a fully loaded service body I weighed in at 7800 pounds. 4:11 gearing gave me a top speed of about 72 MPH ang 19 MPG all year long regardless of what was hooked to it! Tom
