Engine performance...Diesel
All devices are not created equal. This is very true for the mechanical world. Nearly no two cars, trucks, or motor hames will operate exactly the same under the same conditions. In many cases the power, economy and longivity are determined by checking for the optimum adjustments and tweaking to get everything just right. Most engines run so well that the ultimate tune condition or performance equiptment is included. There are many areas to check. In diesels, the requirements are the same as gas with no spark to consider. Diesel engine performance can be improved with unobstructed intake and exhaust, turbo and larger turbo, increase injection pump fuel delivery and advance pump timing. All performance modifications MUST be monitored. Power is HEAT which must be observed. A pyrometer is a must with a trans temp gage. Removing any exhaust restrictions, and increasing pipe size, is the cheapest instant power increase. As power increases, the heat increases as well. The trans should also have some attention with a shift kit, trans program, increase oil pan capacity, in line exterior oil filter, oil cooler relocation and maybe fan forced cooling. Many performance oriented folks used only all synthetic auto trans fluid. The torque of a diesel engine can be very very high. It may take some relearning. A single 3 inch exhaust will flow more volumn than dual 2 inch exhaust. All 5 inch exhaust with no muffler or cat turned down before rear axle is the best flow for diesel performance, power and economy. When there is lots of power all the throttle is not needed???. Frank Idaho
Visit Idaho The people are great
