Old 10-31-2013, 08:51 PM   #1
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Is my turbo working?
ok, this may be another stupid question to some but here goes. since ive never owned a turbo charged vehicle before, my isuzu turbo engine is all new to me. my question is, without having a point of reference, how do i know if my turbo is functioning properly or at all. i was bound and determined to get our maiden voyage in this fall and indeed a couple weeks ago we ventured about 100 miles to raccoon lake SRA in central indiana. we had an absolute blast and the 310 ran very well i must say. ive been working my way through her like so many others and i was pleased. i didnt keep track of our miles per gallon. she did seem to have a little problem with the inclines in the central indiana area which i consider to be rather mild. i never had to down shift but if i didnt get a running start at a long incline she would slow down a bit and seemed to have a bit of trouble maintaining a consistant speed. since i really dont know what the performance should be im just wondering if my turbo is functioning properly. is there a way for me to tell or do i just need a qualified mechanic to look at it. on relatively flat interstate i was running at about 2850 rpm at 60 mph. any thoughts folks.
mayco is offline   Reply With Quote
Old 10-31-2013, 09:23 PM   #2
1985 34.5' Airstream 345
Centennial , Colorado
You should have a boost meter on the dash. It should indicate an increase in pressure as the turbo kicks in.
Heirstream is offline   Reply With Quote
Old 10-31-2013, 09:34 PM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, your turbo should also make a high pitched whine noise; This doesn't mean that it is working correctly.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 10-31-2013, 11:22 PM   #4
1974 Argosy 20
Kooskia , Idaho
If your rig does not have them, both a boost and an exhaust temperature meter are very helpful. The exhaust temp is quite critical on a diesel, especially a turbo one. A friend had a diesel 280 and the exhaust temp would go up to dangerous temps on any grade. He finally found that some PO idiot had put the mufflers on backwards. After that he could run rings around me in my 454 equipped 310. He could hill climb fantastically well. Now, the brakes on his 280 were terrible and mine were much better so he went uphill fast and downhill slow, I went slow up, but never had any stopping issues so could come down faster than he did.
Old 11-01-2013, 03:17 AM   #5
mayco's Avatar
thanks folks. now does the boost gauge work off a vacuum line? i was up under the dash the other day replacing the heater control cable and found what appeared to be a vacuum line just hanging free. i didnt know where it should be connected and its still hanging there. could this be the line going to the boost gauge? is there any other vacuum powered gauge or control up under the dash?
Old 11-01-2013, 04:57 AM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
When the turbo spins-up the manifold vacuum becomes pressure.
The gauge indicates both and is connected to the intake plenum.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 11-01-2013, 08:47 AM   #7
1974 Argosy 20
Kooskia , Idaho
All of the heater and dash air conditioning controls are vacuum operated. The lines are all under the dash.
Old 11-01-2013, 02:15 PM   #8
mayco's Avatar
its sure a mess under that dash
Old 11-01-2013, 02:18 PM   #9
mayco's Avatar
im not getting a reading on either of the turbo gauges so i got to trace down whats up. so, there should be a vacuum line to the pressure gauge?
Old 11-01-2013, 03:12 PM   #10
1995 36' Classic 36
Ludington , Michigan
Can't speak specifically of the Isuzu but the Cummins doesn't supply vacuum for the heater. There is a separate electric vacuum pump for that. You should see at least a few pounds of boost under load. If not I would expect a gauge problem or turbo problem.
Kota is offline   Reply With Quote
Old 11-01-2013, 03:50 PM   #11
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
When you open the doghouse you will see a cast aluminum tube going from left to right across the top of the engine. It's 3" to 4" in diameter. Right in the center on top of the tube is a small elbow fitting with about a 1/16" I.D. rubber tube, it looks like a vacuum tube. That is the tube that goes to your boost gauge. If you remove the tube and rev up the engine you will feel the turbo pressure. The original BAE turbo was a low pressure aftermarket add on turbo and will provide a maximum boost of about 10 psi.
The Isuzu has a vacuum pump on the rear of the alternator. The original step is vacuum operated as well as the cruise control. Some years have vacuum operated A/C and heater controls, some do not. My 1982 has no vacuum to the A/C and heater control.
Cheers, Dan
~ Margaret Thatcher ~
Smartstream is online now   Reply With Quote
Old 11-01-2013, 06:07 PM   #12
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
[QUOTE=mayco;1374281 i was running at about 2850 rpm at 60 mph. any thoughts folks.[/QUOTE]
Unless you're smoking, your Turbo/Isuzu should be close to it's factory specs .Around 3200 rpm is max from GM specs with the turbo.If you're going to keep the the old dear, think about a overdrive unit, we have one.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 11-02-2013, 07:27 AM   #13
mayco's Avatar
as always folks, thanks so much for all the valuable info. im going to check into the overdrive units but its gonna have to wait till the budget allows. thanks for all the good info on the turbo, ive been reading quite a bit on how the unit works and i think ive got a better understanding on whats going on. sure appreciate all you folks for your experience and willingness to share. good on ya!!
Old 11-20-2013, 07:59 PM   #14
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
When I bought my 310 TD the turbo boost gauge didn't work. Not hearing any turbo noise/whine I thought there was a possibility that my turbo didn't work. I talked to a diesel friend who told me that if the coach is accelerating fairly well and not spewing black smoke everywhere, the turbo works. It turned out that the vacuum line was disconected from the intake plenum.
If your turbo doesn't work it's like stuffing a sock into the intake. Without sufficient air intake the diesel fuel doesn't burn completely and is ejected from the cylinder in the form of black smoke. Without complete burn the engine doesn't make peak horsepower.
Of note…….Shepherd57 found his turbo sandblasted to a point that the intake fins were worn down and the turbo wasn't pushing air as efficiently. Make sure your air filter is clean using a filter cleaner or soap and water and re oil the pleat material (there should be no holes in the pleat material). It is critical that the filter is good especially in dusty conditions.
Humphrey gas light not working properly bmklawt LP Gas, Piping, Tanks & Regulators 6 12-05-2011 09:58 AM
'64 Dometic Fridge working fine...a relief! PA BAMBI II Refrigerators 0 11-10-2011 06:13 PM
RM2500 just stopped working TouringDan Refrigerators 6 09-25-2011 10:44 PM
Electric working with battery not with 110 TX_DB Electrical - Systems, Generators, Batteries & Solar 11 04-24-2011 07:19 PM
License plate light not working worksology Lights - Interior & Exterior 7 04-08-2011 05:05 AM
