Old 09-22-2005, 09:27 AM   #15
Nye Thatcher's Avatar
I have experienced an intermittent problem as you described. It turned out to be frozen caliper slides. The calipers are made in two parts. One part moves on the slide when the brakes are applied. If they are beginning to freeze. the seals on the pistons are unable to fully retract causing a heat build up. IF this is it, it is easy to fix with a wire brush and a good penetrating oil, with the wheels removed. (wheels may turn freely when cold). Good luck, nye
Nye
Nye Thatcher is offline   Reply With Quote
Old 09-24-2005, 08:03 AM   #16
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
I picked Chummy up from the shop and they reported that everything checked out fine. The mechanic can find no reason for the vibration and since it is intermittment, it does not happen on a road test. I listed all the suggestions given and he stated that they checked them all plus more, including wheel balance, a bent rim, loose wheel, engine mounts, and on. This may be one of those things that has to get worse before it gets better.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 09-24-2005, 08:22 AM   #17
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
chaplin
one other area of remote possibility would be the steering gear box.
we had a batch of chevys at the power company that would develop cracks in the frame where the steering box mounted.
the steering box would flex at the mounting bolts and cause vibrations and shimmy in the steering.
just a stab in the dark at your problem. could be worth a look.
john
you call them ferrets, i call them weasels.
Old 09-29-2005, 05:54 AM   #18
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
I'm going to persue my own chassis vibration and figure to start with the least expensive item on the list. My tire man took a ride with me yesterday and declared it not to be a tire related vib.
I'll have the U joints changed in the next couple of weeks and also look at the drive shaft brake at the same time.
The vib comes on at about 45mph and is gone at 55. Seems to jump up more on deceleration but that could be my imagination. The vibration is not enough to really shake anything but I can feel it.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 09-29-2005, 04:44 PM   #19
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
45-55 vibration is usually a bent wheel. 55-65 is usually tire balance, and a seperated belt in a tire will normally show between 15-25 mph.
Old 10-02-2005, 03:19 PM   #20
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Glen,
Check the bolt holding the trans yoke in. You can see it once you remove the driveshaft brake. (Be sure you block the chassis well before disconnecting the driveshaft). I have this same vibration and it goes away when I periodocilly tighten this bolt.
I'm considering replacing the yoke and trans tailshaft for a more permanent fix.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 10-04-2005, 02:19 PM   #21
1994 30' Excella
I just returned from a short 80 mile trip all highway and had no vibration. The only thing which was different than before was that my black water tank was empty. I usually drive with it empty but for yucky reasons I rather not get into here I let it fill up so it could get good and digested and cleaned out; which it did. This trip it was empty again. Could this possibly have been the source of my vibration? Have I opened up a can of worms for responses?
Chaplain Kent
Old 10-04-2005, 02:31 PM   #22
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Fill 'er up!
Well if that's the problem, you could easily confirm it by filling your black tank again (with plain old water) and taking Chummy out for a spin. If the vibe comes back you'll know - dump'er before you drive her!
Tin Lizzie
Old 10-04-2005, 03:32 PM   #23
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
can of worms, eh? I don't want to go there. But on the tank subject- I would wonder if the mounts are secure...If you do as stated above it shoudl tell the tale. Unless water weighs less...than well you know....
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 10-05-2005, 06:00 PM   #24
GlenCoombe's Avatar
Belleview , Florida
Images: 27
Swebster, thanks for the heads up on the tranny bolt. Makes a lot of sense to me. So when we take down the drive shaft we can also take a look at the tranny yoke.... the week after next.
Old 10-05-2005, 07:54 PM   #25
Well Preserved
1993 21' Sovereign
Alan, You went there first...
If it is a problem with the black tank having contents in it, why not fill it 2/3 or 3/4 of the way, and drive around with it sloshing.
And since you went there, remember what you see floating in the tank...if it floats, it is lighter than water...
Old 10-21-2005, 06:20 AM   #26
GlenCoombe's Avatar
Belleview , Florida
Images: 27
Well, you guys where right again.... or at least one of you was!
Got the bus back from the shop yesterday and the driveline parking brake/transmission yoke.... was the culpret. Everything is now tight!
Now it's on to the carb redo.
Thanks for all the insight.
Old 10-29-2005, 04:58 PM   #27
Well Preserved
1993 21' Sovereign
Glad we could help. Let us know next time you would like to go crawling around under your coach, dismantling things to see if they are broken, we can send you places you never knew existed!
Old 10-29-2005, 08:29 PM   #28
GlenCoombe's Avatar
Belleview , Florida
Images: 27
Terry, I was under the bus...again today. I'm going to sling my ladder under the tail end. I saw this done last week when I stopped at a rest area. I don't want to put it in the back on my new floor, it'd be in the way and might scratch my new floor covering. I was also looking to see how much room I had and where I could hang the PVC pipe for the sewer hose storage. Going to pick that up next week at Camping World.
MH on a Toyota chassis? ViewRVs Airstream Motorhome Forums 11 07-13-2003 01:03 PM
New P-3X series Workhorse Chassis evan Airstream Motorhome Forums 6 04-19-2003 08:00 PM
Argosy 20ft MH Chassis / frame JerryT94 General Motorhome Topics 5 04-14-2003 10:33 AM
chassis paint john hd Off Topic Forum 2 10-30-2002 03:36 PM
Re-attaching cabinets to the interior skin. Andy R Cabinets, Counter Tops & Furnishings 5 04-07-2002 02:54 PM
