Old 06-03-2002, 07:44 AM   #1
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Instrumentation/Dashboard redo
I have decided to bite the bullet and replace the 1976 P30 intrument cluster on my Argosy. I know I can get a new pre-made one from a company that does Winnebago remodels for around $1000.00. I am unwilling to spend that kind of money. I want to monitor all vitals but need some help and advice.
Are electronic temp gauges accurate enough or should I go with a bulb type that has a copper tube connected directly to the back of the gauge?
Is an amp meter a good idea? it seems to be alot of work to wire the Alt. thru the amp meter to get accurate readings.
I also want to monitor the trans temp, does anyone know where I can install a sending unit without having to pull the pan and drill a hole?
Lastly, I am trying to find an aftermarket speedometer that will accept the cable from my current speedometer, any suggestions?
Any reccomendations on additional systems I should monitor? I plan on Engine Temp, Trans Temp, Volts, Gas level, Speedo, Tach, Possibly an air pressure gauge for the fromt air bags, and a clock. I kicked around a monitor for the electric step as well as for storage bay doors, but I dont think I want to run that many wires the full length of the coach.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 06-03-2002, 09:02 AM   #2
Dash and gages all new
Greetings Brett, I have done a few dash changes on several types of vehicles. There are two types of gages, as mechanical [with little bulb] and electrical. Some folks call electrical, electronic for some reason. I don't know any electronic gages other than airplanes where cost is not considered. The most important part of a dash makeover is the "plan". With out a plan all is confusion. My method is to make a paper pattern of the size and configuration required for placement of new layout. Using the paper layout of the dash, begin placing gages to meet your personal preferences. The tach and speedo are usually larger, about 3.375 or 3.500 od. These gages should be centered for quick reference. The steering wheel sometimes also needs to be changes for best view of gages. About all gage makers offer mechanical and electrical gages. My preference is for the electrical gages. Get a few hot rod car magazines and view the gage ads. There are several companies who make an transmission inline fitting to allow a temp gage sender with a good reading location and minimal labor. Of ten I use a single temp gage with a 2 pole switch that will indicate engine or trans temps. The gages I prefer are VDO, Iss Pro or Stewart Warner. Electrical speedos can be substituted for cable/mechanical drive units with a small generator adaptor. I make final dash from .062 Aircraft aluminium 6061 or ABS black plastic sheet .125 thick. All holes are made with a drill press or verticle mill turning very slow.
Visit Idaho The people are great
FrankR is offline   Reply With Quote
Bathroom redo peggy welch Sinks, Showers & Toilets 7 02-14-2009 11:06 AM
79 Excella Bathroom redo zamboni Cabinets, Counter Tops & Furnishings 0 03-25-2004 08:23 PM
1992 polish or recoat Roland Cleaning, Stripping & Polishing 6 06-25-2003 01:51 PM
Poll !! Interior .. Gut it or Keep it ?? airstreamcaravel General Interior Topics 11 05-17-2003 12:18 PM
