Old 10-10-2006, 03:39 PM   #1
rdm
rdm's Avatar
Ignition system advice needed
Hi everyone
I have decided to upgrade my ignition system
I wanted to use Jacobs RV unit but two the parts are not available athis time for our 85 325. What is not available is the direct plug in wiring harness and the internal HEI cap adapter.
It has been suggest by one supplier to replace the distributor and eliminate the need for these parts the other suggestion was to use a MSD kit.
when I looked the MSD site I was lost immediately.
In the past I had a Jacobs system on a 80's 454 pace arrow and like the system very much.
It seems since Jacob's was bought out it is now more difficult to source all the parts neccessary
any suggestions about what to use from MSD
Thanks in advance
Ray
rdm is offline   Reply With Quote
Old 10-10-2006, 06:13 PM   #2
bobchevy89's Avatar
1977 24' Argosy 24
Inverness , Florida
Jacobs Ignition
Hello RDM,Jacobs is still around. I found the parts in JEG'S Racing and it is also in summit racing..I just got the wiring diagram to put mine in my 77 moho..
bobchevy89 is offline   Reply With Quote
Old 10-10-2006, 08:13 PM   #3
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
Ignition
Hello I would say MSD and MAllory are great ignitions and I use MSD In drag race application Also Have a Mallary In my sons street rod. Both are great. I however would reccomend talking to tech at either company instead of Summit Racing or Jegs sometimes I have found you get people that know more about you rig then you do, that always bothered me. Tech line will give you the info you need to make an good decision. You can go to MSD website
or Mallary and get numbers and look at products. Once you are sure what you want, Then go to Summit or Jegs for the purchase. I use the one with the best return policy ussually Summit Racing, for me. I hope this helps.
One thing also Most after market ignitions have a hotter spark the last longer. Which intern will increase power.
Good Luck
mustang is offline   Reply With Quote
Old 10-10-2006, 09:02 PM   #4
1991 35' Airstream 350
Windsor , North Carolina
On a 1991 AS 350 (Chevy 454) I have installed a MSD ignition and coil, and, so far, have no complaint. Have as yet seen no reason to install a new distributor, as the old one works OK. Have less than 1000K on the new equipment.
Best,
Rob
ralley is offline   Reply With Quote
Old 10-11-2006, 12:15 AM   #5
1960 24' Tradewind
santa barbara , California
Hello rdm ,go check older threads that deal with ralleys MSD install ,or PM
to him on it .MSD ignitions are excellent choices and perform great .I have
an MSD system on my 68 IH travelall and my service truck ( chevy 1 ton)
The website is confusing ,but rally has done the mods you will be seeking ,
with road test results to go with it .Jacobs is also a very good system .
MSD has everything available youll need .
Scott of scottanlily
scottanlily is offline   Reply With Quote
Old 10-11-2006, 05:32 AM   #6
CanoeStream's Avatar
St. Cloud , Minnesota
Scott -- This looks to be the thread. Right?
5 meter Langford Nahanni
Old 10-14-2006, 10:53 PM   #7
1960 24' Tradewind
canoe stream,
Yes it is ,getting back here to this thread days late .sorry .
Scott
Advice needed, and perhaps a tip or two. Curtis-79MH Airstream Motorhome Forums 12 06-26-2007 01:43 PM
Computer / Accessories Purchase Advice Needed hex Forum Admin, News and Member Account Info 16 11-20-2003 11:54 PM
30 Footer Advice Needed JaceBeck Our Community 13 10-04-2002 11:51 AM
Small Clearcoat Repair advice needed JaceBeck Clearcoat, Exterior Paint & Trim 2 08-01-2002 07:01 AM
Advice please - Travels, Flags, Fuel and Caravans NickSowter On The Road... 6 06-27-2002 10:04 AM
