11-15-2003, 03:25 PM
Idiot Lights Acting Up
My '92 30' has several of the idiot lights in the dash: specifically - low fuel, low wash and low coolant - that come on and off randomly and with no reason. I actually disconnected the low coolant sender and filled wash water and fuel several times and lights behave the same. They don't flicker, like a cracked circuit board, or come on briefly, they come on for 1/2 hour or so and then go out again. Doesn't seem to be night/day specific, temperature specific or have anything to do with rough roads. It's also not affected by other idiot lights. High beam light works fine. Oh, and they don't all come on or off at the same time. It's been doing it for several thousand miles, so I guess it's not going away. Clearly something is loose or broken under the dash. Do I really have to take the dash out?
Thanks.
11-15-2003, 09:57 PM
Retired.
, At Large
Re: Idiot Lights Acting Up
Thanks.
Sounds like a wire shorted inside the dash. If you unhooked the low coolant sensor, the washer sensor, etc. and still have the lights come on while the sensors are unhooked, look for the common wire that goes to all three.
I know all three items ground to light, so the first thing I would check is a ground wire. If they were shorted to ground from the power side, you would be blowing fuses, or your fuel gauge would read F or E when this happens.
11-28-2003, 08:13 PM
2004 28' Classic
huntsville
, Alabama
when you find the problem pls post. mine just about drove me crazy for 18 hours today, come on go off all come one goes off and then another and on and on . didnt bother me untill it got dark i had to stop and put some tape over the mess.
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 WB , Pro Pride P-3 hitch
centramatics wheel ballancers 300-556
11-28-2003, 08:34 PM
Haven't looked real hard - working on brakes. They're REALLY bright at night, huh. Which ones of yours are acting up?
11-29-2003, 06:49 AM
1978 31' Sovereign
Texas Airstream Harbor
, Zavalla, in the Deep East Texas Piney Woods on Lake Sam Rayburn
Low Coolant and Water in Fuel
Water in Fuel is always solvable with a piece of tape.
There is no fuel/water separator/sensor on the gas units, only the diesel.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
