Old 04-18-2007, 11:28 AM   #1
Mr. D's Avatar
1988 34.5' Airstream 345
White Lake , Michigan
I need to repair damage to the aluminum skin on my 345 MH.
I'm looking for advice on repairing damage to the skin directly above my wheel well on the front right side of my 345. On a recent trip to Florida (4/13) I blew a tire and like a bomb it damaged the skin up past the Banks powerpack grill and back to the front running light just behind the wheel. I live in Michigan and I can't find anyone to service this kind of damage to an Airstream. Is the factory in Ohio the only spot that handles this kind of damage? or do I have other options. Mr. D.
Mr. D is offline   Reply With Quote
Old 04-18-2007, 12:41 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Can you post pictures? Thanks
5 meter Langford Nahanni
Old 04-19-2007, 10:09 AM   #3
Mr. D's Avatar
Pictures of damaged 345 MH
I will attempt to share pictures of the damage ... but I have a severe technology deficiency ... currently my insurance has most of the pictures... Mr. D.
Old 04-27-2007, 03:14 PM   #4
Mr. D's Avatar
Old 04-29-2007, 10:08 PM   #5
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Ouch! Tire blew out?
There are three ways to repair this one....the "cheap" way, the "decent" way and the "perfect" way.
The cheap way would be to replace the lower section where the docking light is located with sheet stock. Cut to size, rivet back in, replace beltline and live with the crease in the "fender".
The decent way would be to install a replacement panel (again made of sheet) over the existing "fender" panel" from the awning ribline forward to just past the damage and extending under the trim below the window. This would be a "scab" concept if you will.
The perfect way would be to replace the entire "fender" panel with a new one from Airstream. Because it's aluminum, there is no way to remove the crease so the only way to acheive an "as new" replacement would be this approach. Ideally, this kind of work should be peformed by Airstream at the factory or one of the better repair shops. This is also a very expensive panel to purchase.
All three would require trim replacement on the fender and the beltline.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 05-01-2007, 07:46 AM   #6
Mr. D's Avatar
Thanks for the advice.
Thanks for the advice, my goal is to restore to original condition, or as near to that as I can. Currently I am in discussion with an outfit in Holland Michigan that does this kind of repairs. I have not received an estimate from them but I'm expecting something between two and three thousand dollars. Once I get a couple of estimates I will be in the position of deciding whether to do it myself or have someone else do that for me. Does anyone have experience with this type of work that could give me somekind of appreciation for the level of difficulty I would be encountering? I have a parts list and prices from Airstream, the Banks grill and light fixture are no longer being made so getting those parts is another question I need to throw out for advice....Mr. D.
Dash Repair Questions JW84345 Airstream Motorhome Forums 15 07-15-2012 08:59 PM
Winterizing a 345 Motor Home winner Airstream Motorhome Forums 11 09-29-2007 12:56 AM
Shower door. Has anyone put one on a 1987 345 or similar airstream with curtain? MacInDaBox Airstream Motorhome Forums 2 05-17-2007 12:06 PM
Bent Door Repair Road Ruler Doors & Locks 6 09-02-2002 07:27 PM
Question re how to cut aluminum sheeting and get a clean edge... williamhenshall Ribs, Skins & Rivets 7 06-12-2002 05:58 PM
