Old 09-26-2006, 12:34 PM   #1
Mr. D's Avatar
1988 34.5' Airstream 345
White Lake , Michigan
I need a new speedometer for my '88 345
I just got the bad news on my non functioning speedometer and it is the type that can not be repaired. The diameter of the dashboard opening seems to be irregular and finding a new replacement has proven difficult. Has anyone replaced their speedometer on a similar rig? and if so, any ideas or sources would be welcomed. My cruise control is also in-active but I am not sure if the broken speedometer is connected to that problem or something separate. Thanks in advance for any ideas or suggestions...Mr. D.
Mr. D is offline   Reply With Quote
Old 09-26-2006, 01:18 PM   #2
bobchevy89's Avatar
1977 24' Argosy 24
Inverness , Florida
Hello Mr D, try bontragers surplus parts in White pigeon Mi. phone# 269-483-7017 Or trythe search item here for salvage or used parts.thats were I found bontragers.. Bobchevy89
bobchevy89 is offline   Reply With Quote
Old 09-26-2006, 05:51 PM   #3
Robfike's Avatar
1999 36' Land Yacht Widebody
Spencer , Indiana
You can try custominstrumentpanels.com They stock some instruments that work with our panels. I have had good luck with them.
Good luck, Rob
Robfike is offline   Reply With Quote
Old 09-28-2006, 05:51 AM   #4
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
The Summitt folks have some very cool all digital panels for custom installation. I've often looked at the mess behind the panel and though about a complete redo with a full digital setup.... but I digress.
GPS will give you speed as well as distance.... My Delorme Street atlas on the laptop is always on.
The low tech short term is little dymo labels on the tach for final drive speeds.
So many solutions.... so little money....
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 09-28-2006, 05:56 AM   #5
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
I don't know if your rig and my 1984 310 Limited use the same speedo. Mine failed and I got a replacement that didn't match but worked, I then had mine fixed and put back in. I'm 4000 miles from home at the moment so I can't look at the replacement which is on the shelf at home. I'd be happy to check it when I get home (late Oct.).
Also some folks have had good luck with these folks:
http://www.speedometershop.com/
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 09-28-2006, 08:00 AM   #6
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
Cruise Control
The cruise control speed sensor is mounted on the rear left of the transmission. It has two wires running from it to the control unit. The speedometer cable attaches to the speed sensor, so if the speed sensor fails, it takes your speedometer with it.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 09-28-2006, 10:23 AM   #7
RichardT's Avatar
I have a speedo from an 82, if that will work pm me. I have most every other guage from an 82 diesel as well if anyone needs anything.
RichardT
RichardT is offline   Reply With Quote
Old 09-28-2006, 11:40 AM   #8
Mr. D's Avatar
If the speedometer does not work but the cable still turns without any cruise control does this also mean that the cruise control does not work also? Or do they work separately? Mr. D. Also has anyone any advise on what the best for the money dash mounted GPS unit might be?...and where I might find these units?
Old 09-28-2006, 03:02 PM   #9
The Hawk's Lair
cooperhawk's Avatar
If the cable still turns then both the speed sensor and speedometer have failed. I use the Garmin Street Pilot. I fabricated a bracket so it sits on top of my dash right by the left windshield frame. I could hook it to a laptop, but would have to fight my wife for the laptop.
AKA THE GUNNER
VFW, LEGION, NRA
Old 10-10-2006, 12:24 PM   #10
Mr. D's Avatar
Please let me know when you return home and maybe we can work something out in regards to your spare speedometer. I assume the entire exchange depends on the diameter of yours fitting the diameter of mine as it fits in the dashboard. I assume they use the same type of cable, etc. Have a nice trip and give me a note at garry1rondi@aol.com..thanks Mr. D.
Old 10-28-2006, 03:05 PM   #11
guy99's Avatar
Images: 16
Mr. D.,
I'm back, are you still looking for a speedo?
Guy
Old 10-30-2006, 11:36 AM   #12
Mr. D's Avatar
I would like to get more details on the size and shape of your speedometer? If it has the proper dimensions I'd like to talk to you about working out a deal. Thanks for the write back...Mr. D.
Old 10-31-2006, 03:39 PM   #13
guy99's Avatar
Images: 16
Its a Stewart Warner 82677:
http://www.stewartwarner.com/Catalog/2dlx1.html
Round, 3 3/8 inches. Can't say that it matched my other gauges, only that it worked until I had mine repaired.
Winterizing a 345 Motor Home winner Airstream Motorhome Forums 11 09-29-2007 12:56 AM
Shower door. Has anyone put one on a 1987 345 or similar airstream with curtain? MacInDaBox Airstream Motorhome Forums 2 05-17-2007 12:06 PM
Door-Step Cycle -345 winner General Motorhome Topics 8 10-04-2002 02:19 PM
Classic 345 davidz71 Our Community 1 07-26-2002 08:54 PM
Speedometer Problems ViewRVs Mechanics Corner - Engines, Transmission & More... 1 05-13-2002 08:00 PM
