09-19-2008, 04:07 PM
1984 31' Airstream310
Ajo
I don't give a rat.
09-19-2008, 04:53 PM
2014 25' Flying Cloud
Cuddebackville
, New York
I don't get it- your gauges are broken?
09-19-2008, 05:08 PM
Ajo
How do you know any of your gages work?
09-19-2008, 05:16 PM
Ajo
One tends to keep a eye on gages when puttting on 20K a year.
09-19-2008, 06:04 PM
Cuddebackville
, New York
Well at least mine move off "0".
09-19-2008, 07:12 PM
West of Fort Worth
Some things have to be accepted by faith or experience on how the gages read and how the engine runs, etc.
For that matter, how do you know your rear bumper is still back there as you go down the highway....?
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
09-19-2008, 07:19 PM
Ajo
Whatever, for sure you experts have got way more experience than the 250K full time miles we have.
I was making a point about good quality gages; that's all; what's the deal with your comments?
09-19-2008, 10:16 PM
Salem
, Oregon
Hi, Mike Leary. Maybe it's a full moon, or they are moody, or maybe the way you started your post. "I don't give a rat." Either way my opinion is that the less some people know mechanically about their vehicles, the better off they are without all these gauges. It just makes people panic when their trans temp goes up 10 degrees in reallity it's nothing to worry about. And for those who do understand what is going on under the hood, I'm sure those are great gauges. As a mechanic since 1968 I do know what's going on under my hood, but my vehicle was designed to do the job of towing my trailer, and more, and I'm going to rely on what the factory gave me when my vehicle was made. [my opinion]
God only knows I can't text message and read two extra gauges at the same time. [Just kidding]
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
09-20-2008, 05:01 AM
Cuddebackville
, New York
Well my point was simply that I didn't understand what point you were trying to make. To me at least, it wasn't clear what you were getting at. Maybe putting the above sentence in your OP would have helped.
09-20-2008, 07:38 AM
1986 25' Sovereign
Southern Middle
, Tennessee
I've always felt that properly functioning gauges were better than idiot lights. If you learn to check them on a regular basis while running down the road, they give you great information which can help you should one of them indicate water temp, oil pressure, alternator voltage/amps, rear dif temps are not what they should be. Some people have not taken the time to learn what the normal range is for each of these gauges and that is a mistake.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
09-20-2008, 08:00 AM
Ajo
I've replaced all of my gages with the ISSPRO, great product. Sorry we got the thread screwed up. The point was, as you diesel guys know, is while climbing,
your heat, boost and water temp. are all you need to look at!
09-20-2008, 08:09 AM
1975 31' Sovereign
Searcy
, Arkansas
So a rat got into your instrument cluster?
Just kidding!
Good point Mike!
G
Airstream of Arkansas
www.airstreamofarkansas.com
877-Air-hog1
877-247-4641
Keeping the Airstream Dream Alive!
AIR #8844
09-20-2008, 08:15 AM
1992 34' Excella
Austin
In the big trucks, we keep an eye on our exhaust gas temp in a long climb so that we don't melt a piston. In my Peterbilt I had a separate sensor installed upstream of the turbo so that I could see the actual piston temp (there's about a 300º temp drop across the turbo) and I never let my temp get closer than 100º to the piston melting temp. I put a million miles on that Cummins.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
09-20-2008, 08:23 AM
West of Fort Worth
Mike,
Thanks for the added info, it wasn't my intention to twist your knickers .
Sorry 'bout that.
Dave
AIR #15800
2000 Safari SS 25'
