Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 12-31-2004, 10:23 AM   #1
Astrodokk
Astrodokk's Avatar
Profile:  Santa Rosa , California
Hydro-boost needs rebuild
The mechanics at the Chevy dealership said they couldn't get the rod out of the middle of this thing, and are sending it to a rebuild place. They say that if it can't be rebuilt, they haven't found a replacement yet. Any ideas where we can find one?
1981 Excella 454 28', rear bath, twin beds.
Astrodokk is offline   Reply With Quote
Old 12-31-2004, 12:08 PM   #2
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
Thats not an uncommon part. There are plenty of places to get that. This guy and I had some debates about the need for Hydroboost on some vehicles. Tell him "Grim Reaper" sent you. He will get a laugh out of it. He makes custom set ups from stock GM parts and should be able to set you up with what you need.
http://www.hydroboost.com/index.html
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 12-31-2004, 03:12 PM   #3
Astrodokk
Astrodokk's Avatar
Thanks. I sent them an email.
Old 12-31-2004, 03:23 PM   #4
livexl
livexl's Avatar
Profile:  Huntington Beach , California
hydro-booster
When my hydro-booster went out i replaced it with a new one from Workhorse Chasis. Good Luck ...
http://www.workhorse.com/
livexl is offline   Reply With Quote
Old 12-31-2004, 04:29 PM   #5
swebster
RivetAddict
swebster's Avatar
Profile:  Louisville , Kentucky
You will want to double check the part number on this but I found them on www.rockauto.com for the P30 MH Chassis for both 2 wheel and 4 wheel disc brake systems. Rebuilts for around $200 less a $40 core).
Again check the p/n but I've ordered parts from these guys before and have had no problems at all.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
View My ThisOldRV.com Personal Page
ThisOldRV.com
swebster is offline   Reply With Quote
Old 03-03-2005, 07:39 AM   #6
mcneon
mcneon's Avatar
Profile:
I'm replacing the Hydro-Boost power brake unit in my '74 Argosy. This thing was a real bear to remove, but it's finally out. Now, I can't figure how to remove the pushrod from the front end. There appears to be some sort of retaining ring down deep in the bore, but I really don't want to force anything.
Can anyone who's been there offer guidance?
mcneon is offline   Reply With Quote
Old 03-03-2005, 02:24 PM   #7
Astrodokk
Astrodokk's Avatar
Since I hired the dealer to do the job, I have no first hand knowledge of the difficulty of removing the rod, but i was told by them that it was a bear and actually, the rod came out in the hydroboost and they couldn't remove it from the housing...it had to be sent to a shop 100 miles away to get done and rebuilt. Good luck.
Old 03-03-2005, 07:54 PM   #8
mcneon
mcneon's Avatar
Profile:
Got the pushrod out. Turns out the retaining collar is actually a hard rubber or flexible plastic material. The installed collar has to be destroyed to get the pushrod out. The replacement unit I bought from Rock Auto included a new retaining collar.
There's apparently a factory tool that will do the job easily. My solution, though less elegant, was effective (see pic). I attached the spider from the 3-jaw puller for my slide hammer to the pushrod. After chucking the Hydro-Boost in the vise, a few whacks sheared the retaining collar and freed the pushrod. The picture shows how I attached the pushrod to the slide hammer. Note that this is a big slide hammer, about 5 lbs.
In the photo, I've already installed the new collar on the pushrod. The pushrod should install with a few gentle taps. Now, to wrestle the whole assembly back into place!
Note: I assembled the pushrod to the slide hammer for photo purposes - it's not needed for reassembly. A much smaller dead-blow hammer should work.
Old 03-03-2005, 08:42 PM   #9
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Just a question....are we talking about the same hydroboost found in my 2004 Suburban or is this the commercial heavy, heavy duty version?
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 02:37 PM
2005/2006 International Rallies Over59 WBCCI Rallies 21 06-24-2004 10:55 AM
solar boost 2000E nwclassic Our Community 2 03-20-2003 08:21 PM
Dump Valve Rebuild wagsrp Waste Systems, Tanks & Totes 2 10-12-2002 01:01 PM
Furnace problems... Andy R Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-01-2002 08:29 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
