Old 01-13-2012, 10:13 PM   #1
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Hydraulic leveling jacks
Sure hope I'm starting this thread in the right section. Does anyone know where the fluid reservoir is for the leveling jacks? I've looked and looked through my owners manual, and am at a total loss.
Thanks, Derek
Old 01-13-2012, 11:39 PM   #2
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Thanks, Derek
Check your other post. My HWH is one end of the pump/power unit.
Cheers, Dan
Old 01-14-2012, 05:52 AM   #3
crazeevw's Avatar
Cheers, Dan
Thanks Dan!
Old 01-14-2012, 08:51 PM   #4
On mine its the huge tank right under the hood, in front of the radiator...
Old 01-17-2012, 11:21 AM   #5
Mr. D's Avatar
1988 34.5' Airstream 345
White Lake , Michigan
On my '88 345, it is under the floor between the front seats. Take the engine cover off and put your head down far enough to see the transmission and that is where they put mine. Have fun working on it if you have the same location. Good luck, Mr. D.
Mr. D is offline   Reply With Quote
Old 03-05-2012, 06:22 PM   #6
woodja's Avatar
1982 31' Airstream 310
Dayton , Tennessee
On my '82 310 the reservoir is pretty much under the drivers seat, And barely accessible from the dog house.
Does anyone know a good way to put the springs back after rebuilding the jacks? I think this is going to be tricky. Pete
woodja is offline   Reply With Quote
Old 03-08-2012, 06:21 PM   #7
woodja's Avatar
Dayton , Tennessee
After several days, I'll answer my own post. I was re-installing the left front jack after a rebuild & really struggling with the springs. I was able to get them back on by running a come-along from the rear axel forward to the springs. I was able to stretch them out enough to hook them together around the top of the cylinder. Next time, no problem.
Old 03-22-2012, 07:34 AM   #8
I just came across this thread. I read the post before this and knew I had the answer. Then I read this one. That is exactly how I reattached my springs when one broke in the middle of the night. I may have attached the come along to a different point but it is a great way to pull the springs into position.
8rmesse is offline   Reply With Quote
Hydraulic leveling jacks bobnmary Repairing/Replacing Floor &/or Frame 16 12-12-2018 01:57 PM
1979 28' Excella Leveling System marydixon555 Jacks, Stabilizers, Lifting and Leveling 5 04-28-2011 06:19 PM
LY Hydraulic Leveling System LaCajun Land Yacht/Legacy Motorhomes 3 04-25-2011 07:46 AM
Hydraulic leveling system. boatdoc Jacks, Stabilizers, Lifting and Leveling 18 02-08-2011 05:30 AM
