Old 07-26-2010, 12:40 PM   #1
1977 25' Tradewind
kamloops , British Columbia
hydraulic brakes
I have a 2000 ford f350 with the v10 and have recently bought a 1977 airstream with hydraulic brakes. The vehicle was toed home with no brakes as I don't have the vacuum line rigged up yet. Does anyone know the best place to pull the line from the motor.
lance3787 is offline   Reply With Quote
Old 07-26-2010, 01:08 PM   #2
Lance,
I'm assuming you're talking about a 1977 Airstream (Argosy) motorhome. If won't have vacuum assisted brakes. It will have a hydroboost brake system. It uses a hydraulic booster that receives its power from the power steering pump.
If the power brakes are not working then you'll need to inspect the lines from the power steering pump to the hydroboost. The hydroboost is between the master cylinder and the brake pedal. Any number of things could be wrong with your hydroboost system.
More info and pictures would definitely help us give more detailed advice.
Old 07-26-2010, 01:08 PM   #3
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
This vacuum brake system was only used for a few years. Most trailers using this have already had the drums and backing plates changed out and converted to electric brakes.. I seem to recall there was some kind of adapter used with these to provide the vacuum and control the amount of brake actuation..
Even if you get the parts to make the existing system work you will have a setup that is not compatible with anything else you may want to hook to.
Possibly Andy at Inland RV can point you in the right direction
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 07-26-2010, 01:16 PM   #4
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
If you have hydraulic disc brakes, you can purchase a new electric over hydraulic actuator and replace the vacuum system. Much more reliable and you get to keep the disc brakes.
Bill
Just my personal opinion
wkerfoot is online now   Reply With Quote
Old 07-26-2010, 01:38 PM   #5
1977 25' Tradewind
would like to keep the hydaulic brakes and ive heard about carlisle having a system but was hoping to see if the stock still worked or was repairable
Old 07-26-2010, 01:44 PM   #6
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
The previous owner of our '83 Excella got very tired of dealing with the hydraulic brakes and changed them to electric.
I am very happy that he did that. If hydraulic brakes were the hot setup they would still be using them from the factory.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 07-26-2010, 01:57 PM   #7
erock53's Avatar
1978 31' Sovereign
Cincinnati , Ohio
I have a 78 Soviergn that had the same Vac-Assist brake system that you are describing. You have a few options. 1) purchase a electro / hydrolic motor that will operate the brakes with out the vacuum connection. 2) convert the current disc brakes over to a full electric system by replacing the discs with electric drums. 3) what I chose to do was to replace the whole system. You have a 1977 Airstream. I have yet to see one that still has an original axle that is not shot. That was my case. I decided to replace both axles with a complete new system. I chose a Dexter system with hydraulic disc brakes. You can read my blog to see how I did it. There are countless threads on this forum that describe what you need to do to replace your axles. There are also countless threads that describe what brands are out there. My personal opinion is that you should save yourself the hassle of trying to get the old brake system working and just replace the whole thing. The last thing you want on a vacation with your family is to stomp on the brakes and not be able to stop.
http://e-rock53.blogspot.com/
TAC#: OH-13
erock53 is offline   Reply With Quote
Old 07-26-2010, 02:09 PM   #8
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Jim,
I believe that the factory does use hydraulic disc brakes on some models. Someone who knows more about new Airstreams can correct me if I am wrong.
Bill
Old 07-26-2010, 02:17 PM   #9
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Originally Posted by wkerfoot View Post
Jim,
Bill
Why would they do that?
Old 07-26-2010, 02:39 PM   #10
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
With the right actuator, they work better. Uwe believes that discs are the best thing since sliced bread.
Bill
PS: Leaving on Saturday for Salida. Two nights at the North Rim. See you and Lynn there.
Old 07-26-2010, 03:48 PM   #11
Wise Elder
Jammer's Avatar
2010 30' Classic
At the present time, Airstream is not using hydraulic brakes in new production. They were using them on Classic trailers from around 2005 to 2009. My trailer does not have them. However, there have been considerable numbers of trailers converted to hydraulic disc brakes, both by the Jacksonville service center, and others. In some cases these have been new trailers.
Hydraulic disc brakes are said to provide better braking and are said to require less ongoing maintenance, compared to electric drum brakes.
Old 07-26-2010, 04:52 PM   #12
_
... have recently bought a 1977 airstream with hydraulic brakes...
hi lance welcome
a nearly 35 year old stream, lets see...
-it probably needs axles...
-howz the SUBflooring?
-how much RUST on the frame?
-got rear sag?
-is the shell SECURELY attached to the frame/C channel?
the point is there may be a LOT Of work and money to spend before needing brakes.
modern discs (electric/hydraulic) are pretty darn good, and i would NOT tow without them...
but IF you want a disc setup TOSS all the old bits and start over...
((sure u can use SOME of the components but WHEN were they last functional? ))
if you need axles buy them as a package and save a bit o'dough.
but don't even TRY hooking up a common hydraulic line from the truck.
that's a MESS 2do and the truck won't like it.
cheers
2air'
Old 07-26-2010, 06:48 PM   #13
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
I had the old Hydraulic disc brakes on my 77. Nothing but problems on the road. No one has parts or can service them. There is also a fatigue crack flaw that develops in the welding of the caliper holders. I dumped them and went electric. Good enough for 30,000 miles behind a 3/4 ton van. Maybe the new disk brake systems are better now but I would not fool around trying to get the old ones to stay working.
Old 07-26-2010, 09:07 PM   #14
JFScheck's Avatar
Rockville , Maryland
Images: 33
Don't fool yourself - Hydraulic disc brakes are far superior - the factory only stopped using them to save money without having to change Airstream prices (as I was told on a tour a few months back) and will be making a resurgence once the economy and sales start to climb.
John "JFScheck" Scheck
In Between Units
Airstream On Order
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Hydraulic brakes? wacnstac Brakes & Brake Controllers 32 03-26-2006 06:36 PM
Electric Over Hydraulic brakes? JimGolden Brakes & Brake Controllers 23 11-17-2005 09:32 PM
Hydraulic brakes? wyhjr Brakes & Brake Controllers 0 11-04-2004 05:10 PM
Which ones had hydraulic brakes? Roze Brakes & Brake Controllers 3 09-29-2004 05:19 PM
hydraulic brakes wayne.yl Brakes & Brake Controllers 3 07-08-2004 08:23 PM
