Old 10-02-2012, 03:23 PM   #1
Landmammal's Avatar
1977 Argosy 24
Underalog , Illinois
Unhappy Hubby made a battery booboo!
My husband got me a new battery for tow-truck aka 2004 Mercury Mountaineer and now my brake controller does not light up/work at all. Any ideas? He is hopeless at all things mechanical/electrical but will take any suggestion and try his best.
Landmammal
TAC IL-12
Air# 48404
Landmammal is offline   Reply With Quote
Old 10-02-2012, 03:49 PM   #2
2012 23' International
None , Happy
I bet the power wire to your controller was hot wired to the battery. Look for a lose wire near the battery?
thomp is offline   Reply With Quote
Old 10-02-2012, 03:51 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Landmammal!
I suspect that there could be one of several causes for the brake controller ceasing to function after replacing the tow vehicle's battery:
  • On my 1977 Cadillac, the positive wire for the brake controller is inserted into the positive cable clamp on the battery . . . if this connection is not tight and clean, the brake controller can prove problematic.
  • If the battery cables were reversed momentarily, or if the ground was connected before the positive cable, a power surge may have either tripped a circuit breaker/fuse or killed the brake controller's circuit board.
  • Was your trailer connected when testing the brake controller following the new tow vehicle battery installation? With some brake controllers, the pilot light only illuminates when the trailer is connected to the circuit (that is true of my Voyager controller, but the pilot light is on whenever the ignition switch is in the "on" position with my Hayes-Lemmerz brake controller).
  • With the blade type trailer wiring connector, corossion can become problematic. I ofthen either had problems with the brake and/or charge line connections requiring cleaning the terminals and connectors on both tow vehicle and trailer ends. To end this constant issue with corossion, I switched to heavy-duty round-pin connectors ustilized by the over-the-road trucking industry . . . these are said to be self-cleaning each time the devices are connected/disconnected.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 10-02-2012, 05:24 PM   #4
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
Probably, whoever installed the battery failed to reconnect a wire to the positive + post that was the power source for the controller.
robert claus is offline   Reply With Quote
Old 10-02-2012, 05:28 PM   #5
dznf0g's Avatar
Oswego , Illinois
Some controllers are very particular about the order in which the wires are hooked up. Some require a specific sequence of power hookup, or they get confused. Get you installation manual out and see if there is verbiage to that effect.
-Rich-
