Old 10-20-2010, 11:54 AM   #1
1988 32.5' Airstream 325
Groveland , California
HT 502 replacement for 454
I have decided to replace my 454 with a new crate 502. There are two HT 502 engines #88890534 which is carberated and #88890533 which can be injected and is 50 state compliant. The later would require a transmission swap 480LE from my th475 but I would have to rebuild at this point anyway. It's a 1987 325. Has anyone done either swap or has someone done the injected route with the Edlebrock ED3564 or 3565 Injection and the new transmission? I hate to break new ground here - so, going to school on you guys first may save some stress. Thanks
COUCH2TH is offline   Reply With Quote
Old 10-20-2010, 12:42 PM   #2
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Just curious, why do you need a trans swap with the 88890533?
Vaughan
Old 10-20-2010, 03:42 PM   #3
2001 30' Classic S/O
2001 36' Land Yacht XC Diesel 300 hp w/slide
Helotes , Texas
Why not get the 502 RamJet. It should work with what you have very simple swap
lsmith is offline   Reply With Quote
Old 10-20-2010, 04:19 PM   #4
Images: 59
Maybe he wants a good towing motor that runs on regular and costs half as much as a race motor?
Old 10-20-2010, 09:24 PM   #5
The indication I got was that the ...533 engine with injection would need some kind of computer interface with the transmission. This engine is for a 1990's vehicle and the the ...534 is for a 1970's.
Old 10-21-2010, 01:51 PM   #6
Vintage Kin
Fort Worth , Texas
512 ft.lbs. of torque at an incredibly low 2800 RPM and 338 horse power at 4500 RPM
Sounds -- literally -- like the perfect cam profile. How does that work with rear gears and tire height for 60-mph cruise speed? I know we used to like to cruise -- while towing -- just below peak torque. Slap the cruise on and it practically drove itself (the CC type from the 60's/70's).
Who has jetting/metering rod info for your changes on the carburetor? Does EDELBROCK still market their QuadraJet replacement series?
Old 10-21-2010, 07:01 PM   #7
r carl's Avatar
Lin , Ne
Why dont you rebuild what you have?
Ventline screen replacement BB 55 Bubble Roof Vents, Skylights & Fans 1 10-29-2011 11:53 AM
Replacement issues wander'n Refrigerators 0 10-11-2011 06:25 PM
Replacement LED fixture under front cap Pat Conway Lights - Interior & Exterior 2 04-12-2011 01:22 PM
