Old 11-28-2004, 06:15 PM   #1
RichardT's Avatar
How to remove steering dampner? P30
I am replacing the front shocks and the steering dampner on my 79 Excella with some Bilsteens. I got the old shocks off with alot of effort, but I need some ideas on how to remove the tapered end of the old dampner from the pitman arm. It does not want to come out.
What is the correct procedure and tool?
RichardT is offline   Reply With Quote
Old 11-28-2004, 06:38 PM   #2
zamboni's Avatar
"Pickle fork"
Have you tried a Pickle fork, often used for separation of ball joints. Another method which I have had success with is a 2 # hammer behind the "stuck" connection and tapping the front side with another 2 # hammer, it just pops out
zamboni is offline   Reply With Quote
Old 11-28-2004, 06:47 PM   #3
RichardT's Avatar
I will find my pickle fork and give it a try.
I looking up front air springs to replace my bad ones, have you ever done this job?
It looks like a small pain, but I will be doing it soon, I will also be cleaning things up, greasing, etc...
Old 11-28-2004, 08:10 PM   #4
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
I did the front bags this summer. Not as bad of a job as you might think. Dennis (87MH) posted a procedure on the forum which saved me a lot of time. Removing the old bags involves cutting out the bottom schrader valve then making spiral cuts from the top to the bottom and pulling the old bag through the hole in the bottom of the lower A-arm. Seems like a good pair os vice grips and some dish soap helped.
Installing basically involves collapsing the new bags and holding them with worm gear clamps (like for your radiator hoses). Then sliding up through the hold, dropping each band clamp as you go. Partially inflate, move into final position then fill.
Do a search on the forum for front air bags and you'll find the procedure.
One tip: the PO ran a T line to a pressure gauge and a dash mounted schrader valve. I can always see the front bag pressure and adding air is a simple as hooking up my 12V compressor from the cockpit. Very easy and way cheaper then those auto fill systems from CW.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 11-28-2004, 08:47 PM   #5
RichardT's Avatar
I have another question.
on the drivers side exhaust manifold there is a small threaded hole (about 1/8 inch?) on the second boss (from the front to back) even with the spark plugs, any ideas what this hole was for? any idea what size threads it is so I can go get a bolt to close it?
Exhaust is exiting this hole while running and creating a really nice blowtorch effect! Cool huh? Not.
It is a 1979 454 (built in 1978)
PS: My description of the size and location while close could be off a little as I am not near the motorhome and am describing it from memory.
Old 11-29-2004, 07:07 AM   #6
RivetAddict
swebster's Avatar
Not sure on the little 1/8" "plug" - the flames sounds pretty cool and dangerous.
Steven Webster
AIR 1760
Old 11-29-2004, 08:29 AM   #7
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I also beat the mess out of the steering damper getting it off. Also-
Collapsing it by turning the steering wheel helped me to align when mounting the new one.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 11-29-2004, 12:13 PM   #8
LOST , Hawaii
Only 1 cylinder? If all cylinders it is probably for the AIR system.
John
74Argosy24MH is offline   Reply With Quote
Old 11-29-2004, 04:40 PM   #9
Are you sure it's on the driverside? Some exhaust man. used to be the sorce for heat to the carbs. choke . There was a tube that passed through the exhaust man. that had a tendency to burn out over time . If thats the case you'll find you have another exhaust leak on the underside of the man. oposite the one you see. Later they went to electric chokes but some engines were produced with the old style mans. untill they were used up. Also some replacement mans. came that way so you could use them on different year models. If thats the case and your not using that port just thead a self threading bolt in it to stop the leak. There is a replacement tube you can install if you need it for your choke. It's almost imposable to put it in with the man. on the engine. Hope that helps-----Pieman
MikeL is offline   Reply With Quote
Old 06-15-2005, 09:18 PM   #10
alfalsetto's Avatar
1982 31' Airstream 310
Longview , Washington
Maybe Exhaust temp. gauge. My Deisel use a 1/4 hole for its sender.
alfalsetto is offline   Reply With Quote
1975 P30 wiring diagram (as promised) ... Hayseed Airstream Motorhome Forums 1 11-22-2012 02:28 PM
Steering Stabilizer rdm Mechanics Corner - Engines, Transmission & More... 2 09-17-2004 06:03 PM
Stone Guard/ Keep it or Remove it? 74Tradewind Rock Guards, Segment & Window Protectors 9 06-26-2002 01:09 PM
How to remove the glass from windows? Andy R Windows & Screens 2 06-19-2002 09:30 AM
How Do I Remove Rivets melprice General Interior Topics 1 05-31-2002 06:07 PM
