Old 11-23-2006, 10:51 AM   #1
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
Question How do I cut off the engine
1994 Airstream motorhome with a cummins pusher. Turned the engine on check it and make certain all is ok. We have had a long period of rain and there was some leaks around the windshield area. When I went to cut off the engine it would not secure. It has been running for 24 hours and I really don't want it to cut off because of lack of fuel. Any suggestions?
Tarheel
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 11-23-2006, 11:04 AM   #2
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
Turn off the fuel or the air that is the only way to shutdown a diesel. Usually they turn off the fuel. Has it overheated yet?
Michelle TAC MT-0
Sarah, Snowball
Old 11-23-2006, 11:08 AM   #3
Tarheel's Avatar
Images: 21
it is running cool, no problems with overheating, the unit is at a friends house he has just had knee replacement and has difficulty getting in the engine compartment. Has already tried cutting off air supply but has been unable to completely starve it.
WBCCI # 348
Old 11-23-2006, 11:22 AM   #4
If it has a electric driven pump, disconnect the wires. Engine driven? Disconnect the incoming fuel line. Not outgoing. drain the fuel tank? trying to cutt of the air could risk having something sucked into the engine.
Find the shutoff valve and manually close it. I am out of suggestion at this time...
Michelle TAC MT-0
Sarah, Snowball
Old 11-23-2006, 11:38 AM   #5
Tarheel's Avatar
Images: 21
Its a mechanical fuel pump and he is not physically able to disconnect the fuel line. Its a bear when your physical ability limits what you can do. If it were straight shift he could stall the engine, not easy to do with an automatic which is mired in mud.
WBCCI # 348
Old 11-23-2006, 03:16 PM   #6
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
Cummins
Okay, been a while since I drove diesel simis, however, if it is the usual cummins PT Pump there may be a lever on the pump that switches from electric to manual. If so, try switching that. If not, the on off switch to the pump used to require voltage to hold a ball suspended that allowed fuel to flow. Try disconnecting the batteries. It could be that the ball is gummed up and won't drop into place to block the fuel flow, try tapping on the pump with a hammar. TAP, don't strike. If none of that works, disconnecting the fuel line coming into the pump will stop the engine for sure, however you will want a container to catch the fuel until the fuel pump stops.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 11-23-2006, 03:33 PM   #7
Tarheel's Avatar
Images: 21
Thanks I have passed this information to my friend with the problem. It may have run out of fuel by now.
WBCCI # 348
Old 11-23-2006, 04:19 PM   #8
1976 25' Caravanner
Campton , New Hampshire
It is probably the fuel shut down solinoid stuck in the on position , it is just foward of the fuel filter , pull down on the rod that comes out the bottom . If he has a manual it will show a picture of it's location , drivers side of the engine .
P.S. It looks like a small canister , about 1-1/2" dia.,with a bellows below and a rod coming out the bottom. Good luck
ticki2 is offline   Reply With Quote
Old 11-23-2006, 04:37 PM   #9
1976 25' Caravanner
Here's a picture
Old 11-23-2006, 04:39 PM   #10
1976 25' Caravanner
Try again
Old 11-23-2006, 04:42 PM   #11
1976 25' Caravanner
Sorry , can't get it to work
Old 11-24-2006, 09:52 AM   #12
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
On my dashboard I have a handle which I pull to stop the engine. This handle cuts the fuel supply. Is it possible such a handle is also on your dashboard?
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 11-24-2006, 07:04 PM   #13
Tarheel's Avatar
Images: 21
He couldn't find a kill swithch on the dash, it has run out of fuel and is secured at the present time. Thanks for all the help. I guess I need to look at my new cummins and see how I would shut it down if it happened to me. I am pretty sure it was a problem with the fuel shut down valve.
WBCCI # 348
Old 11-25-2006, 07:34 PM   #14
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
Kent, are you sure the handle is a fuel shutoff? I thought that was a compression release... If it's a fuel shutoff I've given someone some bad info regarding cold weather starting.
I have had some older semi tractors that had a compression release to aid in cold starts as you could get the engine turning before adding fuel and ignition.
Please correct me if I've been wrong.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Class B-190 Vans - engine size joysjoy600 Sprinter and B-van Forum 19 08-27-2015 01:22 PM
Engine Revving Problem winner Mechanics Corner - Engines, Transmission & More... 19 02-08-2010 10:05 PM
Help!! Engine Won't Start!! eraffety Mechanics Corner - Engines, Transmission & More... 41 07-05-2006 07:01 PM
454 engine questions Curtis-79MH Mechanics Corner - Engines, Transmission & More... 10 10-06-2003 06:22 AM
Engine Monitoring, gauges etc. thenewkid64 Mechanics Corner - Engines, Transmission & More... 1 07-25-2002 02:25 PM
