Old 11-25-2006, 09:30 PM   #15
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Glen,
My manual calls it a fuel valve shut off, thus I assumed it shut off the fuel.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 11-26-2006, 06:11 AM   #16
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
Thank you Kent! I stand corrected embarassed, but corrected.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 11-26-2006, 09:34 AM   #17
1977 28' argosy moho
scarborough , ontario
I' m no mechanic, but all the firetrucks I've driven in the last 25+ years have a fuel shutoff that you pull out of the dashboard like the old manual chokes. We also have a secondary shutoff that is basically a metal flap that falls down over the air intake to starve the engine. The secondary has to be manually reset and we are always told not to touch it unless the primary doesn't work. Hope this helps.
Warbs is offline   Reply With Quote
Old 11-26-2006, 05:55 PM   #18
1991 35' Airstream 350
Windsor , North Carolina
Stopping diesels
One of the things that can be done to stop a diesel which is running on after the key is turned off is to loosen and remove the primary fuel filter. It is usually a spin-on filter on the engine--somewhere near the injectors. Removing the filter allows air into the fuel line and will stop the engine before it consumes all of the fuel in the tank.
Starting an engine which has been fuel starved requires bleeding the air out of the fuel lines at the injectors. Turn the key on to cause the fuel pump to run, and use a line wrench at each injector to bleed the air.
Best,
Rob
ralley is offline   Reply With Quote
Class B-190 Vans - engine size joysjoy600 Sprinter and B-van Forum 19 08-27-2015 01:22 PM
Engine Revving Problem winner Mechanics Corner - Engines, Transmission & More... 19 02-08-2010 10:05 PM
Help!! Engine Won't Start!! eraffety Mechanics Corner - Engines, Transmission & More... 41 07-05-2006 07:01 PM
454 engine questions Curtis-79MH Mechanics Corner - Engines, Transmission & More... 10 10-06-2003 06:22 AM
Engine Monitoring, gauges etc. thenewkid64 Mechanics Corner - Engines, Transmission & More... 1 07-25-2002 02:25 PM
