Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 06-14-2004, 11:21 AM   #1
swebster
RivetAddict
swebster's Avatar
Profile:  Louisville , Kentucky
Is House Wiring the same as Automotive Wiring?
I'm getting ready to replace some wiring on the Chassis. Primarily to repair the wire I burnt on the last trip and to relocate the my "extra" relay from an alternator bracket extension to the chassis to remove it from the vibrations it gets on the engine (I've stress cracked the mounts on four of these things so far).
My question is: what are the differences between wiring sold at auto stores and wiring sold at Home Depot. The Home Depot wire is much cheaper but can it handle the heat found under the dohouse?
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
View My ThisOldRV.com Personal Page
ThisOldRV.com
swebster is offline   Reply With Quote
Old 06-14-2004, 11:27 AM   #2
74Argosy24MH
Profile:  LOST , Hawaii
Along with the heat I question if the insulation will handle the oil and other chemicals it will contact (I am assuming you are talking about using stranded wire from HD).
John
74Argosy24MH is offline   Reply With Quote
Old 06-14-2004, 11:33 AM   #3
swebster
RivetAddict
swebster's Avatar
John - yes. Home Depot from the rack.
Steven Webster
AIR 1760
ThisOldRV.com
Old 06-14-2004, 12:05 PM   #4
Tripp
Profile:
Images: 55
Steven,
I think John is right about the chemical and heat resistance for the wire. You might find the manufacturer name and search their website though? You never know, it might all be the same stuff from the same place!
Let us know your findings! I'll be starting a frame off on my 56 later this year and will be rewiring the entire trailer, so this is pertinent info.
Tripp
Tripp is offline   Reply With Quote
Old 06-14-2004, 12:06 PM   #5
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
if you get wire from home despot make sure it is type tthn or similar, it is gasoline and oil resistant.
stranded would be the best because of vibration.
john
you call them ferrets, i call them weasels.
Old 06-14-2004, 12:11 PM   #6
swebster
RivetAddict
swebster's Avatar
tthn stranded - got it! thanks!
Steven Webster
AIR 1760
ThisOldRV.com
Old 06-14-2004, 07:30 PM   #7
eubank
Lynn
Commercial Vendor
eubank's Avatar
Profile:  1967 30' Sovereign
Angel Fire , New Mexico
The color coding system is also different for house wiring and automotive.
Lynn
WBCCI 21043
Lynn's blogsite: http://forum.aardvarkrv.com/blog/
If you're WBCCI, come visit us at the park (and get more cool air and less oxygen and ... a 50% discount!)
Old 06-15-2004, 06:11 AM   #8
Over59
Over59's Avatar
Profile:  1959 26' Overlander
1968 17' Caravel
Images: 37
http://www.thomasregister.com/olc/72978943/wi03.htm
http://www.taihan.com/taihan_eng/pro...p?curMenu=wire
Let those who can play, let those who cann't rule.
Over59 is offline   Reply With Quote
Wiring Diagram 84 Excella 31ft dscluchfc Electrical - Systems, Generators, Batteries & Solar 2 01-03-2005 11:09 AM
MH stored at my house! 1985air345 Airstream Motorhome Forums 6 12-01-2003 08:33 AM
trailer wiring Cruiser Electrical - Systems, Generators, Batteries & Solar 4 09-02-2003 01:43 PM
Suburban tow package wiring question uwe On The Road... 9 08-29-2003 02:08 PM
TV Antenna wiring??? tenrsingr Audio, Video & TV 6 05-06-2002 02:16 PM
