My alternator crapped out on Bank Holiday Sunday in deepest Devon. I'll need a new one. I recall advice that we should shoot for a high output version, but can anyone confirm that this looks reasonable for my 1990 250 Classic?
Nick
I just wanted to pass along some experience about high output alternators in these old p30 chassis first off the 10si / 12si framed alternators can't she'd enough heat in the cramped doghouse at anything much above 100 amps and the stock wiring defenatly will not handle any output more than that anyways when I redid mine I went with 105amp low cut in alternator and I run 4 electric engine fans use the extra money to go led on the lighting and up the battery capasity. I did rework the charge line to 4G a . I changed all of my vehicle lighting as well as my boat trailer to led and I have had zero charging problems in 4 years now. I have 4 group 31 battery's on board and the bottom line to all this is much better boondocking capasity and good prep for solar for about the money just spent differently
Sent from my SPH-L900 using Airstream Forums mobile app
