Old 02-03-2006, 05:57 PM   #1
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Smile Here's your chance to spend someone else's money.
My 1984 310 Limited has 105,000 miles on it. In the two and a half years we have had it we have put 30,000 miles on it. We plan to keep it indefinitely. I just put $5,000 in the suspension. I don't mind spending money to improve the performance/ reliability if it seems to be good value. I know someday soon, the engine will require major repairs or fail entirely and I'll have to decide what to do.
The performance of the 454 with the Banks Power Pack is adequate but I wouldn't want to downgrade. I get 7.5 - 8 mpg while towing our Scion.
So my questions is what would you recommend as the most cost effective solution to providing the motive force for the Silver Slug for the next 100, 000 miles?
I have thought of three broad options:
1. Retain 454 power plant - rebuilt, or re- manufactured, or a new crate engine, or ...
Perhaps add gear vendors overdrive unit, Electronic Ignition, TBI, built up transmission...
2. Stuff a newer generation gas engine/transmission ems, etc. in
3. Some sort of diesel option
I dislike the noise and smell of diesels but if I can get 40% lower fuel costs and 100,000 miles of service, it might be worth it.
Some assumptions:
The days when I was willing to do an engine swap myself have long past so I will be paying someone to do this work
Reliability is my greatest concern, next would be economy although I wouldn't want to see fuel economy go down.
So please respond with ideas (including sources and approximate costs if you happen to know)
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 02-03-2006, 06:34 PM   #2
_
guy99
what did you do with the suspension...me likey upgrades....
if the engine was about to crap out and the tranny was going at the same time......it would be easier to suggest a couple of drivetrain options and just do the whole thing....
more likely the tranny will need work before the engine, since you have a toad...
how many miles per year of travel....getting to the next 100k?
the newer diesels are smell less and are quieter...but not with that dogcage....
that's still the p-30 chassis right..... for easy of fitting, go for the gm crate/new tranny/rear end and do the banks upgrade again....and do a brake upgrade as well.
i don't think you will recoup the cost of a custom diesel setup with better mpg...and current fuel prices...
cheers
2air'
Old 02-03-2006, 07:09 PM   #3
Tinsel Loaf's Avatar
With a new diesel engine and drive train with a gear vendors overdrive unit
you would save on fuel and with proper maintenance you would achieve 300,000 to 500,000 miles. Would cost about $ 15 to 18 thousand installed.
Tinsel Loaf is offline   Reply With Quote
Old 02-03-2006, 07:14 PM   #4
guy99's Avatar
Images: 16
I'll have to break out my recipe to give a detailed list but I took out the airbags in front and went with super steer springs, new steering gear, steering coupler, Koni shocks in back (I have bilsteins in front), I already have super steer bellcranks, there were a few other suspension components that needed to be replaced.
Yes it is a P30. I'm figuring 10-12,000 miles per year. A back of the envelope calculation says that if a diesel cut fuel costs by 40%, that would $12,500 saving in fuel cost. Would a diesel setup really cost as much as $12,500 plus a gas engine or two with installation?
Old 02-03-2006, 07:48 PM   #5
guy99's Avatar
Images: 16
Tinsel,
What engine/transmission combination are you suggesting?
Old 02-04-2006, 08:34 AM   #6
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
[quote=guy99]3. Some sort of diesel option
I dislike the noise and smell of diesels but if I can get 40% lower fuel costs and 100,000 miles of service, it might be worth it."
I stand on my soap box again as a loud supporter of the "new" diesel engines. First my old diesel was loud and smelly, the exhaust was black and nauseous. I agree with you that it is not a pretty thing. BUT there have been major improvements and my new diesel is a dream. You would not know I had a diesel engine unless I told you. It is as quiet or even more quiet than the standard 345. There is little to no odor from the exhaust and rarely do I get a shot of black smoke. I can sneak out of campgrounds in the early AM with no one knowing I am leaving. I can warm up my engine with out waking even my closest neighbor. Inside the coach we can carry on a conversation at normal volumes and even have people from the back seats join in. I play classical music on my stereo and hear all the parts. Shall I go on? Truthfully, I get more road noise than engine noise now that I made the engine swap. This spring I will be working on how to lower some of that road noise.
The draw backs to the diesel is power and the present cost of diesel fuel. However my engine is set to run on Bio- Diesel, it has all synthetic fuel lines and i use it when I can get it. The power issue is not a problem for me since I drive slowly regardless of what i am driving. My son on the other hand was a nervous wreck not being able to maintain a 65 to 70 MPH speed. I am happy at 55! I also think our coaches are safer at that speed. I have plenty of torque and can maintain that speed on any incline so I always drive a steady speed. In fact once I set the cruise control I rarely touch a pedal for miles.
You might guess that my vote is for the diesel. It will be expensive, mine cost $20,000 but it will last forever. Service is better than a gasser in that there is no tune ups and recommended oil changes are 10,000 miles and they mean it. A trucker told me he would be a fool to change his oil every 3000 miles and he had 500,000 on his engine!
Good luck with your decision, anyway you choose I am happy to hear you are keeping your classic. I could not imagine life with out mine.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 02-04-2006, 05:26 PM   #7
_
chaplain kent
i agree the newer sludge burners are much nicer/quieter/cleaner and so on..
and all that torque would sure help.
very much enjoying the superduty psd....
can you describe your upgrade and how hard was the fitting.
pricey?
sure but if it's what you wanted and done right......worth every penny.
i'd sure like to see/read about your upgrades...
cheers
2air'
Old 02-04-2006, 06:52 PM   #8
Diesel engines are different because of the many choices you have for your application. In doing your homework you need to look at the amount of power and torque you want compared to the compatibility of the engine compartment and drive train mounting and room. Anything can be done, but keeping it simple is best. When looking for an engine select a turbo charged model. Find a manufacturer that has a well time tested engine on the road. Go to a motorhome diesel engine rebuild shop and talk to a ‘certified mechanic’ that specializes in rebuilding motorhome diesel engines. Don’t talk to the service writer they usually have been out of the (hands on) aspect of repair and rebuild to long. Talk to a older seasoned mechanic, one that has worked on the newer style electronic diesels. There is a huge difference between the old crackle of everything mechanical and today’s electronic timing of cams, injectors and sensors that keep diesels quiet and clean burning. Check the history of recent diesel reliability in motor homes journals and by surfing the web in motorhome forums. You can find a lot of third party dealers that sell after market products and some (just a few) really know what they’re talking about. But you must whittle down your possibilities to about two. Remember a bigger engine is not necessarily a better engine. Sounds like Chaplain Kent has already been through the search, what and where did he get his. You have a lot of reading in your future, not to mention fingernail biting. Wish I could help more but I must be there and see what limitations, if any there are. Ask questions. Good luck. This reminds me that I must go change my fuel filter.
Old 02-04-2006, 07:31 PM   #9
guy99's Avatar
Images: 16
Chaplain Kent,
When are you going to head out my way so you can take me on a test ride?
Or, we were in Wisconsin summer of 05, maybe we'll get that way again.
Guy
Old 02-04-2006, 09:39 PM   #10
Steve Heywood's Avatar
1997 30' Excella
Waddell , Arizona
Images: 13
If I were you I'd go with a GM Performance Products 502 crate motor sold as a replacement for the 454 used in trucks (320 HP-515 lb ft Torque). I'd resue the Banks headers, stock ignition, & carb but replace your stock cast iron intake manifold with an Edelbrock Performer aluminum intake. I think you'd net nearly 350 HP and end up with an engine that wouldn't work near as hard as a 454.
As for the transmission you have to decide where to most effectively spend your money. A gear Vendors OD will net you increased mileage and power in the mountains but will never come close to paying for itself. A wide ratio gearset (2.75:1 1st gear) would increase low-end punch.
Steve Heywood
Waddell, AZ
1999 19' Bambi (SOLD)
1997 30' Excella (SOLD)
Steve Heywood is offline   Reply With Quote
Old 02-05-2006, 07:26 AM   #11
1994 30' Excella
As some of you are aware my engine swap was not planned but the cause of a mechanic using the wrong oil filter on my old engine. I am a chaplain trained and educated in things not mechanical and can only say God was with me when Chummy was towed into Standard Truck on the south side of Chicago. This is one of the largest truck dealers in the country. My mechanic was a young man who grandparents owned an Airstream! he fully understood what this motor home meant to me. He began to rattle off numbers and statistics, turbo ratings and injector sizes. He mentioned several manufacturers, including Cummings and recommended I stay with Isuzu for the most advanced engine on the market today. Once again I was towed in here and had little time to prepare and my knowledge was scant to say the least. But I looked around at hundreds of trucks to be repaired and a mechanic who was certified in everything except making ham sandwiches and decided faith is my best guide and put my trust in Charley. I am not sorry. As for the cost the insurance company paid all but $2000.00. My original engine had 60,000 miles on it and was depreciated 20% and if that does not speak for an Isuzu I do not know what would. I can not say how hard it was to swap out other than Charley patted me on the back and told me he would take care of everything and I was not to worry. The job took 8 weeks and that included sending to Japan for an engine. If you take off the dog house in my coach everything is new right down to the hoses and wires. Charley even put on a block heater as a special present for me since we like to winter camp.
Now for you Cummings lovers out there when I picked Chummy up I had my choice of hats and did choose a Cummings hat. They are really cool but for our application I would stick with an Isuzu engine..
Chaplain Kent
Old 02-09-2006, 07:38 PM   #12
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Guy,
I'm facing the same decision in the coming years. I "suspect" there are about 40,000 miles on my engine (454). I baby it and love it and fanatically monitor it because I want to extract as many miles as possible from it. Like I do compression checks at every oil change – I know – it’s a problem.
However the time will come when it's given me all it had and I'll have to replace it.
My coach however recently turned 195,000 miles and is now 20 years old. We've invested a small amount (< $4500) on repairing/improving the drive train, chassis, suspension, exhaust and engine accessories to date. I bought the coach right and we're investing more each season by updating the interior and systems to make this coach ready to serve our family for another 20 years.
We also use it a lot; we're young (late thirties) and we and plan to keep it as long as we can. (A recent trip to the RV Show confirmed for me I don't really need four slide outs). I can also see a day when my children might use it for their families – after all it is an Airstream right?
Chaplain Kent hit on another attraction for us; alternative fuels. I don’t like the volume of refined gasoline that goes into my tank. Bio Diesel, SVO, future fuels – all seem more realistic and cost competitive every year. Will there be a time when I can fill up with SVO? Well….there already is here in Louisville. Should I be planning for future fuels? Not sure, but it’s in the back of my mind when I think about this decision. Honestly, for me I think it’s about having choices in fuels. That seems like a smart idea to me.
So, I believe the diesel powered coach is the way to go.
You do need to consider that you have very limited options given the weight constraints on the P30. Cummins/Allison is a proven performer but it's heavy. (Of course there was a factory 345 with this setup for sale recently). There are also other GM options that came in the P30 (delivery van) like a turbo'd 6.2 rebuild from a donor - more of a shade tree project but kind of appealing (http://www.airforums.com/forums/f159/6-2-turbo-diesel-conversion-anyone-19271.html).
And then there is the ISUZU power plant, which Chaplain Kent and Cooperhawk have had terrific personal experience with and Airstream used on their MoHo's from the factory. It’s proven, they have service centers everywhere, parts or readily available, there are a lot of mechanics who know these engines and there is a large public knowledgebase available through books and websites about them.
I think something that's often overlooked when considering a diesel conversion is that an Airstream Moho, if properly maintained, baring any collisions should outlast three or four gas power plants. I say that because I can easily see my coach (on it’s second or possibly third engine) going another 200K miles. So if you figure $10K for a gasser R&R per pop X 4, then an ISUZU replacement should be roughly 60% - 70% of the cost for replacement over the life of the vehicle.
Of course, you will have to deal with transmissions, fuel systems conversions, cooling, generator conversion (LP?), engine mounts and about a million other things.
But I figure, if you're going to keep the coach forever and pass it down to your family then gasser replacements over the years may cost you less per replacement, but more in the long run - gas mileage aside.
OK...my flame suit is on. Fire away!
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 02-12-2006, 03:17 PM   #13
1991 35' Airstream 350
Windsor , North Carolina
Rivet Diesel Replacement Matrix
Taking my cue from SWebster (we haven't met, but thanks very much!!) I have begun to pull together a matrix on a spreadsheet about diesel and other engine replacements, to be posted on the Forum occasionally or sent directly to interested parties.
I am limiting it to Airstream and Argosy Class A's, simply because my time and knowledge is limited, and I haven't pulled a trailer in many years. I will be home for the next month recouperating from back surgery, and this seems a reasonable way to effectively use some of that time away from work.
My search of the forums appears to be a bit hit--or--miss, and I do not always catch useful information buried in obscure threads. I don't know why. In order to be as thorough as possible, I need forum members and moderators to direct me to forum information about repowering AS or Argosy Class A MH's which have ACTUALLY BEEN ACCOMPLISHED with diesel or other engines and transmissions (new or used) over the last, say, 10 years. Information about aftermarket ancillary stuff (cruise control, over/underdrives, etc.) will be included if provided.
My goal is to be able to provide the forum with a matrix of what has been done and by whom, boiling down the options ( and speculation) to what is actually accomplished, possible, cost effective (more or less), efficient, and dare I say--fun?
I would prefer folks contact me either privately by email or publically through the forum. Phone calls invariably catch me without paper, pencil, or brain.
Rob Alley
1991 AS 350
ralley is offline   Reply With Quote
Old 02-12-2006, 07:01 PM   #14
guy99's Avatar
Images: 16
Rob,
Sounds like a very useful project, I look forward to what you find.
Steven,
Like you I am concerned about the amount of fuel which my gasser drinks and the attendant pollutants. We still use less gas per year than we did when we were working and commuting but still... I guess one question which I would love to have the answer to is whether diesels are really better environmentally I know that the particulates they spew are very bad. But perhaps the new motors are better?
On the cost side, it seems clear that if you are going to put enough miles on the rig the greater fuel economy will eventually compensate for the higher initial cost. But what about repair costs, it seems that diesels are not trouble free and parts and repairs seem to be quite a bit more expensive. Then you also need to consider the costs if you have a early demise of a diesel such as Chaplain Kent and at least one other contributor to the forum has experienced. There is no guarantee that a failure will be someone else's fault or that repair costs would be paid by a third party as was the case for Chaplain Kent.
If a mistake or bad luck causes the replacement of a gas engine, its a $4,000 bummer, if its a diesel its a $14,000-20,000 bummer.
We all hear about diesels going 300,000 miles. But I wonder if we really hear about all the times they don't go that far.
I read a couple of diesel RV forums or lists and there seem to be a lot of very expensive repairs even in the cases where you are not looking at an engine replacement.
What we need is some good TCO data.
Another consideration for me is that I'm not willing to take this on myself so I will need to hire someone to do the job. I have no idea how to find someone who can give me a good up front idea of total costs including instruments, and converting the generator, etc.
Having said all of this, I'd still like to find a practical way to achieve good reliability, durability, and economy.
Ideas?
How much will you spend this year? Andy R Community Polls 76 02-01-2009 08:22 AM
Best battery charger for the money? Andy R Electrical - Systems, Generators, Batteries & Solar 27 10-01-2007 07:46 PM
Airstream vs. ??? DnnRe8 Our Community 33 10-08-2004 09:15 AM
Help!! Refrigerator Access Door Needed! Melissa Hamilton Exterior Storage Compartments & Access Doors 13 01-19-2004 04:03 PM
Chance MH Meeting... ViewRVs Airstream Motorhome Forums 1 09-24-2002 08:41 AM
