Old 08-19-2015, 01:20 PM   #29
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
If you bought a computer controlled transmission, you will need a wiring harness and processor to make it work, a lot of expense and trouble.
88 was around the transition time to electronic controls. If the transmission is a THM 400 it is NOT computer controlled, if it is a four speed OD, I don't know if it needs a computer or not.
Old 08-19-2015, 01:26 PM   #30
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
If the 88 transmission is from a 3/4 tom Suburban you SHOULD be good.
It should be a THM 400, and therefore not electronically shifted.
Old 08-20-2015, 07:47 AM   #31
I had an '87 and a '90 3/4t Suburbans.... Both had TH400.
Old 08-30-2015, 12:16 AM   #32
german6563's Avatar
1977 24' Argosy 24
Hilden , NRW
Hello everyone
I want to thank all the support I have been given here.
It was difficult but not impossible to buy the correct transmission yesterday for my RV, so now get to work to place and to make the first ride
Herman
german6563 is offline   Reply With Quote
Old 08-30-2015, 10:56 PM   #33
Grosspoluter's Avatar
Franklin Park , Illinois
I to would like to thank everyone here for the advice and insights
I have since had the uncracked trans rebuilt by Aamco
This picticular shop had a lot of good reviews, I know everything YA here on the Internet isn't nessarly true, but also at some point you have to trust someone.
After the rebuild I took the rebuild and the 345 to a truck and RV shop in rockford illinois (where the 345 is stored) it is now in the shop having the transmission switched out, if the repair is good I'll feel a LOT better about taking trips in the 345.... Of course I'm now reading the thread about tag axles and have new things to worry about
Grosspoluter is offline   Reply With Quote
Old 09-08-2015, 11:08 AM   #34
german6563's Avatar
1977 24' Argosy 24
Hilden , NRW
Hello people
the transmission is placed, and now want to put an extra cooler,
Now I need your help once again
My idea is to put the cooler after the original cooler means, transmission, original cooler and after the extra cooler.
transmission now come two pipes one up and one down, which is the output of which is the oil that returns from the cooler to the transmission?
Thank you
Herman
Old 09-08-2015, 04:09 PM   #35
Originally Posted by german6563 View Post
Hello people
Thank you
Herman
Herman, that is a wise choice.
The UPPER cooler line is the return, and the LOWER is the feed.
TH400
Fitting Location..... Thread Size..... Flow Direction
Upper
.................... " Pipe............. Return/in
Lower..................... " Pipe............. Cooler feed/out
Old 09-16-2015, 11:32 AM   #36
german6563's Avatar
1977 24' Argosy 24
Hilden , NRW
Hello
Keyair thanks for your help, it helped me a lot.
Now I need help I think the last, someone has a diagram from the shifter to the transmission, is that when disarmament I now can not remember how it goes connected to the transmission,
I try to connect but I saw that there are two positions and which is not the correct .I look on google, but unfortunately nothing
Thank you
Herman
PS I just need to make that connection and can give the first lap with my RV
Old 09-16-2015, 04:56 PM   #37
This might help...
Old 09-19-2015, 11:07 AM   #38
german6563's Avatar
1977 24' Argosy 24
Hilden , NRW
hello Keyair
Thanks for the picture, helped me a lot, of course already placed
again thank you very much
Herman
Help...transmission cooler mandolindave Tow Vehicles 8 09-12-2013 01:27 PM
Help - Transmission Rear Seal Part No? swebster Mechanics Corner - Engines, Transmission & More... 8 02-29-2004 02:49 PM
Allison auto transmission O/D lockout davidz71 Tow Vehicles 0 01-20-2003 10:28 AM
Transmission questions jcanavera On The Road... 6 08-13-2002 09:36 AM
Transmission repairs rdm Mechanics Corner - Engines, Transmission & More... 0 05-12-2002 08:51 AM
