Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 10-20-2003, 08:22 PM   #1
swebster
RivetAddict
swebster's Avatar
Profile:  Louisville , Kentucky
Exclamation HELP - Poor Pedal Pressure
Replaced the master cylinder today. On the last trip to MS I lost almost a half pint out of the old girl. Figured its time to make that old one a core return.
Put the new one on today, bench bled it, mounted it, and bled the lines (RR, LR, RF, LF) got out all the little bubbles). But – I still don't have decent pedal pressure. Any ideas? Should I buy/rent that brake bleeding tool? Anyone done this before?
Of course I leave tomorrow for a 2000 mile trip. Why do I decide to do this stuff? I know – because it’s a quest to make everything better and it was only 50 bucks at NAPA. It was calling to me, taunting me, come on you can do it you can replace me right before you head out…I dare you!
Seriously, I’m pretty hosed if I don’t get this corrected ASAP.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
View My ThisOldRV.com Personal Page
ThisOldRV.com
swebster is offline   Reply With Quote
Old 10-20-2003, 08:30 PM   #2
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Steven,
How do the flex hoses from the frame to the calipers and rear axle look. These tend to get soft and will expand instead of pushing against the wheel cylinder. If they are original I would start there. It will require a re-bleed so it may be worth the new tool. This has been an issue on a few of my 10 year old cars.
I assume this pedal pressure is at rest with the engine running. I found that the age of the power steering fluid seems to have some effect too.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 10-20-2003, 08:34 PM   #3
74Argosy24MH
Profile:  LOST , Hawaii
A pressure bleeder is calling you, or a vacuum bleeder if you have a helper.
I don't think you could get all the air out with the master cylinder. When the brake lines go inside the cross members they go up for clearance and that is where the air stays. There just isn't enough displacement in the master cylinder to move it through so big a system.
Buy me, rent me.
John
74Argosy24MH is offline   Reply With Quote
Old 10-20-2003, 09:30 PM   #4
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
soon to be , on the move again
Images: 58
Steven, do you mean it takes too much effort to mash the brake pedal to make the coach stop? Or is the pedal all the way to the floor, and you are still rolling?
To make sure you get all the air out of the master cylinder, you have to bench bleed it. That is, you have to fill the thing with brake fluid, and put those plastic caps on the outlets, and the rubber hoses on them, and run the hoses up into the reservoir, making sure the ends of the hoses are submerged. Then, push the plunger in the end of the master cylinder until no more air bubbles come out. Then install (or re-install) the Master cylinder, and bleed the rest of the system like you described.
If it takes too much effort to push the pedal, you could have a bad booster. If it is a hydro-boost type, running from the power steering, check and make sure the power steering pump is full of fluid. If you have the old vacuum type booster, check to make sure the vacuum hose is connected to the booster.
Good luck, and happy motor-homing!
Change is inevitable, except from a vending machine
AIR#2611
Old 10-21-2003, 07:19 AM   #5
swebster
RivetAddict
swebster's Avatar
Thanks for all the replies. Just to answer everyone's questions:
1. Pedal goes to the floor with little resistance both engine on and off
2. Before I replaced the cyl it had decent pressure about 2" into the pedal
3. Vac pump is working (or was)
4. You can "pump up" pressure with multiple strokes.
5. The brakes worked well before the replacement...good pressure, good stopping, minimal pedal effort.
6. New front calipers and flex lines, checked the rears when replacing the shocks and the "looked" fine but since things work before I don't think its the rear lines.
I'm beginning to think I did not bench bleed the cylinder correctly. Getting no air bubble from each caliper but way to soft on the pedal. Must have air trapped somewhere in there.
Going to NAPA/AutoZone to get the tool today. I'll keep you posted
Steven
Steven Webster
AIR 1760
ThisOldRV.com
Old 10-21-2003, 07:21 AM   #6
PeterH-79MH
PeterH-79MH's Avatar
Profile:
Images: 63
I think you just need to do some more bleeding.
Its best to have three people on hand to do the manual bleeding. Pumper, filler and bleeder.
Using the air pressured bleeding machine still is best accomplished with 2 people. Filler and operator.
I assume you very carefully compared the two master cylinders and took great care in proper seating?
Be nice to yourself and put a quality pair of vicegrips on the line mounting nuts at the master and give it the extra torque. If you want to know why, ask me why I purchased some good vicegrips in Taos, NM after descending from a 9k pass.
Once you figure out how to do it,
the instructions actually make sense.
_____________________________________
WBCCI Member at Large
PeterH-79MH is offline   Reply With Quote
Old 10-21-2003, 07:44 AM   #7
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
GM often is problematic to bleed. Many times it's air trapped in the proportioning valve(PV). Find the PV and see how it's mounted. The rear circuit seems to be very prone to trapping air. Th inlet from the master cylinder is on the top and the outpout is on the low end on most GM PV's.
WHat I have found that helps is to make sure the master is full of fluid. Loosen the inlet lines on the PV till it leaks at a pretty good rate. Tap the PV with a wrench as it's leaking. The master will gravity bleed so no air will work back up to it. Tapping the PV will cause the air to dislodge and hopefully come out with the fluid. Retighten the line and try breeding again.
ANother thing to look at is how the lies are routed. The RR-LF Bleed sequence may not work well. One of the front outlets is higher then the other. On my GM trucks that is the Left front. Logic tells you that air rises to the top in fluid. Logic would be bleed the top line first to get the air out fastest. On my GM truck Bleed rear first (side doesn't matter because on mine it's a single line back that "T's" on the axle. Bleed the Left front then the right front.
The master HAS to have rear pressure to get the front to bleed out. The piston for the rear has mechanical connection to the peddle but when properly bleed the master traps fluid between the rear piston and the front piston. That fluid is what actually pushes the front piston. Now if the rear circuit does loose pressure the rear piston will botom out against the front piston but the peddle travel will be excessive.
I have had mixed luck with the Suction bleed kits you can pick up. If the system is fairly air free they work but if Air is in the PV it will suck the PV shut.
My method is to try to gravity bleed the system first. Simlyp open the bleed valves and let the fluid drain. for a couple minutes eache wheel. I usualy try to both rears at the same time because of the T at the axle. Then I trymy suction bleed if that has failed to work alone. Then I grab my wife or my 11 year old and do the pump method.
A pro mechanic friend of mine has a trick he swears by on stuborn systems. He has some junk yard master cyl caps he has put some fittings on. This allows him to put a slight pressure and force fluid through the system (10psi max 3-4 is usualy enough). THis allows him to by himself go around and open each bleed valve to perge the air. He has also had luck by putting a slight vacuum (about 10HG) on the sytem to draw the air that may be trapped in high spots back up to the master. Usualy leaves it under a vacuum state for 2-3 hours.
I haven't tried either method but both make sense. I have used Vac tricks in the printing buisness to remove air bubles from inks and casting resins we had to do for parts. Works well in that application and seems like it should work for this application.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 10-21-2003, 10:54 AM   #8
74Argosy24MH
Too big of a system to let gravity suck the air out. There is probably 25 ft. of line to the rear axle. Every crossmember has an offset up for clearance. The air is going to get into these offsets and stay. Your mechanic buddy is using a pressure bleeder, that is the best way to bleed any brake system. Once the mc is bled it forces the air from the system, start to finish and flushes the old fluid out.
John
Old 10-21-2003, 11:22 AM   #9
swebster
RivetAddict
swebster's Avatar
Talked to the service manager at AC Brake here in town (commerical truck brake shop)....said that I should not need to pressure bleed a GM P30 Chassis. Suggested gravitity bleading the front circuit for 30 minutes...then bleeding each caliper again.
Getting ready to try it along with all the other good forum tips so far.
Steven Webster
AIR 1760
ThisOldRV.com
Old 10-28-2003, 03:35 PM   #10
swebster
RivetAddict
swebster's Avatar
Finally back
OK...Just got back from a trip to NE. The gravity bit worked great. Had to really stomp on the brakes in NY when a driver pulled out in front of me...no problems and no more leaks.
Thanks to all for the tips.
Steven Webster
AIR 1760
ThisOldRV.com
Old 10-28-2003, 06:13 PM   #11
87MH
87MH's Avatar
Profile:  1978 31' Sovereign
Katy (West Planet Houston) , Texas
Images: 143
Stomping down
Great - Gives me something to look forward to.
Who knows how long the brake fluid has been in the Xilver Xeppelin, and I do not feel real comfortable with the 18 year old rubber hoses connecting everything.
One of the close proximity projects will be to replace the flexible parts of the brake system, inspect everything one more time, and ensure that the fluid is properly changed.
I was reviewing the old threads on trailer brakes, and learned a lot about the system on the tag axel.
Dennis
WBCCI # 1113
AirForums #1737
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 12:31 PM
No oil pressure! Stefrobrts Towing, Tow Vehicles & Hitches 3 11-06-2003 08:47 PM
Tire Problem? Pressure Question montanaandy Tires 1 04-22-2003 08:56 PM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 07:12 AM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
