Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Prev Previous Post   Next Post Next
Old 11-07-2009, 09:31 PM   #40
PLDodd's Avatar
Profile:  1975 Argosy 26
Portsmouth , Virginia
when the brakes lock up, loosen the master cylinder mounting bolts instead of releasing the fluid at the caliper. If this releases the brakes, adjust the brake booster pushrod. On gm p30 chassis there are about 10 different master cylinders that look almost the same and will bolt up so it could easliy be the wrong one.
PLDodd is offline   Reply With Quote
Grabbing Brakes 74Tradewind Brakes & Brake Controllers 15 08-05-2004 06:26 PM
Intermittant Brakes dinoburb Brakes & Brake Controllers 4 11-12-2003 09:00 AM
Tag Axle Brakes cooperhawk General Motorhome Topics 1 06-23-2003 01:48 PM
Trailer brakes won't lock-up? John Brakes & Brake Controllers 24 02-06-2003 01:22 PM
Heeeelp! My brakes have failed...any one had a similar experience? williamhenshall Airstream Motorhome Forums 9 07-12-2002 04:04 PM
