Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 10-20-2004, 12:46 PM   #15
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
Spoke to Dennis last night and they are enjoying themselves in spite of a harrowing trip from Texas to Georgia. He is going to make the adjustments and check it out.
On the way to see Ruby Falls when we spoke.
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
Old 10-20-2004, 02:40 PM   #16
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
PM received
Steven, I tried to PM you several days ago when you contacted me about Dennis' brake problem. I got a message you had too many PMs, and could not receive it.
My advice was the same as some others, MC pushrod, and MC.
Let me know what the outcome is.
BTW, I just tried to PM you again, with the same result.
Change is inevitable, except from a vending machine
AIR#2611
Old 10-20-2004, 03:21 PM   #17
swebster
RivetAddict
swebster's Avatar
Profile:  Louisville , Kentucky
Boy do those PM's add up! Thanks for the info Terry - cleared my PM's
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
View My ThisOldRV.com Personal Page
ThisOldRV.com
swebster is offline   Reply With Quote
Old 10-20-2004, 04:31 PM   #18
mcneon
mcneon's Avatar
Profile:
I've just checked the service manual for my '74 P30 chassis. If the '87 uses the Hydro-Boost brake booster as mine does, it appears that MC pushrod adjustment isn't the problem. The pushrod (on the P30) gets set to 9.9" eye-to-eye length, but that's it. There is no brake pedal stop; the MC rest position is set only by the MC itself and the booster it's attached to.
It's possible that something under the dash may be interfering with the pedal, but I doubt it. More likely to me is a problem with the MC itself or its attachment to the booster. I realized that the GMCs I mentioned in a recent posting use a conventional vacuum booster; the hardware and installation are completely different from the Hydro-Boost systems.
mcneon is offline   Reply With Quote
Old 10-25-2004, 06:26 AM   #19
swebster
RivetAddict
swebster's Avatar
Another update. Dennis ended up putting on a different (US Made) MC and he thinks this solved his problem. He told me when he put the recently replaced MC next to the new one the sizes were different.
I'm sure he'll post more about this when he gets back home in a few days. Again, he passes along his thanks for all of the advice.
PS - if anyone ever gets the chance to check out his rig I highly recommend it. I wasn't sure which was more impressive; the perfectly clean (almost new) undercarriage or the bose suround sound system with the big flat panel LCD TV. Certainly shows what can be done with these old rigs!
Steven Webster
AIR 1760
ThisOldRV.com
Old 10-27-2004, 04:43 PM   #20
87MH
87MH's Avatar
Profile:  1978 31' Sovereign
Katy (West Planet Houston) , Texas
Images: 144
Many thanks for all replies, calls, and PM's!!
Thanks to everyone for your replies!!!
The problem turned out to be the "new" Master Cylinder ($50 foreign made from O'Reilly's) that was pre-loading on it's own.
When I took off the "new" (O'Reilly's) MC I could detect no adjustment points for the Hydroboost to MC push-rod, so I proceeded with the Master Cylinder replacement. The first one, picked up from NAPA in Trenton, GA (10 miles from Cloudland Canyon) was the wrong size. Jim Mickle (JCMickle here on the forum - retired GM) graciously picked it up for me on his supply trip to town ($50, rebuilt). I brought the unused "rebuild" back, and the only one in stock to fit the unit was a $150 "new" (not GM) unit.
You gotta' do what you gotta' do.
A couple of quarts of Synth Blend DOT 3/4 brake fluid later - and I'm ready for the road.
Thanks to all to all who helped at the Ralley.
BTW, I recently purchased a full set of Chevy/GM manuals off of e-bay
ST-330-86 10-30 Series Shop Manual
ST-330-86 WD 10-30 Series Shop Manual Wiring Diagram
ST-333-86 10-30 Series Unit Repair Manual
Picked all 3 up on one sale - PM me if anyone needs a page cut.
The manuals confirmed that no adjustment is possible on the push rod.
It is also painfully obvious that I do not want to do an overhaul to the Hydro-Boost unit - Way too many seals and tight fits - as with the master cylinder - a new or rebuilt unit will be purchased when it's time has come.
One more system (hopefully) fixed for a while.
Dennis
WBCCI # 1113
AirForums #1737
Old 12-24-2004, 10:00 PM   #21
Astrodokk
Astrodokk's Avatar
Profile:  Santa Rosa , California
Guess what? My hydro-boost gave up...it was bone dry from several leaks apparently from 4 different high pressure fittings. The dealer has to have them manufactured cuz they can't find replacements for the fittings. The hydro-boost shares it's job with the power steering too. Both brakes and steering went south, so I had to scrap my Christmas trip to Seattle. Here I sit broken hearted reading emails.
1981 Excella 454 28', rear bath, twin beds.
Astrodokk is offline   Reply With Quote
Old 12-25-2004, 05:55 AM   #22
overlander63
Images: 58
Was it the Hydroboost unit itself, or the fittings on the hoses that go to it? If it is the hoses, it will be a fairly straightforward repair, although nothing you could get done on Christmas day. At least you are safe at home with this problem, and it can be fixed.
Merry Christmas.
AIR#2611
Old 12-25-2004, 07:00 AM   #23
ALANSD
Unfortunate news! But then at least it did not happen many miles from home.
Hope you will have a merry christmas.
My Music Site:
Old 12-26-2004, 04:59 PM   #24
livexl
livexl's Avatar
Profile:  Huntington Beach , California
hydro-booster
When my hydro-booster went out i replaced it with a new one from Workhorse Chasis. Good Luck ...
http://www.workhorse.com/
livexl is offline   Reply With Quote
Old 12-26-2004, 05:46 PM   #25
74Argosy24MH
Profile:  LOST , Hawaii
Was it the hydroboost or the pump that went out? I would think the pump would burn up running dry before the hydroboost.
John
74Argosy24MH is offline   Reply With Quote
Grabbing Brakes 74Tradewind Brakes & Brake Controllers 15 08-05-2004 05:26 PM
Intermittant Brakes dinoburb Brakes & Brake Controllers 4 11-12-2003 08:00 AM
Tag Axle Brakes cooperhawk General Motorhome Topics 1 06-23-2003 12:48 PM
Trailer brakes won't lock-up? John Brakes & Brake Controllers 24 02-06-2003 12:22 PM
Heeeelp! My brakes have failed...any one had a similar experience? williamhenshall Airstream Motorhome Forums 9 07-12-2002 03:04 PM
