12-24-2004, 10:00 PM
#21
Seattle
, WA
Guess what? My hydro-boost gave up...it was bone dry from several leaks apparently from 4 different high pressure fittings. The dealer has to have them manufactured cuz they can't find replacements for the fittings. The hydro-boost shares it's job with the power steering too. Both brakes and steering went south, so I had to scrap my Christmas trip to Seattle. Here I sit broken hearted reading emails.
2000 Ford E-350 Super Duty 418ci/6.8L Triton V10 21’ Chinook Concourse XL
12-25-2004, 05:55 AM
#22
Retired.
, At Large
Was it the Hydroboost unit itself, or the fittings on the hoses that go to it? If it is the hoses, it will be a fairly straightforward repair, although nothing you could get done on Christmas day. At least you are safe at home with this problem, and it can be fixed.
Merry Christmas.
12-25-2004, 07:00 AM
#23
1966 26' Overlander
Woodstock
, Georgia
Unfortunate news! But then at least it did not happen many miles from home.
Hope you will have a merry christmas.
12-26-2004, 04:59 PM
#24
1992 35' Airstream 350
Huntington Beach
hydro-booster
When my hydro-booster went out i replaced it with a new one from Workhorse Chasis. Good Luck ...
http://www.workhorse.com/
12-26-2004, 05:46 PM
#25
LOST
, Hawaii
Was it the hydroboost or the pump that went out? I would think the pump would burn up running dry before the hydroboost.
John
02-13-2009, 04:40 PM
#26
1978 31' Sovereign
Texas Airstream Harbor
, Zavalla, in the Deep East Texas Piney Woods on Lake Sam Rayburn
Originally Posted by mcneon
I've just checked the service manual for my '74 P30 chassis. If the '87 uses the Hydro-Boost brake booster as mine does, it appears that MC pushrod adjustment isn't the problem. The pushrod (on the P30) gets set to 9.9" eye-to-eye length, but that's it. There is no brake pedal stop; the MC rest position is set only by the MC itself and the booster it's attached to.
It's possible that something under the dash may be interfering with the pedal, but I doubt it. More likely to me is a problem with the MC itself or its attachment to the booster. I realized that the GMCs I mentioned in a recent posting use a conventional vacuum booster; the hardware and installation are completely different from the Hydro-Boost systems.
Many thanks to Bob (and everyone else) for helping me out all those years ago....it's hard to believe just how long ago it was.
I was remiss in following up with the REST of the story...I did have the "brake lock up" problem one more time - thanks to the info here on the forums (thanks again, Bob) I found that the pedal to hydroboost linkage was a bit too long - the set up was not allowing the brakes to release all of the way all of the time...
Backed off a couple of turns on the adjustment linkage and all was well...I shudder to think what a service call at a GM dealer would have run me on that one.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
04-10-2009, 02:21 PM
#27
Hypnotist
1982 28' Airstream 280
las vegas
, Nevada
Guys I had this problem when I first purchased my 82 280.. the master cylinder needs to be shimmed otherwise it will apply the brakes every time...
Trust me on this it cost me a new tranny as well
Justin
04-21-2009, 06:11 PM
#28
1982 31' Airstream310
Alpharetta
, Georgia
I just replaced my master cylinder to address a leak, and I was hoping my brake pedal would have improved. However, it remains the same. We flushed the fluid out when we replaced teh MC.
My pedal travels a long way before the brakes start to apply, then it still seems soft.
I will flush out the power steering fluid and check the pedal to hydroboost linkage to see if that helps.
What do your brake pedals feel like? Mine are not very confidence inspiring, but I want to make sure my expectations are set correctly.
What are the symptoms of a failing HydroBoost?
Paul
04-21-2009, 10:31 PM
#29
Hypnotist
las vegas
, Nevada
Paul I cant tell you exactly what a failing hydroboost feels like I can tell you that mine stops very well with everything replaced however make sure you shimmed that master cylender otherwise you will be driving down the road and the brakes will apply themselves without input... That is not fun..
Justin
04-21-2009, 11:00 PM
#30
Salem
, Oregon
Paul
Hi, a hydroboost won't have a hard pedal, especially while stopped. While driving will your vehicle stop like it should? If you don't have the correct Master Cylinder replacement, it won't work right. Many parts look the same or similar, but are different. If for example your new Master Cylinder has smaller bore/pistons than the original, you will have more travel to push the same amount of brake fluid. When a vacuum brake booster fails, it is very hard to stop the vehicle; When a Hydroboost fails, it is nearly impossible to push the pedal hard enough to barely slow down. [will feel like slideing on ice]
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
04-21-2009, 11:30 PM
#31
Alpharetta
, Georgia
The replacement was a Cardone rebuilt unit and had the same casting numbers and dimensions as the one I took off including the bore size. There were no shims on the one I took off or the one I put on.
Justin, what is the basis for the shimming and what dimensions are we trying to achieve?
It stops OK, but it does not have a confidence inspiring amount of pedal travel left, but that is what it was like before the master cylinder replacement.
Let me get the power steering flush and the pedal to hydoboost linkage checked first and then see what I get.
Paul
04-22-2009, 07:46 AM
#32
2011 34' Classic
Westchester Cty.NY
, / Miami FL
never mind. duplicate info.
Ricky
04-22-2009, 04:58 PM
#33
Richmond
, Kentucky
Paul,
Had the same sort of problem on our 84 310 after having the hydraboost and the master cylinder replaced at a big truck service shop. Took them a month to get it right. They replaced the mc twice and the booster 3 times before they finally realized the whole problem was air in the lines. They ended up buying a pressure bleeder to try and fix it and that still didn't get the job done. After finally trying it manually, with very slow pedal pushes and pumping about 4 gallons of fluid through the system they got the brakes to work right. The pedal now is very firm and probably goes halfway to the floor and stays firm even when stopped. I'm a lot more comfortable with the brakes now.
One other thing we had done was to replace all of the rubber hoses. After 25 years the old ones were just to brittle and I was worried about driving it until we got them replaced.
Hope this helps!
1975 24' Argosy Motor Home
05-26-2009, 06:45 PM
#34
Santa Cruz
I hope that folks are still reviewing this thread -- I have a similar problem with my 83 310, which like the 345 has disk brakes all around. It has a Mico Lever-Lock instead of a parking brake. I drove the rig home from Seattle, about 850 miles, a couple of months ago with no problems, using the Lever-Lock as a parking brake. It would apply and release properly each time.
The rear brakes started dragging. After a few miles they would lock up almost entirely (full throttle for 5 mph). Opening a bleeder, even after the rig was stopped for 30 minutes as I thought about what to try, resulted in a squirt of brake fluid - there was a lot of pressure still in the system. Everything OK for another few miles. Only the rear brakes were being applied (still hot while the fronts were cool).
We tried pulling both rear calipers. The slides were dry and a little rusty (we cleaned and lubricated anyway) but nothing too bad. The cylinders moved freely and retracted as they should.
MC is certainly a possibility. But why would it fail in this way just out of the blue? Maybe the booster? How would I tell?
05-26-2009, 07:27 PM
#35
Retired.
, At Large
It could be the master cylinder, or the brake hose to the rear axle has collapsed internally. It will let pressure in, but not back out. Tracking it down is easy, but messy. Apply and release the brakes several times, then crack the rear brake line line at the master cylinder. If there is pressure there, the master cylinder is likely the culprit. If there is no pressure (no squirting fluid), move to the rear brake hose, above the axle. Try the same thing there, crack the line and see if fluid squirts out. It's possible the little adjustable rod for the brake pedal/master cylinder needs to be adjusted inward a bit, but if no one has touched it, or the booster or master cylinder, it is unlikely.
05-26-2009, 07:35 PM
#36
1984 31' Airstream310
Ajo
What is a "Mico Lever-Lock"? I've never had brake problems, except on 10% grades where I wished for a Jake Brake.
05-26-2009, 07:42 PM
#37
Richmond
, Kentucky
Terry, since this is a 310 its likely going to have two rubber hoses for the rear brakes, one for each rear caliper. While its possible I would be surprised if they both failed at the same time.
I'm inclined to think its probably the master cylinder or the booster. I seem to remember a thread where the rod between the master cylinder and the booster has to be just right or the brakes won't work right. Of course that doesn't explain why it would all of a sudden fail. Needless to say this one is a tough one to diagnose.
05-26-2009, 07:47 PM
#38
Retired.
, At Large
IIRC, it's a lever that blocks the brake lines, and keeps fluid pressure from dropping while parked. I have seen one fail, but it was an "almost no movement possible" failure.
I wasn't sure if it was one hose or two, but I'm thinking it's probably master cylinder (which is why I suggested starting there), or that Lev'r Lock.
05-26-2009, 08:04 PM
#39
Ajo
Was the lever lock a add-on? I have a simple parking brake off the overdrive shaft.
05-26-2009, 08:12 PM
#40
Retired.
, At Large
It was an add-on, usually installed on manual transmission vehicles with lots of in-and-out of the cab, such as delivery and tow trucks.
