Old 03-15-2014, 10:41 AM   #1
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Help; Loss of power
Was taking the moho to a shop a few hours from home to get the A/Cs done.
I was unable to get above 45mph. Just had it out for a drive last week-end and it ran like a bat out of H.... I made it back to the storage lot.
Cummins 5.9 BTA with Allison transmission.
I checked all the fluids. Transmission was low and topped it off. Drained fuel separator, nothing noted.
Fuel filters are a year old with less than 100 miles in them.
Engine idles great and revs with no load just fine.
Any ideas before I call Good Sam to arrange a tow to the nearest shop would be appreciated.
I am going to crawl under and check the fuel line. There is not a secondary pump that i know of nor was one needed during the 1400 miles I have put on it in the last 15 months.
Thanks!
Dave
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 03-15-2014, 11:57 AM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 58
Turbo Boost connection failure? Is the connection tight on the intake manifold fitting?
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 03-15-2014, 12:08 PM   #3
wxbuoy's Avatar
Dave,
Will check but I was still getting 10 lbs of boost at 40 mph.
Dave and Felicia
Old 03-15-2014, 12:26 PM   #4
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Dave,
If you have a boost gage, was the 10 PSI normal? I've got a '97 Dodge 5.9L and it makes mid to upper 20's IIRC under heavy load acceleration and my '05 Dodge 5.9L gets 28-29 under hard acceleration. I know, not a motor home, but still from the 5.9L family. Checked the air filter housing for critter debris? Do you have an EGT gage also?
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 03-15-2014, 12:42 PM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
What you are describing is a classic symptom of fuel restriction, typically at the fuel filter. Since your fuel filter is new, possibly there is some kind of restriction in the fuel line.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
moosetags is online now   Reply With Quote
Old 03-15-2014, 12:47 PM   #6
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
What Brian says above.
Old 03-15-2014, 12:55 PM   #7
1976 27' Overlander
Hartford , Alabama
wxbouy,
Have you by any chance filled with bio-diesel lately? If you don't normally run it it can losen crud in the tank and lines and plug a fuel filter very quickly.
TomJ
Valacidor is offline   Reply With Quote
Old 03-15-2014, 01:09 PM   #8
wxbuoy's Avatar
Dave: looks like everything is tight
Gary; no egt gauge. 10lbs is about right Only time it goes higher is if I am going up a steep incline at 65 mph. Checked the air filter all is good and no critters
Brian; no signs of crimped fuel line but they way it is run who knows.
Dave and Felicia
Old 03-15-2014, 01:11 PM   #9
wxbuoy's Avatar
TomJ; no haven't used biodiesel yet, that I know of. But will get new filters just in case.
Dave and Felicia
Old 03-15-2014, 01:13 PM   #10
wxbuoy's Avatar
Thanks for all the suggestions. I am off to napa to get new filters and see if that works. I have a tow scheduled for monday morning worse case scenario.
Dave and Felicia
Old 03-15-2014, 01:14 PM   #11
masseyfarm's Avatar
Images: 58
The "shut down solenoid" on these has been updated with a new style.
The solenoid requires power to open, and if it hangs up, will give you that loss of power feeling before it quits for good.
Dave
Old 03-15-2014, 01:18 PM   #12
wxbuoy's Avatar
Dave; Never heard of that. Were is that located?
Dave and Felicia
Old 03-15-2014, 02:08 PM   #13
masseyfarm's Avatar
Images: 58
Bottom or top of fuel pump.
Look on the Dodge owners site for some info. I had to change mine on my 8.3 back in 2010 on the road in Utica NY.
Hang on, I will get you a picture. Cummins has an upgrade that is heavier than the original but bolts in the same pattern.
You can manually operate it in an emergency if that is the problem. Just tie it up or pull it down.
Dave
Old 03-15-2014, 02:15 PM   #14
wxbuoy's Avatar
Dave
Will do thanks!
Dave and Felicia
Power Loss & Pets Inside? Frank&Mike The Pet Forum 67 07-27-2013 08:57 AM
Solar Power for Battery Maintenance Tumajin Generators & Solar Power 10 08-12-2011 06:10 AM
Newbie has power questions Czechitout Electrical - Systems, Generators, Batteries & Solar 2 08-07-2011 04:20 PM
No Power To A/C (power at breaker) vhariable Electrical - Systems, Generators, Batteries & Solar 3 06-28-2011 05:54 PM
HELP...Sudden loss of power to AC netlace Furnaces, Heaters, Fireplaces & Air Conditioning 2 04-09-2011 06:28 PM
