Old 08-28-2009, 11:35 AM   #1
1988 34.5' Airstream 345
katy , Texas
Question help!! 454 ex manifolds & reservoir
looking for stainless steel manifolds for my 1988 airstream 345 also coolant reservoir. just bought it and trying to keep as close to original as possible. thanxs jim
katytx is offline   Reply With Quote
Old 08-28-2009, 02:29 PM   #2
345bill's Avatar
Las Vegas , Nevada
I could be wrong but I'm pretty sure original ex. manifolds were cast. Alot of people have switched to headers, alot of benefits over stock. Do a search here and you'll find all the info. you need on headers.
On the coolant reservoir I was unable to find exact stock one to replace mine so I got a universal one that's a bit smaller but works fine on our 1990, 345. Alot of auto parts stores have different ones on shelf.
345bill is offline   Reply With Quote
Old 08-28-2009, 03:21 PM   #3
Gunter
gunner's Avatar
2000 35' Land Yacht XL w/2 slides
Greenville , Ohio
Found the coolant reservoir at Airstream, Jackson Center, OH.
Gunter
2000 Land Yacht XL 355
gunner is offline   Reply With Quote
Old 08-29-2009, 09:18 AM   #4
345bill's Avatar
Las Vegas , Nevada
When we were at Jackson Center in Aug. of 07 they told me the overflow bottle was no longer available. I'll definatelly recheck with them as I also would prefer the "correct" one. Thanks for the info.
Old 08-29-2009, 09:34 AM   #5
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
I take it you are talking about exhaust manifolds.
I would not use stainless for that purpose, too problematic for leaks. The problem is stainless has a expansion coefficient that is not compatible with cast iron. They change size differently with heat. It will leak, stick with mild steel headers or cast iron manifolds. You will have less trouble in the long run.
It is just too hard to change out blown gaskets on a regular basis due to metal movement.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 08-29-2009, 09:40 AM   #6
Gunter
gunner's Avatar
Greenville , Ohio
I purchased the coolant reservoir several years ago from Airstream, Jackson Center, possibly by now they may not have them any more. The probes for the coolant level were part of the kit provided but I had to drill the holes and assemble to the reservoir.
Gunter
Hydraulic Levelers Reservoir noiva Mechanics Corner - Engines, Transmission & More... 4 11-03-2005 07:34 AM
The exhaust manifolds are off! Now what? swebster Mechanics Corner - Engines, Transmission & More... 13 08-07-2005 12:29 PM
exhaust manifolds David LaVoisne Airstream Motorhome Forums 9 03-29-2004 08:45 AM
'81 454 prevenative maint. & upgrades IPM Mechanics Corner - Engines, Transmission & More... 10 09-02-2003 10:29 AM
