Old 01-24-2006, 05:47 PM   #29
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by noiva
Terry,
If I'm not mistaken, Steven is replacing the rear bushing on his tranny, not the rear main seal on his engine. At least that's what I understood. I could be wrong, of course. Sure wouldn't be the first time !
Tim
Glenn is replacing his rear main seal.
Old 01-24-2006, 05:58 PM   #30
noiva's Avatar
Chesapeake , Virginia
Images: 46
Like I said, it sure wouldn't be the first time ! I thought you were commenting on the proposal by Steven for the exchange of pictures. Sorry .
Tim
noiva is offline   Reply With Quote
Old 01-24-2006, 06:10 PM   #31
Well Preserved
1993 21' Sovereign
Tim
At least it shows someone reads my posts...
Old 01-29-2006, 04:39 PM   #32
noiva's Avatar
Images: 46
Talking No Leaks
Took the 370 out today for its monthly "exercise" and to test all the hose connections from the replacement of all 60 feet of heater hoses on this beast. Good news...not a single leak . I checked every connection at the engine, front heater, and auxiliary rear heater, and not a drop of coolant . I know this sounds insignificant, but since my shoulders are still recovering from all the twisting and contorting I did to get that job done, I was a little concerned something had to leak. Also, it appears the replacement of the air filter, fuel filter, pcv valve, breather element, and some degreasing of spots where there was a little hydraulic "weeping" and tranny gasket "weeping" (but no dripping) has eliminated a rather constant smell of "engine odors" I had been experiencing. I also worked on the fit and gasket of the dog house cover to seal it off a little better. Only engine smells were when I finally parked. That appeared to be just normal exhaust smells, since it quickly dissipated when I cut the engine off. Do any of you experience "engine odors" (not gasoline) when parking a hot engine MoHo? Is that normal, or should I go looking for a source. The engine is clean, with no oil drips or runs of any kind. I don't want to go looking for a "problem" that may not exist .
Tim
Old 01-30-2006, 11:07 AM   #33
noiva's Avatar
Images: 46
Question Engine Odors
Tim
Anyone have any observations on the engine odors? I'm afraid this post may have gotten buried at the end of this thread.
Tim
Tim
1987 30P
2003 Suburban 2500
AIR # 5648
Old 01-30-2006, 11:09 AM   #34
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Yes, we can smell a "hot engine" smell sometimes when we shutdown.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Water Heater Replacement rpwx Water Heaters, Filters & Pumps 2 04-23-2014 01:43 PM
heater... Basotrol replacement? help Tick Furnaces, Heaters, Fireplaces & Air Conditioning 2 12-07-2005 02:45 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
Water Heater Replacement, Others roessler Water Heaters, Filters & Pumps 9 06-18-2002 03:53 PM
