Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 10-20-2009, 07:42 PM   #1
Profile:  choctaw , Oklahoma
heater hose
After 24 years, the Silver bullet need new heater hoses. It takes about 50' and all the skin off the knuckles, plus two days of hard labor. While I was at it I replace the upper/lower radiator hoses and the water pump by-pass tube. I put 2 gallon of antifreeze and one gallon of distilled water in it before I ran out of water. Got to go buy more water, probably more antifreeze and some sealer for around the hoses before I'm done.
Think I need a blood transfusion and some skin-grafts now too.
That is a once in a life time experience!
mel
choctawmel is offline   Reply With Quote
Old 10-27-2009, 10:22 AM   #2
Profile:  Richmond , Kentucky
Mel,
Replacing the heater hoses is a job I am planning on tackling sometime in November. From the sounds of it its not going to be a job that I will enjoy .
Thanks for the heads up on what to expect
"Wherever you go... there you are." - Buckaroo Banzai
1984 310 Limited Motorhome
1974 31' Excella 500 (future hauler for 2 Triumph race cars)
1974 20' Argosy Motorhome (future Excella 500 tow vehicle)
Old 10-29-2009, 08:22 AM   #3
Brad, Good luck. I didn't re-plumb the heater under the couch, maybe later. Was running out of time before a road trip. The hardest part was trying to get a 5/8 hose onto the 3/4 nipple on the tank of the radiator. Was easy using a piece to 3/4 hose between the return "Y" and the radiator. All in all, about 50' of 5/8 hose, 5" of 3/4 hose, 2 gallon antifreeze, 2 gallon distilled water, 4 square inches of skin, and 1/2 pint of blood.
No pain, no gain ;<)
mel
Is furnace duct hose the same as household dryer duct hose? Bearstream1 Furnaces, Heaters, Fireplaces & Air Conditioning 4 01-12-2009 11:21 PM
Replace heater duct with flex hose? SafeHarbor Furnaces, Heaters, Fireplaces & Air Conditioning 2 02-11-2007 08:07 AM
Leaking hi pressure water heater hose Astrodokk Water Heaters, Filters & Pumps 8 06-05-2005 11:13 PM
"Water Heater" & SS Flex hose? Sneakinup Water Heaters, Filters & Pumps 15 01-31-2004 10:22 PM
Heater core, Door handle, Lower Radiator hose. josephhh Airstream Motorhome Forums 9 11-19-2003 10:20 PM
