Old 10-26-2011, 11:55 AM   #1
1982 28' Airstream 280
Redwood City , California
Heater/Defrost fan motor
My heater/defrost fan motor is bad. It's the one mounted on the outside of the firewall not the a/c motor. Has anyone found a source for them?
Dean
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 10-26-2011, 09:26 PM   #2
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Wow Dean, I think one of my first threads that I ever replied to dealt with this very subject. http://www.airforums.com/forums/f311...air-67476.html Think that it was decided that the motor is from Acme, and there is a link in the thread. Good luck, let us all know if you're successful, sure that each and everyone of us will be in your shoes soon enough. Thanks, Derek
Old 10-27-2011, 03:01 PM   #3
This is what it looks like...
'82 280
Old 10-27-2011, 03:02 PM   #4
How do they get two speeds out of a fan with only two wires?
Old 10-27-2011, 03:05 PM   #5
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
One wire for low and one for high?
OK, explain three or four speeds.
Actually it is done by sending different voltages from the control switch.
Compare to a variable speed drill that still only has two wires from the motor.
Vaughan
Old 10-27-2011, 03:11 PM   #6
That's what I was figuring, but it thought I tested voltage at both settings of the switch and got 12 volts on both...will do it again!
Old 10-27-2011, 03:28 PM   #7
1983 34' Excella
1967 24' Tradewind
Images: 32
OK, maybe it's magic instead.
Vaughan
Old 10-27-2011, 04:43 PM   #8
Called Inland and they want $166.48. I'll just say that is very steep and I'll have to look around.
Hopefully drive to Yosemite in two weeks isn't too cold!
Old 10-27-2011, 04:51 PM   #9
Andy, incase I do need to get the fan from you, can you give me a bit more info?
Is your part the motor, mount and fan cage?
I previously posted a photo of mine. Dimentions are...
Motor 3.1 x 3.7 inches.
Mount is about 6.5 inches in diameter
Cage is about 5.5 inches in diameter and about 2 3/4 inches wide
Dean
Old 10-27-2011, 08:13 PM   #10
Fan motor fixed!
I love it when I run across "real" experts! An old guy here at the ranch is a retired mechanic...he knows everything there is to know and he has proved it once again.
Asked him his thoughts on finding a new fan motor. He took a look at mine, smelled it and said the motor is not burned up and it is just the bearing on the shaft is froze up...rust and non-use.
He said drill a little hole in the capon the rear bearing and spray the front bearing on the shaft and the rear bearing with WD40. Work the shaft back and forth. Then tap the top of the shaft with a hammer to loosen it up. Hook it up to power and spray more WD40. Then spray se gun oil on the shaft and bearings. Gun oil? Of course I have gun oil!
Motor runs as good as new!
Cleaning and painting it up now!
Old 10-27-2011, 08:19 PM   #11
1983 34' Excella
1967 24' Tradewind
Images: 32
Outstanding!
Vaughan
Old 10-27-2011, 08:34 PM   #12
AirRowan's Avatar
1986 34.5' Airstream 345
Key West , Florida
The speeds are controlled by a resister mounted next to the heating/cooling box. The wiring from the controller (2 for 2 speeds, 3 for 3 etc.) end at the resister and just two wires go to the motor. I have one if you need it.
AirRowan is offline   Reply With Quote
Old 10-28-2011, 08:04 PM   #13
Hi All. Motor and fan are back in and all is working well. Even got two speeds! Saw resister under heater box.
I need some new defroster ducts...someone just posted about that as well.
Old 10-28-2011, 08:19 PM   #14
crazeevw's Avatar
The ducts at the dash, or the ductwork tubes going to the base of windshield?
Derek
Fantastic fan issues Skater Roof Vents, Skylights & Fans 3 10-15-2011 08:07 PM
Best way to install Fantastic Fan dcole Roof Vents, Skylights & Fans 3 10-01-2011 08:31 PM
AC Fan Motor Seized? jonny Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-13-2011 02:00 PM
Fan Motor Okiegent Roof Vents, Skylights & Fans 19 05-15-2011 11:58 AM
Stove Vent Motor Speed Control Road Geezer Stoves, Ovens & Microwaves 12 04-29-2011 02:12 PM
