Old 12-11-2018, 02:15 PM   #1
San Luis obispo , California
Getting 454 smog ready
My father picked up a 85 Airstream motorhome with the Chevy 454 and the previous owner removed some parts needed to smog because they stopped working and it never really left his property in 10 years. The local Chevy and Airstream dealers have been no help in the matter so I was hoping I could see if anyone not restricted by smog laws may have these parts in the garage or at least know part numbers/where to get them. I am missing;
- smog pump and pulley
- diverter valve
- engine emissions label
Would also be very helpful if anyone had the vacuum system diagram as things have been rerouted around said missing parts.
Thanks for the help
Colin91 is offline   Reply With Quote
Old 12-11-2018, 03:44 PM   #2
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
There is quite a bit of info here:
http://www.airforums.com/forums/f311...ted-97568.html
You will probably find more by looking at Keyair’s posts, not sure if the sticky thread in the “classic motorhome” section has smog information.
Waipio Rim is offline   Reply With Quote
Old 12-11-2018, 04:12 PM   #3
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Most, if not all of those parts, are common 454 components. Should be able to find them pretty easily. This is going to sound strange, but I've had great success with rockauto.com. They a great selection of parts and great prices. The emissions sticker may be a bigger issue though. Might want to check with California emissions and see what can be accepted or reinspected by them.
92landyacht is offline   Reply With Quote
Old 12-11-2018, 04:48 PM   #4
Waipio Rim's Avatar
Honokaa , Hawaii
Post #8 in the link above has a picture of the sticker from an ‘84. Maybe it could be printed out as a new sticker?
Old 12-11-2018, 04:51 PM   #5
r carl's Avatar
Lin , Ne
Try salvage yards.
Old 12-11-2018, 05:03 PM   #6
- diverter valve
I've got the pumps and possibly the diverter valve from an 86. If someone can tell us if they will work you can have them for shipping.
Old 12-11-2018, 07:23 PM   #7
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Excellent idea on the copy, of not you could google the correct one and reprint it.
bobmiller1 is offline   Reply With Quote
Old 12-11-2018, 08:00 PM   #8
The label in the other thread will help a lot just getting everything put back together. I looked on the state website and it plainly says it can’t be failed for just missing the sticker so that might not be an issue after all.
I checked rock auto and they have three different pumps for a P30 chassis so I’ll have to check parts numbers when I pull the old one out tomorrow. And it looks like they have the correct pulley as well.
As for the diverter valve I’m not having much luck finding anything specific. Dozens of options come up with whatever search terms I use. Is there a more technical term for it that I might be missing? Brad - would there happen to be a part number of any kind on the one you have. I don’t see them changing over one year....hopefully
Old 12-12-2018, 06:27 AM   #9
This weekend I'll climb up to the barn loft and get a picture of the diverter valve. Here's a link to a diverter valve on ebay. From memory the one I have looks similar if not the same as this one.
Old 12-12-2018, 11:52 AM   #10
That exactly the one I found and think is the best bet. Just want to be sure before I spend the $100 on it
Old 12-12-2018, 01:05 PM   #11
I'll try and get up into the loft tonight and get a picture of the one I have. If the one on ebay is the same I'd buy it before trying to get by with a used one.
Old 12-12-2018, 05:31 PM   #12
I actually have two of the diverer valves. The 86 345 had twp smog pumps and two diverter valves.
ID:	329567Click image for larger version
Old 12-12-2018, 09:40 PM   #13
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Extra cylinders, coils, sparkplugs, spark plug wires, carbureters, heat issues, explosive fuel, smog pumps, diverter valves, weird vacuum lines.......I'm soooo glad I have a diesel.
Cheers
Sidekick Tony
Old 12-13-2018, 12:16 AM   #14
Attachment 329567Attachment 329568
That diverter valve is different than what I’ve been seeing. I found and got a NOs one ordered off eBay tonight. It is the same part number as the one in Keyairs post in the other thread. Napa had a remain pump for a pretty good price so I snagged that as well so I won’t be needing Brads old parts after all. Thanks for taking the time to look though.
Late 454 vs early 454 & 400 vs 4L80E gbell Mechanics Corner - Engines, Transmission & More... 33 07-01-2017 06:59 AM
Correct belt sizes for 1984 310 with 454, A/C and smog pump bkahler Mechanics Corner - Engines, Transmission & More... 11 01-09-2013 12:52 AM
smog pump - 454 Pop Rivet Mechanics Corner - Engines, Transmission & More... 13 12-31-2007 04:43 PM
Getting ready to get ready to think about an AS pinkflamingoes Our Community 22 10-04-2004 07:36 PM
Cal Smog? 1988 Airstream 345 nglase Airstream Motorhome Forums 4 04-30-2003 08:34 AM
