07-17-2006, 06:45 PM
#21
1995 33' Land Yacht
Houston
We actually have a TPAS, and displays on the Garmin 530 screen similar to what TIS looks like. You get advisories and alerts in the headset via a sexy woman's voice with an english accent. It also has an terrain alert and a fancy autopilot that will fly your flightplan including the published approach (and missed, if you need it).
I'll take a photo of the panel next time I run up to the airport. It's a Beech A-36 (club owned). If it's a quick (or cheap) trip I fly a Piper Arrow PA28-200.
____________
Troy Marrs
95 Land Yacht 33
07-18-2006, 07:15 PM
#22
2012 31' Classic
1999 36' Land Yacht Widebody
Andalusia
, Alabama
I wonder how many of us are (or were) pilots? One of the things that drew me to an Airstream was the look and feel of the inside shape. I was a corporate pilot for 25 years, flying Citations, and Falcons. In the 345, I feel right at home.
Rob
07-19-2006, 03:30 PM
#23
1984 28' Funeral Coach
Belleview
hmm...... I feel a new thread comign on.... Look for "Flyboys and Airstreams" or something to that effect.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
07-20-2006, 04:26 PM
#24
1996 28' Excella
Portland
, Oregon
I've flown hang gliders for the last 11 years. The shape of the vessel is quite different, but the fascination with aerodynamics and aspiration to be independent/different are very much similar.
Anyway, problem not solved with the generator. It seems I was totally off with the points. Maybe it's running better, but it still dies. I have a float/valve problem. The needle gets stuck open or shut and either starves the motor of fuel or overflows into the venturi somehow, and kills the motor.
I'm going to buy a new needle and seat, try and get it to work right, and I'll let y'all know if it fixes the problem.
does anyone know of any tricks that I'm missing?
-Kevin
1996 Airstream Excella 28'
2007 GMC Duramax 4x4 CCSB
07-23-2006, 02:01 PM
#25
1982 28' Airstream 280
Norfolk
, Virginia
Hate to butt in on you fly types, but I was wondering about the points in an Onan. It is my understanding that Onan makes a kit to convert the ignition to electronic. Does anyone have any experience with this?
Steve
07-24-2006, 09:24 PM
#26
RivetAddict
1986 34.5' Airstream 345
Louisville
, Kentucky
SEL, MEL, Commercial here too. Definately had an influence on the purchase of our 345 as it tends to influence other areas of my life (met the wife at flight school).
Kevin,
When I first got mine it would not run at all. I pulled the carb, removed the needles and blew about a can of carb cleaner through everything. It fired right up after re-installation and setting the needles to base setting.
Also check the control box (especially at night) for shorts. Last year I chased an intermittant short in the box which when vibrated enough would ground and kill the genny. Also look at the low oil sender and the R1 resistor.
Steve, I've not heard of a conversion kit. The points on mine have been pretty bulletproof but I'd be interested in how the conversion works out.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
10-26-2006, 04:27 PM
#27
1996 28' Excella
Portland
, Oregon
I tried everything listed here. I swear, I'm not a dummy. I figured that I've spent 20 or so hours sitting next to this genset trying to tune it, and get it right. I think step one of 27 is to check the oil.
So I decide to give up and take it to the Onan shop at $97/hr.
I swear I'm not a dummy.
You ready?.... Low oil.
They told me this over the phone, I'm going to pick it up right now. I guess they're going to have to show me how to check the oil.
At least now I have new filters, plugs, points, hr. meter, and a clean carb and motor!
-Kevin
10-26-2006, 06:01 PM
#28
2012 31' Classic
Andalusia
, Alabama
I hate when that happens.
10-27-2006, 07:32 PM
#29
RivetAddict
Louisville
, Kentucky
Ouch! Well it'll never happen again
Steven Webster
AIR 1760
10-28-2006, 10:03 AM
#30
Just a throught. I have experienced this kind of problem with a bad plug "wire" after you disturbed it you got continuity. It's a cheap fix and worth a try. Good luck
Nye
02-17-2007, 05:02 PM
#31
Iowa City
, Iowa
We have an Onan NH65 that starts and runs for a minute and then starts spewing black smoke and dies. We took it in for repair, got a new choke, tuneup, fuel pump, and a head gasket on #2. It ran ok, twice for about a half hour each time, and now is back to its black smoke and dying. Two unresolved issues after the $800 plus repair by the Cummins Onan folks. was, they couldn't get a carburetor, and also they needed to replace fuel line but would have to have drained the (full) fuel tank to get at it.
They also said they found threaded stock in place of cylinder head studs on the #2 side and had to helicoil them and put in bolts,
What Mr. Auretrv is looking to do is locate a carburetor or kit that includes a float and valve, re-check compression, and replace the fuel line.
We're hoping the problem is either in the float valve or choke, and that a carb kit, fuel line will get it going again.
The Onan is 6.5 KW and could run both A/C,s at once if desired. Also we are hoping it would be repairable for significantly less than the cost of a replacement.
Any similar black smoking genset death stories would be appreciated!
Airstream OCD...there is no cure!
1983 Classic 310 Motorhome.
AIR 15765
02-17-2007, 05:14 PM
#32
RivetAddict
Louisville
, Kentucky
Black smoke usually means too rich a mixture. I agree that a compression check is in order. Not sure what you meant by "threaded stock"...did they mean studs or cheap stock from Home Depot?
Replacing the fuel line can be done when the coach reaches 1/4" tank. The generators are plumbed in at that level so you don't run the tank dry when boondocking somewhere.
I absolutely agree on the carb. Try removing it, and cleaning the jets with carb cleaner. There are only a couple of gaskets in there so sometimes a really good bench cleaning will do the trick. Also adjust the needle in to reduce the mixture.
What do your plugs look like?
Lastly, it is possible you have an ignition issue as well. Check the points, circuits, etc. I chase a lot of gremlins out of my Onan and it almost always turned out to be electrical.
Steven Webster
AIR 1760
02-17-2007, 06:08 PM
#33
Another (ex) pilot here. 1500 plus hours. IFR. Nearly all in a Piper Six-300. I hope to live long enough to enjoy never, ever having to fly an airplane again!
Some of you suffered, along with me, during the recent ice storm and extended power outage here in Missouri. My 19 year old generator ran great for day one, pretty good on day 2, intermittently on day 3 (running rich, fouling the plug), and had gas pouring out of the carb on day 4.
To cut to the chase, I discovered that the carburator float didn't. After a period of extended use the float was soaking up enough gas so that it sank! A new float and it runs as good as new.
Mark
'85 Sovereign, 25'
02-17-2007, 06:52 PM
#34
Belleview
Well, to make a long post longer... I had no further trouble with the generator for some time and finally desided it was due for a carb overhaul. (new Carb) when the starter crapped out. The cost of the new carb was cheap enough that it seemed a good idea.
The AS dealer here locally did the work and informed me as I picked it up that the flywheel took quite a hit when the starter caved in. Why they didn't mention that when they had it apart was beyond me.
So now the Generac 40 works great, sometimes you have to hit the starter until you find a spot where the teeth happen to be but it works as it always did.
So now the bus is back in the shop getting the new Honda 6010 installed. I figured the Generac with it's 6-7000 hours might be reaching a limit of it's service life with me and the Honda was a deal.
I can't wait to have the extra power and dedicated circuit for the A/C.
The old Generac will go back onto it's original spot on the old Coachman that I hope someone will buy before the end of the month so I don't have to relicense it.
On the flying front it looks like I'm out of medical AGAIN!! Time to go visit the doc.... maybe soon I'll get a chance to go do a BFR?
03-03-2007, 09:08 AM
#35
Hi Guys,
My Onan in my 1988 Classic stops running as soon as I release the start button. It will run fine as long as the button is held in (fortunately this has not damaged the starter). It starts up great, runs great, comes on line with AC power, but my finger gets tired pressing the start button. Oil and gas levels are full.
It seems to me that a relay is not changing state as this problem has gotten progressively worse. Some days it would start and run as it should but not anymore. I will see if I can find and bypass the oil pressure switch and the fuel level sensor switch. Any other suggestions?
06-25-2007, 05:17 PM
#36
1996 28' Excella
Portland
, Oregon
AccessMaster,
I know this sounds simple, but one time I was pressing the button on the genset while the switch in the cabin was in the "off" position.
Don't know if y'all remember, but last summer I gave up and took the genset to Onan and they told me I had low oil. $103 and problem fixed. Since then I've been starting her every month just to keep things going - no problems.
So I'm getting ready to make the first trip of the season and I start her up, let it warm up, then I go inside and turn on both A/C units for a test and it kills the genset. I turn everything back off, and try to re-start. Now it starts and runs for 10 sec. then cuts out. I want to check the "low oil switch" but from my past, I know that when this switch activates black smoke pours out - and this is not happening.
What I've done so far:
1. pulled jets and sprayed carb cleaner in holes.
2. pulled the fuel line to carb and sprayed gas everywhere
3. pulled both plugs to check for spark and gap. (plugs were at .015 - maual says .025 and plate on unit says .025 but someone here said .015 was right)
4. used mirror to watch throttle body and saw steady stream of gas spraying in.
5. checked points gap.
6. added more oil - just over the "full" line.
7. added more oil - .5 qt more (I'll try anything at this point)
How can just adding a heavy load to the unit cause it to go into this tailspin of operation? It was running just great for so long now.
-Kevin
06-26-2007, 11:40 PM
#37
1996 28' Excella
Portland
, Oregon
If you take out the main and idle fuel adjustment screws is there supposed to be an o-ring or rubber gasket under the spring?
08-10-2007, 08:37 PM
#38
Iowa City
, Iowa
Onan Run Rich and Die Problem Solved...
OK, in my case the culprit was the carburetor float valve. Also, I discovered you can place the electric choke spring backwards and cause it to try to close instead of trying to open when the engine is started and warming up. One of those binary choice errors.
If you have an Onan 6.5 and do not have the Airstream or Onan instructions for calibrating the governor and jets, I can provide them. If the idle and main jets aren't reasonably close to correct adjustment, then adding a load will cause the unit to go down.
Now the gen runs smooth, although I haven't checked the brushes yet and the time clock died at 1140 hours before I acquired the unit. That'll be my next chore.
Thanks.
AIR 15765
