Old 05-20-2005, 02:59 AM   #1
, Alaska
generator in 1989 345?
I have decided to put an original replacement generator in my 1989 model 345. Which type was originally used? I know it was a 6.5 Onan, but I don't know if it was a Marquis or Emerald or what....
Thanks!
BTW, the former owner took the generator before selling the coach, and that is the reason I don't know what was originally in there.
Curtis-79MH is offline   Reply With Quote
Old 05-20-2005, 06:49 AM   #2
87MH's Avatar
1978 31' Sovereign
Images: 292
'87 Generator
Originally Posted by Curtis-79MH
...generator in my 1989 model 345. Which type was originally used? I know it was a 6.5 Onan, but I don't know if it was a Marquis or Emerald or what.....
Original equip in the '87 345...
Onan Generator
1986 6.5 McGraw Edison Onan
Model 6.5NH-3CR/1600 4P
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 05-20-2005, 07:03 AM   #3
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Curtis - Just out of curiosity, is there a reason you want to stick with the original OEM Genset? I think if I was in your position I'd look at a new Onan or more likely install a Honda RV liquid cooled generator as a replacement.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 05-20-2005, 07:43 AM   #4
LOST , Hawaii
I wonder along with Steve. Generators are probably the most problematic system in these. When you find one it will probably have an unknown history and problems. They need to be run regularly and the hour meter is not part of the unit. You won't know if it has 600 hours or 6000 hours. Externally they all look similar but there were a lot of changes made thru the years; parts can sometimes be hard to find and expensive.
John
74Argosy24MH is offline   Reply With Quote
Old 05-23-2005, 09:44 AM   #5
, Alaska
Post
I remember talking to Peter after the Honda installation and he said it was a difficult installation, but that was in a 1979 28'. Do you know if the generator compartment is larger in the 345? Remarkably, the price difference between a NEW Honda, and a used Onan from Colaw's, isn't but about $300. Any idea what an installation of a new Honda might cost?
Thanks again!
Old 05-23-2005, 10:17 AM   #6
Images: 59
Another thing to consider is the engine speed. Onans run at 1800 rpm and Hondas at 3600 rpm. I would choose the slower one. Personal preference.
more info: On further investigation, I found the Onans run at various speeds. I may have been referencing an earlier model. Speed varies by size and type. Onans run at 1800, 2400, and some as high as 3600, like the Hondas.
Old 05-23-2005, 10:59 AM   #7
RivetAddict
swebster's Avatar
I'm not sure about the dimensional differences of the compartment itself (280 vs. 345) but I'm pretty sure that access to the compartment is better on the 345. If yours is like mine then you basically have a big access door on the drivers side. The door opening is 36" x 18". The GenSet on mine is 33.5" x 19" with the carb and air cleaner bolted on and 17" with it removed (measured to top of the control box).
The GenSet is bolted to a metal pan which is attached to the floor of the genset compartment with four bolts. Once disconnected it should come straight out the door? Lifting the weight of the GenSet while it's still in the "hole" is your biggest problem.
87MH has removed the Onan from his 345. I think he had to use a forklift to lift it out. Perhaps you might send him a PM for some information from someone who has "been there done that" on a 345.
You might call around to your local RV Dealerships for a book rate on an R&R for a GenSet. It might be a little different for you if you switch to Honda in that the 12V, 115V and fuel connection locations may change or require modification to work with the Honda.
As far as getting a new Honda in there; I found this on the NorthernTool website for the Honda 6000 Watt RV GenSet:
Dimensions: 25.59in.L X 19.09in.W X 14.17in.H
REQUIRED COMPARTMENTAL DIMENSIONS: 28.11in.L X 21.49in.W X 15.23in.H
AC OUTPUT IS 120V: 6,000W (50A) CONTINUOUS & SURGE
Engine: Honda
HP: 12
Fuel Type: Gasoline
Looks like it's considerably smaller than the Onan....so it should "slip right in" - right?????
Please continue to post your findings on this thread. We're all facing Generator replacement at some point and I for one have considered the Honda as the logical choice for me when the time comes.
Steven Webster
AIR 1760
Old 05-23-2005, 04:10 PM   #8
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
One thing for sure, my 345 had a LOUD Kohler gen set. It was air cooled and shoook the whole coach at start-up and shut-down. I love Honda and would think it would add to (1) enjoyment and (2) value.
I forgot to mention that the Kohler would almost kill any grass under it with super hot dry air.
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 05-23-2005, 09:21 PM   #9
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
I very much enjoy the Honda4010 and its performance has been 100%.
The size of the compartment required very precise placement of the Honda, but that was not the big issue. Cutting the various new holes in the 5 gauge steel was a difficult job.
I wrote an article about my "weekend" here:
Installing a Honda 4010/6010 generator
1991 25' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 05-23-2005, 09:46 PM   #10
mcneon's Avatar
Check out this GMC Co-op link. These guys mostly work on GMC motorhomes, but they are branching out into Airstreams, too.
In the "79 Shiny one" story, they're replacing the Onan with a Honda. The report isn't finished yet, but it could be helpful once it is.
I replaced the old Onan Power Drawer unit in my '74 Argosy with a 6KW Honda. Quite the shoehorn fit, but it works great. A 4KW would've fit much more easily, but where's the challenge in that?
mcneon is offline   Reply With Quote
Old 05-26-2005, 04:49 PM   #11
Airstream Driver
1997 30' Excella
Images: 51
This picture shows some of the modifications to the bottom plate required to make the Honda EV4010/6010 work
AIR #13
Old 05-26-2005, 04:57 PM   #12
LOST , Hawaii
One of my least favorite combinations, heavy steel and hole saws.
John
Old 05-26-2005, 11:03 PM   #13
, Alaska
That is the picture I needed to see, Peter. Think I'll go with OEM! Thanks
Winterizing a 345 Motor Home winner Airstream Motorhome Forums 11 09-29-2007 12:56 AM
Shower door. Has anyone put one on a 1987 345 or similar airstream with curtain? MacInDaBox Airstream Motorhome Forums 2 05-17-2007 12:06 PM
Door-Step Cycle -345 winner General Motorhome Topics 8 10-04-2002 02:19 PM
345 Hill Climbing ViewRVs Mechanics Corner - Engines, Transmission & More... 12 04-18-2002 11:52 AM
Hello from new Forumee - and a question about front shocks on my 1989 345LE williamhenshall Mechanics Corner - Engines, Transmission & More... 12 04-14-2002 10:13 AM
