Old 10-26-2005, 08:42 AM   #15
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
Onan Generator
This may have no bearing but my generator would run for 15 minutes or so and then lose power, start to miss, and stop generatoring. Rpm's got too low. I put in a tune-up kit and it had no effect. I took it to an Onan trained mechanic and he tuned it up again. Ran great for 15 minutes and then the same thing. Had to warm up first. Finially took it back to him and said call me when it works. He called the next day. He found a screw on the back side of the carburator was loose and when it heated up and the hole expanded, it sucked air and caused the mixture to go lean. Tightened it up and now it works great again. The screw was in such a place that it could not be seen without a mirror.
cooperhawk is offline   Reply With Quote
Old 10-27-2005, 07:47 AM   #16
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Fixed it. Turned out to be four things:
1. The point gap was off (.025 instead of .015)
2. The plugs were fouled and their gap was off - replaced with new
3. The mixture was too rich
4. The 12V feed into the control box was chaffed and shorting (the real cause of the intermittant stalls.)
I also checked the plug wires for arching, etc. Everything else seemed to be fine. It's such a relief to go from backfirings, smoking, coughing to purring like a kitten with less than $5.00 invested.
Thanks to all that provided input.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 10-27-2005, 10:04 AM   #17
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
way to go,my favorite type of repair....cheap and simple....
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 10-27-2005, 06:17 PM   #18
noiva's Avatar
Chesapeake , Virginia
Images: 46
Generator cutting off
I never cease to be amazed at how simple things can cause so much trouble. Glad to got it fixed, and w/o even spending enough to buy 2 gallons of gas!
Tim
noiva is offline   Reply With Quote
