Old 12-30-2004, 05:59 AM   #1
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Gen Set Maintence
I finnaly have an Airstream in which eveything, well almost eveything works and I want to keep it that way. I need to know how to maintain my generator. I do have all the manuals and understand that it needs to be operated at load each month but beyond that the manual was somewhat vague.
What do the rest of you do to keep your generators running at tip top shape?
Thanks in advance for all the great advice.
Chaplain Kent
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 12-30-2004, 06:13 AM   #2
87MH's Avatar
1978 31' Sovereign
Images: 292
I found both of the jets in my original carburetor terribly eroded. After attempting to replace the jets I just purchased a new carb (not much more expensive than a carb rebuild kit)...in hindsight, I should have changed the carb to start with instead of trying to rebuild.
I firmly believe that the eroded jets were caused by air being sucked into the line somewhere - caused by a combination of almost 20 year old rubber lines and a LONG suck from the rear mounted gasoline tank to the genny mounted fuel pump.
If you have to pull the generator, it is held in place by 4 bolts through the genny pan to the compartment floor...the back two bolts are difficult to get to, and you have to work by "feel" only - you will need two people to remove these four bolts - one in the genny compartment and one under the chassis.
I ended up using a forklift to get the generator out - there is only a minimum amount of clearance to lift the generator out of the compartment door - I also had to remove the carb, intake manifold, and air cleaner to get the genny out of the door.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 12-30-2004, 07:20 AM   #3
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
clena your carburetor, change or clean out the fuel filter. Check all the incoming lines for condition. Change out the spark plug(s) and change the oil and filter. The filter can be bought off the shelf at NAPA with your gen set number, instead of ponying up 14 or more dollars for the Onan one.
Be sure that the oil level stays right or the gen will not run correctly. The splash oiling it does makes it critical to keep the level correct. I have had stalling when the oil was too high or too low.
Run the gen at least 2-3 hours straight, per month when you are not using it. It needs that to keep the seals in good shape. Run it with a load on it, like the ac, or roof strip heater, or something that will pull some amps.
Mine has 500 hrs on it, runs like a champ with the above done to it...only had on one problem in three+ years, and that was when the oil level was off as stated.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 12-30-2004, 08:15 AM   #4
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Alan made some great points on generator maintenance. A few things to add would be to replace the points yearly and clean all of the electrical connections in the "box". I had to replace a few relays and a resistor to get mine running correctly and also had the low oil level switch go out. (Alan - this switch could be presenting itself as the "stalling" you mentioned with low oil levels - it is actually by design and acts as an ignition cut off if the oil gets low).
On the filter - I've run both NAPA and Onan filters and found the NAPA caused problems with low oil pressure when operating in winter temps. The Onan filter has a single large "bypass" hole in the base for cold weather starts. I could not get mine running for more than a few minutes last winter until I replaced the NAPA filter with the Onan. For warmer climate or summer running the NAPA filter is fine.
I agree completely that running the Genset is the best preventative maintenance task you can perform. When I got my MH getting the genny running was a big job and all of the isues I had seemed to be related to lack of use (my unit sat unused for a while before I purchased it). I run mine at least an hour a week under partial load (one AC or heat strip).
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 01-10-2005, 09:04 AM   #5
1994 30' Excella
A always I appreciate the great advice. I have had the gen set serviced and now have a zero hour starting point. Thanks alot.
Chaplain Kent
Old 01-10-2005, 10:38 AM   #6
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
good issue on the Onan filter, i will keep that one in mind when replacing next time, poenny wise as they say. What does zero hour starting point mean? Do they reset the gen hours at the service center?
AIR #005
retired!
Old 07-14-2005, 08:58 PM   #7
alfalsetto's Avatar
1982 31' Airstream 310
Longview , Washington
That a new one to Me to ??????
alfalsetto is offline   Reply With Quote
Entry Door Lock Set Hunt ends at Inland Grady White 1959 - 1965 Ambassador 3 12-16-2004 09:08 PM
Generator Problems thenewkid64 General Motorhome Topics 27 05-07-2003 09:36 PM
Loaded question: avg miles per set of brake pads John Brakes & Brake Controllers 2 12-12-2002 05:01 AM
Take this Generator and Stuff It..... kzener40 General Motorhome Topics 8 07-24-2002 07:30 PM
Small gas gen sets FrankR Electrical - Systems, Generators, Batteries & Solar 0 04-12-2002 02:37 AM
