Old 07-29-2006, 09:43 AM   #43
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Tim,
If I have this right-you and your son-in-law were under the MH with 80 gallons of fuel, his finger was inside the drain hole holding back the flood while you put tape on the threads of the plug. He then took out his finger and you quickly inserted and tightened the plug. WOW! I'm glad you are able to tell the story.
I am eager to hear of the results from your new axle since I too need to do something with Chummy.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 07-29-2006, 09:58 AM   #44
noiva's Avatar
Chesapeake , Virginia
Images: 46
Originally Posted by Chaplain Kent
Tim,
Chaplain Kent,
You have it right! I couldn't figure any other way to stop the weep (very slight, seriously), and it went much quicker and with less fuel leakage than one might expect. Notice I had my son-in-law plugging the hole . That freed me up for the more technical stuff . Seriously, we made sure all electrical stuff was disconnected, we don't smoke, no fire around, etc. I've done more dangerous things putting gas in my lawn mower, but I am not recommending anyone else copy me . (This is where faith comes into action.)
I'm not clear on your comment about a "new axle". Are you referring to the GV under/overdrive or the keeper ring on the tag back plate? I guess it couldn't be that, since you don't even have a tag.
Side note: got any cute name ideas for the Silver Blimp. I really like your "Chummy" name, but I haven't been able to come up with anything for this silver whale.
Best
Tim
1987 30P
2003 Suburban 2500
AIR # 5648
noiva is offline   Reply With Quote
Old 07-29-2006, 10:24 AM   #45
1982 28' Airstream 280
Norfolk , Virginia
Tim,
Be honest. Bet there was a lot of praying during that operation. My luck is to have someone come up to me smoking a cig while I am "bathing" in gasoline and want to know if I knew I had a leak!
With that new GV maybe you could call it the Silver Streak, or the Silver Flash. Let us hope it ain't the Silver Dog.
Steve
Geophilist is offline   Reply With Quote
Old 07-29-2006, 10:43 AM   #46
noiva's Avatar
Images: 46
Originally Posted by Geophilist
Tim,
Steve
OK, Steve...
The praying went on in the form of thankfulness AFTER we finished. I know I should have prayed before, but I was truly thankful afterward. Fortunately, my MoHo sits so far back in the yard it would take a pretty good eye for a neighbor to have seen us crawling around soaked in gasoline .
If it's Silver Dog, I'll sell it to you for a very good price . Even deliver it, since you live so close.
I'm very hopeful I can call it something like Silver Cruiser, as in HIGHWAY cruising .
Best,
Tim
1987 30P
2003 Suburban 2500
AIR # 5648
Old 08-05-2006, 02:18 PM   #47
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
Tim, just got back from the left coast and wanted to check in for an update on the GV project. What's the scoop? Did you get your rig back yet?
We're all dieing to hear about it... and to see the before figures ... and the new test figures! Come on buddy, don't hold out on me man!!!
It really is amazing what you'll find if you take the creeper tour of your coach bottom from time to time. I do my tour once ever two weeks or so as I drive it so much. Forgot to do that a few weeks back and paid the price of having to replace some header collector bolts while on the road.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 08-05-2006, 05:37 PM   #48
noiva's Avatar
Images: 46
Glen, OK, I'm not holding out on you ! Fact is, I got a call yesterday that there was one missing wire in the kit sent from GV. When the shop tried to wire it with another wire (not clear what they meant by that ) they "fried" the electronics box that goes with it . They've called GV, who is sending a replacement box and the missing wire. I was assured that the unit is in, the drive shaft cut, balanced, and reassembled, and the switch wiring was all that was left. Now they say it will be next Weds. before they get the parts from GV, so I "should" get it back by the end of next week. Kind of long for a job that was to take 2 days, but after I read the installation instructions I really don't know how so many people install these themselves (according to GV - at least). I'm fairly mechanical, but I would not have attempted this job. Anyway, the shop has been faithful about notifying me, so I think they are still trustworthy . I've had these kinds of delays before when I had the blimp at another local shop having work done when my brother still owned it, so I've sort of come to expect it.
Thanks for asking, and I promise I'll be more than happy to report the return of my coach . I'm going to report the performance data as well, but I don't have any long trips planned as yet, so I may have to report on shorter runs for a while. By the way, I can't use a creeper under mine. It's parked on rocks. Try a tour of the bottom on rocks . Also, try finding a dropped part IN rocks .
Tim
1987 30P
2003 Suburban 2500
AIR # 5648
Old 08-05-2006, 07:14 PM   #49
GlenCoombe's Avatar
Belleview , Florida
Images: 27
So if I hear this right, you and your son-in-law did the finger thing "on the rocks"???
Makes me kinda glad I extended the driveway this spring. It is actually level too!
O.K. Tim, you got us going.... now how about the early numbers? How was the speed/rpm/fuel use on the long vacation trip??? Huh??? Huh??? Give us something!!! Pleeeeeeease............
Old 08-05-2006, 08:13 PM   #50
noiva's Avatar
Images: 46
Glen,
You got it about the gas drain plug fix "on the rocks". At least I didn't get any nasty stains on good concrete . I'm shopping for a good concrete guy now to see if I can at least afford a pad (other than gas absorbing rocks) to park this blimp on.
I was going to give all the figures at one time, but I sense you may have a medical emergency if I don't supply the "before" figures soon . So here's what I recorded: First leg - Air temp in low 80s, average speed 59 mph, typical rpm 3,000, engine temps between 190 - 210 depending on whether I was climbing or not, drove approximately 300 miles from flat Chesapeake to Blue Ridge Parkway at Afton Mtn, 30 miles south on Parkway and 30 miles back north - then first fill-up. Averaged 5.6 mpg (with generator running approx 2 hours). Second leg - Air temp in mid 90s, average speed 59 mph, typical rpm 3,000, engine temps between 200 - as high as 220 on hills (definitely can tell when outside temps go up), drove approximately 200 miles from Afton Mtn to flat Chesapeake - then second fill-up. Averaged 6.8 mpg (with generator running for approximately 1 hour). Dash AC on both ways whole trip.
Two quick observations: I've gotten as high as 8.6, but only on flat land, and in air temps below 90 degrees. As expected, 3 main fuel killers are outside temps, above 55, and climbing. Driving above 55 mph causes considerably higher temps, rpms, and gas consumption than staying at 55, but 55 is a real problem on interstates.
OK, now what do you think?
Tim
1987 30P
2003 Suburban 2500
AIR # 5648
Old 08-06-2006, 06:14 AM   #51
GlenCoombe's Avatar
Belleview , Florida
Images: 27
Tim, I think I'm surprised that you can get so much in the way of fuel economy ( I know that's an oxymoron ) out of the coach.
I'm going to be working on my rig today prior to launching tomorrow on another whirlwind fall booking time.... I'll see you all the end of September when I'm back home.
I'm certain the wait will be worth it all in the end and you have the 370 back. I'm looking forward to your first road trip, but then you knew that didn't you?
BTW I found my concrete guys in the yellow pages and they did the job the next day for cheap! Shop around.
I had already done the excavating as I wanted the dirt so they just had to form up and pour/finish.
Old 08-06-2006, 06:23 AM   #52
noiva's Avatar
Images: 46
Glen,
Thanks for the encouragement. Good luck on your trip. Frankly, I'm beginning to miss the blimp in the backyard. I keep needing things we keep in there . Hope you're right about this being worth it. Everything points to that, but I've dropped a lot of money , and have not yet been able to drive the "new" version. Anyway, I'm shopping for concrete guys now. Got one good lead, but I'll need them to excavate since my drive is compacted rock from almost 30 years. Not really a job for a shovel and rake .
Hopefully, I'll have some news by the time you return.
Best,
Tim
1987 30P
2003 Suburban 2500
AIR # 5648
Old 08-06-2006, 07:01 AM   #53
GlenCoombe's Avatar
Belleview , Florida
Images: 27
The compacted rock would be a good base for concrete. Some site evaluation could have you working with an elevated pad rather than excavating that much. I had a little deeper pour (6") done at the head end where the weight of the engine is generally parked. The rest is just 4".
If you form up on top, all you need to do is ramp up on the entry end. Excavate just for the landing areas for and aft... you'll also end up with better runoff and a more defined edge to mow around.
Old 08-06-2006, 07:04 AM   #54
1988 29' Airstream 290
Berkeley , California
Send a message via AIM to MrGoate
Well....
Originally posted by NOIVA: "OK, now what do you think?"
We think that when you get to the top of the entrance ramp and that beautiful 370 shifts into overdrive, running 65 mph at much lower rpms and temps with better mpg...
We'll see this:
Continue to hang in there; you won't regret it!
Mr. Goate in Sunny California
1988 Classic 290, 2005 Interstate
MrGoate is offline   Reply With Quote
Old 08-06-2006, 08:59 AM   #55
1991 35' Airstream 350
Windsor , North Carolina
Wink Gearvendor's wire?
Tim:
Can you supply a bit more info about your missing gearvendors wire?
My GV showed up Friday, and I plan to put Zeppelin in the shop next Friday. If I can check to see if the GV is complete BEFORE I take it to the shop......Well, you know.
PS: My (rather vague) average MPG on the 350 is about 6. The last trip to Harrisburg (which is mostly uphill, both ways (!)) confirms this. If I assume I can get about 8 MPG with the GV, my guesstimate of the time to return on investment is 27,000 miles driven at $3.05 per gallon. Your results will vary!!
(Disclaimer: These calculations were done with my shoes on, and are subject
to revision at any time.)
Rob
ralley is offline   Reply With Quote
Old 08-06-2006, 11:37 AM   #56
noiva's Avatar
Images: 46
Glen,
Actually, that was my plan. In Tidewater, VA it's always a good idea to put anything on a concrete slab high enough that you won't be stuck later having to raise the floor. I've already had to add 4" of concrete to my 50s era garage floor (fortunately, I had a row of cinder blocks before the sill plate, so I could just pour it in). My dad's garage is constantly getting water in the floor because the ground has risen in the 30+ years since he built it. When I added a ground level utility room to my house in 1990, I insisted the contractor pour a 12" slab to avoid future problems. I was thinking of a 6" slab for the blimp. Since I back it in, at least the front half would need to be 6". Thanks for the tips.
Have a good trip,
Tim
1987 30P
2003 Suburban 2500
AIR # 5648
gear ratios RVNUTTY Tow Vehicles 11 09-04-2004 03:38 PM
Opinions on Gear Vendors under/overdrive rdm Mechanics Corner - Engines, Transmission & More... 0 10-15-2002 10:36 AM
I finally went camping... Chuck General Appliance Topics 8 07-23-2002 12:42 PM
I finally got it home.... Chuck On The Road... 15 07-03-2002 11:11 AM
Gear vendors vs Us Gear LKappenman Mechanics Corner - Engines, Transmission & More... 0 04-18-2002 08:00 AM
