11-03-2008, 06:14 PM
1984 27' Airstream 270
long beach
gear ratios
My 1984 Excella 270 with a 14 bolt corp. axle with 4:56 gears. Has anybody switched to 4:11's? Drag racers and rock climbing 4x4s have 4:11 ratios so they are available and I'll bet the 4:56 would make an offroad vehicle climb that much better and my 454 should more than enough power to use the slightly lower gears?
11-03-2008, 06:25 PM
2005 30' Classic
Burlington
, Ontario
Not sure I'm understanding here!
My 1/2 ton sierra 4x4 has 4.11 diffs. Yours are actually lower than mine - unless I am very confused, which isn't entirely impossible!
Brian.
Brian.
11-11-2008, 07:45 AM
1984 28' Funeral Coach
Belleview
Craig, that's one low rear end... but lots of Moho's had 4.56's.
What do you turn (rpm) at 55 mph?
Check out Jegs or Summitt Racing for Ring and Pinion sets.
Make sure you get someone to do this swap who has experience and the right tools. As I understand it you can tear up a new rear end if it's not installed and meshed just so.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
11-11-2008, 07:55 AM
Retired.
, At Large
If I understand your question, you want to swap your lower-ratio gears for something a little more highway-friendly. The ring gear and pinion gear need to be installed together as a set, and need to be "set up" or preloaded. Most pinion gears use a crush sleeve and/or shims to accomplish this. It is something you can do, but requires more than basic automotive knowledge.
11-11-2008, 08:42 AM
1967 26' Overlander
Owings Mills
, MD
I don't think it's something you need to worry about with a '84, but when I took a look at new gears for the rear of my Titan, I was told I would need to have the dealer reflash the ECU.
11-11-2008, 10:43 AM
Retired.
, At Large
That's why my '02 Silverado will continue with the OEM 3.73 gearing. I am not sure if the '84 has an electronic speedometer or not, if it does, it will need a different VSS. If it doesn't, it will need a different speedometer drive gear. Both are located in the same place, in the tailshaft of the transmission.
11-16-2008, 10:06 PM
1987 32' Excella
Nepean
, Ontario
Before you mess around with changing the diff, do a bit of calculating - - figure out how much distance 1 rev moves the rig - remember that to do this, you need to know the diameter of the tires. I once had a Chev G20 van that came with a 2.73:1 diff. It was useless for towing, so I bought a set of 4.10:1 gears, but I increased the tire size so that it was effectively the same as a 3.96:1 rear.
BTW, if you do change the diff ratio, you will also have to change whatever is used to calculate your speed and odometer, either a small gear, or, more likely, you will have to change the DRAC (digital ratio adapter controller), a small module that interfaces between the sensor and the speedo.
Personally, I would be inclined to keep what you have. With the Chev van, I actually got better mileage with the 4.10:1 than the 2.73:1, not to mention the power to pull a heavier load. By moving to a numerically lower ratio you will lose load carrying capacity of your rig.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Gear vendors
gloran |
Land Yacht/Legacy Motorhomes |
1 |
03-31-2008 04:54 PM |
Gear Ratio ???
slow-canoe |
Argosy Motorhomes |
2 |
07-24-2007 10:09 AM |
Gear Ratio ?
slow-canoe |
Mechanics Corner - Engines, Transmission & More... |
9 |
04-10-2006 08:29 PM |
gear ratios
RVNUTTY |
Tow Vehicles |
11 |
09-04-2004 03:38 PM |
Gear vendors vs Us Gear
LKappenman |
0 |
04-18-2002 08:00 AM |
