Old 05-23-2015, 08:34 AM   #29
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Originally Posted by Kota View Post
Test drive a new F250 diesel.
Agree the new diesels since 2010 are quieter and the exhaust does not smell. The price for this is complex emissions systems like DPF (Diesel Particulate Filter) and SCR (Selective Catalytic Reduction) which requires DEF (Diesel Exhaust Fluid).
But your hands will still smell from diesel fuel if you get a drop on them because the stuff does not evaporate like gasoline.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 05-23-2015, 09:27 AM   #30
timhortons's Avatar
2015 16' Sport
Oakville , Ontario
Originally Posted by Ultradog View Post
I have a couple of diesel tractors. Diesels STINK. The fuel stinks and the exhaust stinks. If you get a drop on your hands or clothes or shoes you stink untill you change or wash them. And diesels are NOISY. Way more noisy than a gasser. I would never want to be around a diesel as much as I am my daily driver gas pickup.
This was very true ... up to about 1983-4
timhortons is offline   Reply With Quote
Old 05-23-2015, 09:30 AM   #31
timhortons's Avatar
2015 16' Sport
Oakville , Ontario
- - Mike
Don't imagine that Gasoline is any better for you just because it isn't as smelly at the fuel end. The VOC and benzene compounds are giving you cancer faster than the diesel, and the the anti knock agents aren't extending your lifespan either.
Old 05-23-2015, 01:19 PM   #32
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
Think I might have mentioned this, but there is a reason, commercial, military and industrial applications use diesel.
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 05-23-2015, 01:40 PM   #33
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Which is best is really based on your intended use. Today diesels and their fuel is different than it used to be and yes there is little to no noise or smell. I have not owned a diesel motorhome or truck but I owned a diesel Mercedes and a 2010 diesel VW Jetta Sportwagen. My family owned diesels for years when I was young. On that latter choice I wanted Diesel and that was that. My father and the salesman tried to tell me otherwise, that I was overbuying for my need. They were correct. Nonetheless, in this discussion, if you plan to have the motorhome in storage a bit the diesel is great as the fuel is pretty much non "soured" with time. The problem that is being talked about in the diesel community, even in the diesel car community by those who care, is about the need for additives. Some use Urea and that costs along with the fuel raising overall operation costs. It adds up. Then those with the Bosh high pressure fuel systems got information that U.S. refineries did not meet the lubrication specifications of their pumps. VW has revised their pump at least four times since 2009. The refining process is different now that used to be for the clean diesel. VW for example does not use UREA but they use a burn off device in the exhaust system that has a life expectancy to deal with. The issue is that the old adage that diesels will run forever may have been true long ago but now often there are other essentials like the $10K Bosh fuel system on the VW or the specialized expensive exhaust or some such that makes it potentially much like the hybrid car with a very expensive battery- parts that one day need replacement to remain functional.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 05-23-2015, 01:47 PM   #34
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
All in the nose of the beholder, I guess. Diesel is a great smell. I wish I still had my 1983 Mercedes 300D Turbo. That thing ran like a top and was very comfortable.
I'll agree with you on one point, though....... I have a hard time sneaking up on Prius drivers with my 7.3L PowerStroke!
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 05-23-2015, 01:49 PM   #35
1995 36' Classic 36
Ludington , Michigan
They learned from the Sherman tank Vs the panzer.
Kota is offline   Reply With Quote
Old 05-23-2015, 02:02 PM   #36
2006 25' Safari
Images: 8
Yep, clattery but a nice clattery. Mine was an Ivory '84 300CD Turbo. Beautiful coupe. Some well-dressed man who lived part-time on Sanibel Island bought mine. I miss it too. It was immaculate with the Palomino tan MB tex interior.
Old 05-23-2015, 07:20 PM   #37
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
It's all interesting but noise and smell are part of design function, mostly getting the most power. I have an A Series 3.4 liter Cummins 6 cylinder turbo diesel. It was designed for Onan back about 1980 and has no diesel rattle. I have it installed in a 1938 Ford COE truck. It is so quite that I don't even use a muffler, just a straight pipe. At idle the only way you can tell it's a diesel is to smell the exhaust. I like the diesel rattle myself but while driving the old truck about all you can hear is the air filter roar and of coarse the turbo whine.
Cheers, Dan
~ Margaret Thatcher ~
Smartstream is online now   Reply With Quote
Old 05-23-2015, 08:39 PM   #38
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Thats very cool Dan, have you got a picture handy you can post of the 38 cab over
mayco is offline   Reply With Quote
Old 05-23-2015, 08:45 PM   #39
mayco's Avatar
Name:	ImageUploadedByAirstream Forums1432435494.841366.jpg
Old 05-23-2015, 11:53 PM   #40
Well I did some digging and found a few of a tour we went on Vancouver Island a few years back.
This is at the motel getting ready for a little clean up.
That's my Speedster on the back.
We are waiting for the ferry at Mill Bay.
This is on the ferry.
Cheers, Dan
Old 05-24-2015, 12:02 AM   #41
Decatur , Georgia
Wow. Someone is having some fun. That is an impressive collection of autos.
scottg is offline   Reply With Quote
Old 05-24-2015, 12:56 AM   #42
You know us guys like our toys.
Cheers, Dan
What fitting for GAS on Atwood gas/elec WH rlindberg Water Heaters, Filters & Pumps 1 04-09-2010 11:29 PM
3/4 Ton Test Drives (8.1L Sub Gas, Exc Diesel, F250 Diesel) big_john Tow Vehicles 7 02-21-2010 12:02 PM
Need pictures of gas line for Magic Chief oven gas connection dghaas General Repair Forum 1 01-30-2009 09:04 PM
Gas or No Gas, that's the question... oldtrucksrul LP Gas, Piping, Tanks & Regulators 14 11-16-2008 10:29 AM
Locking Gas Cap for 2003 AS Gas Motorhome spat61 Land Yacht/Legacy Motorhomes 11 10-27-2008 11:37 AM
