i have spent most of this day looking for a gas tank sensor. not a 90 ohm sensor to be had. could someone point me to a source . my old one is about wore out. i took contact cleaner to it and it tracks some what . but not perfect. i plan to put the tank back on tomorrow, but i would pull the tank and put a new sensor on later if i can find one. lol
al
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 trailer
PEGGY SUE security dog
couldnt find a 0 to 90 ohm sensor and yes i had already planned to do some red neck engineering. picked up the filler hose this am and installed the tank . and ill be diped in s0-478 i pinched the engine fuel hose some how. let the tank back down and repositioned the fuel line hose and all s well . put 24 gals of gas and tryed the generator snake bit again the generator hose is pinched . we went up and down with the tank and walla cut the fill hose. now we are almost back to step one. tank drained .
going to drop tank and do some measuring and try to figure where the fuel lines are getting pinched. and also another trip to the parts place.
it looked so simple. and i had help screwing this one up. try try try again is about the best i can do sometimes.
al
AL
allison 6 speed
Sorry about your troubles, Al, but thanx for posting them. I feel a lot better now.
When I first got my MH, I always could smell gasoline in the rear. Like some dumb idiot I went to the gas station and filled up. Well, the gas was pouring out all the way back to house and down my driveway. Now I had 80 gals of fuel to get rid off before being able to remove the tank. It turned out to be a missing nut on top of the tank at one of the fittings.
I made my new fuel lines real long and was able to keep an eye on them with a mirror during installation.
Once you figure out how to do it,
the instructions actually make sense.
_____________________________________
WBCCI Member at Large
Block your tank solid with the mh sitting on the ground. Loosen the mounts and jack the mh up enough to get at the top.
John
You are a brave man, John.
Just to find out that the MH has to be raised 1' or more to be able get up above the tank because of some frame cross beams.
well it is raining now so dont look like i will be playing with the tank. i plan to drop the tank and do some measuring and tape the lines to the top of the tank. it has four lines .
1. vent
2.return from fuel pump
3. fuel line to fuel pump
4. fuel line to generator
at present the line to the gen set is pinched. and the fill pipe is cut.
if it dries off today im going to drop the tank and figure out where the lines have to be and tape them to the top of the tank. you cant see a thing after the tank is in place. it is jamed to the floor with two strips of ply wood as spacers got 1 inch space to put the lines and that is more than enough . im not seeing something. when i drop the tank i will know where the spacers are hitting on the tank. im going to measure and then draw chalk lines .
peter
i only had 24 gals in the tank i filled all of my vehicles up and still had 12 gals in gas cans. and that is all i will be putting in when i get it reinstalled . i plan to put 20 lbs of air thru the line and see if i can hear it in the tank. and that is how i plan to check the lines.no gas in the tank until im sure they are not pinched.
al
AL
allison 6 speed
peter
where did you get a 80 gal tank??? went to mr good wrench and he told me to try a junk yard as the trash i had in my hand wasnt GM . well he is right the tank has the airstream sticker on it . they say they put a 60 gal tank on the motor home but the stickes says 58 gals.
re read some of the post cant lower the tank straight down the fill pipe and over flow hose go thru the frame rail. it comes down at a angle after the fill hose is attached. has a large frame cross piece in the rear where the hoses are. that blocks any view of the hoses. might be 1/2 inch by the frame and the air bag crap blocks the front.
AL
allison 6 speed
Is your tank in a place where you can get to the fill hose from the inside. Both of mine have been under the front couch. There is an access cover that the hose runs thru that is accessable from inside. This may help in the routing and stop the pinching of the fill hose.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
my tank is in the rear no acess holes in the floor . my tank has to be installed at a angle as the filler hoses are on the side of the tank they just about clear the frame rail would have been nice if they stuck out a little past the rail so you could install the hoses with the tank in place. just about have to have this thing coated with ky jelly to get in the hole.
AL
allison 6 speed
