Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 08-20-2003, 01:07 PM   #15
PeterH-79MH
PeterH-79MH's Avatar
Profile:
Images: 63
Originally posted by 74Argosy24MH
Nah, I just have some really big jacks.
John
Forgot all about the filler neck. Mine had to be dropped and reinstalled at an angle as well
But what is 640 pounds of fuel and 80 pounds of tank for a guy with big jacks.
Al, it seems that the 80 gal fuel tank was an aftermarket addition. The 79's came with a 50 gal fuel tank. There was a sticker of the manufacturer, but it is in a location that I hope to never see again.
Once you figure out how to do it,
the instructions actually make sense.
_____________________________________
WBCCI Member at Large
PeterH-79MH is offline   Reply With Quote
Old 08-20-2003, 01:36 PM   #16
wb13798
wb13798's Avatar
Profile:  2004 28' Classic
huntsville , Alabama
yes the label was not where you could see it. id like to forget i have seen it. and hope not to see it again.
called a couple of airstream mechanics and told them what was happening with the fuel lines and i wasnt saying anything that they didnt already know. seems the lines are a bear to get in just the right spot. they have the same problems.
to put the filler hose on you feed it thru the frame rail and attach with the tank raised at a angle . then you can jack the tank into position. it is not very difficult after you get the jack in the right position. and the tank is empty. most folks dont think gas weight a lot 24x8=192 lbs plus the tank is close to 100 . that can wear an old man out. quick . lol
al
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 trailer
PEGGY SUE security dog
wb13798 is offline   Reply With Quote
Old 08-20-2003, 02:05 PM   #17
74Argosy24MH
Profile:  LOST , Hawaii
To heck with the jacks, I am glad I have a saddle mount tank. Straight up and down, just cut the hoses a foot too long and thread them through the frame rail. The filler hose is a little nasty, but just because it is so stiff. But then I will look like a rear ended Pinto if I ever get hit in the right side.
John
74Argosy24MH is offline   Reply With Quote
Old 08-21-2003, 09:27 AM   #18
wb13798
wb13798's Avatar
peter
going to take a picture and post of the label on the gas tank. i just posted at another thread about the tank not being gm . napa has a guage and sensor that could be installed to replace the 90 ohm sensor . also a boat supply has a sensor but not 90 ohm. i plan to talk to the farm tracktor places and see if the might have something . the omish work at jackson center and they may hay gone to the tractor supply for parts.
it is in a farm area.
al
AL
allison 6 speed
Old 08-21-2003, 12:53 PM   #19
wb13798
wb13798's Avatar
here is the jpg for the spacers lots of room . where i was messing up was the space on the side of the spacer boards to route the lines . i plan to make that opening another inch wider. i need all the help i can get.
AL
allison 6 speed
Old 08-21-2003, 12:54 PM   #20
wb13798
wb13798's Avatar
this is the spacer that is going to get cut
AL
allison 6 speed
Old 08-21-2003, 12:57 PM   #21
wb13798
wb13798's Avatar
the airstream sticker didnt come out to go but it is enough that you really dont want to see it. i know you recgonize the airstream blue.
this is the last jpg .
AL
allison 6 speed
Old 08-21-2003, 07:04 PM   #22
wb13798
wb13798's Avatar
well all is done got one small glitch. the over flow hose is damaged it driped a little, repositioned and got it stopped . i have 60 gal s of gas in the beast. the tank will hold 60 gals after all. . i think i will ty wrap it to the filler hose so it dont drip . after i burn couple gals it wont drip any way. going to take a trip labor day and watch the gas guage and try to come home on fumes.
some one posted once you understand what your doing it is easy.well that is the story. lol
al
AL
allison 6 speed
servicing gas part of refrigerator nickcrowhurst Refrigerators 3 02-21-2006 08:46 AM
New clean water tank silver suz Fresh Water Systems 19 03-29-2004 09:16 PM
Gas Furnace ketchumwt Furnaces, Heaters, Fireplaces & Air Conditioning 4 12-04-2003 01:46 PM
gas tank wb13798 Mechanics Corner - Engines, Transmission & More... 6 08-17-2003 01:49 PM
Black tank flush.... drboyd Waste Systems, Tanks & Totes 11 08-01-2003 08:40 AM
