Old 02-07-2003, 06:44 PM   #29
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Brett- I bought a starter from Alterstart in Dallas,TX. They make twoor more mini gear reduction types, I bought the racing starter. It has a solid billet alum mounting plate, with a revolveable head for the motor so it can be mounted away from the manifold/exhaust pipe, and the solenoid is solid metal sealed to protect from heat . All that for 119 bucks, which is less than half the price of a Tilton starter.
Just my 2 cents, but in the long run it may save me lot of grief. I also went the next maybe unecessary step and got at Thermal wrap for the starter too. If i have a heat related starter problem now I will eat the solenoid. With hot sauce of course!!
www.4alterstart.com is their address if anyone is interested.
Old 02-09-2003, 07:16 AM   #30
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Picked up the MH yesterday and boy is the new carb sweet! Smooth idle that is not so rich it stinks, and the secondaries kick in even when cold now. The new starter really kicks the engine over, and it seems to run quieter.
I also had the 2 flex lines to the front calipers replaced and the brake system bled. I now feel in more control when I have to stop due to some $%$#head who swoops in front of me and jams on the brakes.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 02-09-2003, 09:20 AM   #31
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Hey Brett,
$%$#head's brother lives in Austin and I understand he has an extended family.
Good move on replacing the brake pressure lines
I would hope that your mechanic checked the Idle mixture. One side was off by quiet a bit on mine. I would ask him.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 02-10-2003, 04:09 AM   #32
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
The idle mix was the only adjustment he made. The idle is perfect. At normal temps the coach will just roll a bit if you take your foot off the brakes.
Can't wait to make the run to Sarasota on Monday. I pick up the Saturn from CW Tuesday with the tow bar installed and the Brake Buddy will be here Thursday. Monday will be my first Toad pull as well.
Brett G
Old 06-16-2004, 08:50 PM   #33
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
OK, this is an oldie, but I thought I would add to it.
The prior posts were about my 76 MH, this one is for the 78.
I replaced the quadrabog with an Edelbrock a few months back. I tried to adjust it based on directions I received from all you forum friends. Of course at the time I did not realize my tach was acting goofy. I have no way to check the idle speed since I do not have an external tach.
In doing my adjustments I riched the carb up good! I was getting with toad 6-7 MPG I got 11 before I blew up the engine.
So I have been trying to get the carb back to factory spec and adjust from there. I ran the low speed screw all the way in ( I had to turn it in close to 4 turns to bottom it out) and backed it out 2.5 turns. I left the high side alone and took it for a run. The secondaries now open much easier and it has more power. The dash Vacuum gauge (fuel economy) is running higher than it was before, thats good, right?
Tonight I decided after reading a few more posts I would turn both screws in 1/4 turn. This required me to adjust my idle up a bit, but now I have even more vac on the dash gauge. Have not taken it for a run, but will on Saturday as part of the final prep to head for Lansing.
I guess the real questions are:
1. Anyone know the factory setting on the high speed screw?
2. What would be the symptoms if I am running too lean, and the possible side effects?
TIA
Brett G
Old 06-17-2004, 08:44 PM   #34
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
well?
Anyone? I have recently read running too lean can be harmful.................
Brett G
Old 06-17-2004, 09:04 PM   #35
LOST , Hawaii
If you are too lean it will backfire or stumble off idle. Too lean will burn pistons, valves, etc. When you get to Michigan pull a couple of the plugs and see how they look, tan is good, white is not. Tuning with the vacuum gauge is the way to go so you are probably on the right track.
John
74Argosy24MH is offline   Reply With Quote
Old 06-18-2004, 06:27 AM   #36
87MH's Avatar
1978 31' Sovereign
Images: 292
Originally Posted by 74Argosy24MH
If you are too lean it will backfire or stumble off idle. Too lean will burn pistons, valves, etc. ..... Tuning with the vacuum gauge is the way to go so you are probably on the right track. John
Ask any hightime aircraft pilot about leaning engines - if you own your own airplane, you buy a lot of expensive avgas just to keep the engine cool - price a rebuild of a recip aviation engine.
As cheap as "spot" infrared thermometers are (< a C note), it might be a good investment, lean carb to max manifold temp (run a vaccuum check to confirm), and rich the mix up to drop the temp about 50 degrees on the manifold - this would equate to about double the drop of the actual exhaust gasses (I think).
I keep the spot infrared thermometer handy at all times, when I stop to fuel up, I always do a walkaround visual check, get a spot reading on the tires (high temp will indicate a low tire pressure), and each wheel hub (high temp indicates a bad bearing or dragging brake). It takes no time at all to do a walkaround using the laser spot thermo, and it actually encourages you to take a closer look at the things that need a frequent visual inspection.
Another handy use of the thermometer is to record the in and out temp of the radiator - might indicate problem areas before a catastrophic failure does a lot of (expensive) damage.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
gas valves gmlcjb LP Gas, Piping, Tanks & Regulators 5 07-17-2006 09:31 AM
servicing gas part of refrigerator nickcrowhurst Refrigerators 3 02-21-2006 07:46 AM
Gas Furnace ketchumwt Furnaces, Heaters, Fireplaces & Air Conditioning 4 12-04-2003 12:46 PM
Engine will not start - LP Gas detector? AccessMaster Airstream Motorhome Forums 6 08-31-2003 08:38 AM
Small gas gen sets FrankR Electrical - Systems, Generators, Batteries & Solar 0 04-12-2002 02:37 AM
