Old 12-13-2004, 03:36 PM   #1
1985 34.5' Airstream 345
Marietta , Georgia
Send a message via MSN to 85/345
Fuel Pumps
Just got done replacing my fuel pump and was wondering if the old one could be refurbished. I have a Holley Blue top and I can take the bottom off of it off and see the internal part or is it just better to toss it.
Brian
85/345 is offline   Reply With Quote
Old 12-13-2004, 04:44 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Fuel pumps are so cheap, and cheap to make, you may as well chuck it, it would cost more to rebuild it, if you could get the parts, than a brand-new one.
Old 12-13-2004, 07:21 PM   #3
LOST , Hawaii
Still got the regulator for it? Holley blue pumps put out around 15 psi. The vanes and rotor for a rebuild are less than $20. The regulator is about $45 and you really need it. For a carb engine it is an excellent fuel pump, if you have the regulator I would rebuild and keep it as a spare for the mh.
John
74Argosy24MH is offline   Reply With Quote
Fuel Consumption: (curious) Drew Tow Vehicles 15 12-26-2002 06:28 PM
cat. heater's fuel supply-Inside?? pebblepoint Furnaces, Heaters, Fireplaces & Air Conditioning 4 12-15-2002 04:02 PM
Kohler Fuel shutoff problems rdm Mechanics Corner - Engines, Transmission & More... 5 11-12-2002 07:11 PM
Advice please - Travels, Flags, Fuel and Caravans NickSowter On The Road... 6 06-27-2002 10:04 AM
fuel pressure PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 3 06-09-2002 08:40 PM
