Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 07-17-2004, 08:56 AM   #15
shinola345
Profile:
I had power when I first started to investage the problem. I've not had a chance to look it over today but will this afternoon. There are two connections on the oil sending unit. I assume one of them is for the pump, same color white. does'nt seem to be any power to the unit. I'll check the fuse box also. should be in the glove box.
Have a good weekend. lobsters are soft shell this month .
shinola345 is offline   Reply With Quote
Old 07-27-2004, 04:52 AM   #16
shinola345
Profile:
Talking
AIR IS NOW OUT OF THE LINE. As I stated, I installed a water separator to remove any large chuncks of rust from the tank so as not to be replacing filters each day. It worked very well and the rust problem is to much better. I also ran a line off the separator to feed the GEN. knowing I could run out of gas running it from the same pick up line in the tank .
However As the pumps are working, and pulling fuel I was pulling air from the Gen line into the separator ,point of least reisitance, and on to the electric pump. I have installed a flow check valve in the GEN. line to prevent the back flow . When I pull the tank this fall I will repair and replace all lines in and out of the tank and go back to OEM design.
Still not getting power to the electric fuel pump. Checked the sending unit on the block, hot wired the line and still nothing. I'm running another line from the fues pannel to a swich and will manualy turn it on and off again till the fall.
Thanks again to each of you for your input and help.
Old 07-29-2004, 07:04 AM   #17
George
Profile:
Question air in line
Hello ,
Where did you get your flow check valve?
I have a simular problem with my fuel running back to the tank, causing long crank times on my generator.
George
George is offline   Reply With Quote
Old 09-01-2004, 04:44 PM   #18
redynvre
Profile:  , California
Hello all!
I am having similar problems. I checked for a rear electrical fuel pump, there is none that I found. I will then replace the mechanical one for now. I have never touched a fuel pump before. (I did two cooling systems before on other vehicles) It seems pretty straight forward, but is there anything I should be aware of? Like draining oil first...?
ALL the fuel filters and lines seem new and in perfect shape. However I found the "secret" fuel filter that Steven talked about, the one in the carb, but from what I read there should be one more, where?
Last, what electrical fuel pump would you recomend for the rear?
Thank you all!
AS 345 1985
redynvre is offline   Reply With Quote
Old 09-01-2004, 05:32 PM   #19
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Fuel lines.
As a general PM, all the fuel lines should be replaced every 10 years or so.
Certainly, a fuel line that is almost 20 years old, especially when a large flow is required, is almost gauranteed to have cracks that will leak air, but only on high demand.
Most 345's had the electric fuel pumps. It too should be replaced or overhauled every 10 years or so.
PM is always the name of the game. Push it to the limits and it will reward you with failure.
Also the 345 fuel pickup can only be reached by dropping the tank.
Replace the other gaskets as well when the tank is down.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
Old 09-01-2004, 06:23 PM   #20
74Argosy24MH
Profile:  LOST , Hawaii
The mechanical pump runs off a pushrod that is driven by a lobe on the cam. The only problem will be holding the pushrod up when trying to reinstall. There should be a pipe plug behind the pump, pull this and the push rod will come out. Put a dab of grease on the end of the pushrod (cold engine or the grease will melt) and push it against the cam (long screw driver, small extension), it will hold so you can get the arm beneath it.
John
74Argosy24MH is offline   Reply With Quote
Old 09-02-2004, 02:21 PM   #21
redynvre
Thanks Andy,
I think these lines must have been replaced not too long ago because they look really good and firm. I have to check the paperwork to see when.
Thanks John,
I will follow your direction. From the look of it, it seems that I don't need to remove the tire. I will be ordering the Chassis manual next month but I still want to take care of this before.
What would you recommend for a rear electrical fuel pump? It seems it will requiere a 15lbs pressure capacity from what I understand.
Thank you for the help!
Francois.
AS 345 1985
Old 09-02-2004, 03:21 PM   #22
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
I crawled around under my 280 and looked for a rear fuel filter, did not see one. Anyone else have one on their smaller than a 345 unit? I plan to add one and will do so this winter.
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
Old 09-02-2004, 03:37 PM   #23
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Alan,
I have 2 filters.
One on the frame rail inside the pass side front tire. A second one in the carb. I carry spares of both. I know that peter added a marine style screw on cartridge filter right at the output of his tank. I am considering the same thing. The little frame rail filters seem to clog up really fast on mine
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 09-02-2004, 04:34 PM   #24
ALANSD
I did not follow the line all the way to the front, figured any other than at the carb woudl be in back.
I will look again, thanks.
I have seen a the screw on type at Jeg's. Guess I will invest in one of those.
My Music Site:
Old 09-02-2004, 05:02 PM   #25
74Argosy24MH
15 lbs. is too high, it will hold the needle off the seat and flood the engine. 5 or 6 lbs. will do it. You need volume more than pressure, it is a long way through small lines from the carb to the tank.
John
Old 09-02-2004, 05:12 PM   #26
thenewkid64
Just a member
Images: 21
Mine has an AC1 AC delco sticker on it, just to offer a reference of what to look for. It is less than 6 inches tall.
Brett G
Old 09-05-2004, 05:18 PM   #27
redynvre
Hello all,
I looked again for the fuel filters, and I think there are only two of them:
-1 in the frame behind the battery compartiment
-1 in the carb.
John says volume is more important than pressure, which should be then at around 8lbs, but what is a good volume? It seems some of them go pretty high, 150gpH?
Thank you all for your help!
Enjoy your long Week end!
Francois
AS 345 1985
Old 09-05-2004, 07:53 PM   #28
87MH
87MH's Avatar
Profile:  1978 31' Sovereign
Katy (West Planet Houston) , Texas
Images: 143
....John says volume is more important than pressure, which should be then at around 8lbs, but what is a good volume? It seems some of them go pretty high, 150gpH?
Francois:
8 psi should be OK. If you have a carbureted engine, you just have to push the gasoline to the mechanical fuel pump......most 454's have a regulator built into the mechanical fuel pump which sends the "excess" volume of gasoline back to the fuel tank (this decreases the pressure to the float in the carb). This is not the case in newer fuel injection systems - they do not have a mechanical fuel pump.
150 gph should be fine - I have recorded a low of 4 mpg at cruise - figure 60 mph - this works out to 15 gph - I would not go too much less than 150 gph - at full throttle (taking off from a stop or pulling a steep grade) the 4 bbl carb is going to suck a LOT of go juice.
Dennis
WBCCI # 1113
AirForums #1737
Fuel delivery problems on 1990 LY MH smily Mechanics Corner - Engines, Transmission & More... 17 04-14-2004 06:49 PM
Onan Fuel Pump swebster Mechanics Corner - Engines, Transmission & More... 20 11-06-2003 04:35 PM
Trip report (fuel filter issues) PeterH-79MH Airstream Motorhome Forums 10 08-01-2003 05:57 AM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 10:16 AM
fuel pressure PeterH-79MH Mechanics Corner - Engines, Transmission & More... 3 06-09-2002 08:40 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
