Old 06-14-2005, 07:29 PM   #1
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Fuel Filling Problem
I filled up today at our local Flying J. I like their pumps since the nozzle fits my filler neck. At most truck stops the nozzle is too large for my filler neck opening. I have to stand there and hold the nozzle into the filler in order to get the fuel inside the tank and not the pavement.
I used to drive a deisel VW and had a plastic adapter when i found a nozzle too thick. Also some of you may remember back in the days when they switched over to unleaded and made the filler necks smaller we had adapters to get the larger pump nozzle into our little filler necks. I am really dating myself here.
I am positive they no longer make such an adapter, but can I make one? And if I do, what should I make it out of. I would need the bottom to fit far enough in and the top to extend out enough to hold the pump nozzle.
What do you other deisel guys do?
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 06-15-2005, 06:35 AM   #2
LOST , Hawaii
Aluminum shaped like a narrow funnel, it is soft and easy to work. But, if you are talking about the full size diesel nozzles they pump a lot of fuel, it will probably blow back even more with a more restricted opening unless you hold it at a very low setting. Why not enlarge the opening in the filler to fit the nozzle?
John
74Argosy24MH is offline   Reply With Quote
Old 06-15-2005, 11:02 AM   #3
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Check with your local truck stop, or auto parts store that caters to diesel pickup owners, those adapters are still around.
Old 07-07-2005, 10:12 PM   #4
alfalsetto's Avatar
1982 31' Airstream 310
Longview , Washington
I have not seen one in years. Thay have to be make then some place. I have a diesel an I have not run across this. But sone day I'm going to run across this. If you find one. Post it on line. I want one. Thanks Al
alfalsetto is offline   Reply With Quote
Old 07-07-2005, 10:28 PM   #5
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Chaplain Kent,
When I had a Mercedes Diesel, I used the auto pumps at the truck stops, they have the small auto nozzle. I have noticed that there are RV pumps also which have the small nozzles. You really need a 50 gallon large opening tank for the truck pumps.
Bill
Just my personal opinion
Old 07-07-2005, 10:38 PM   #6
alfalsetto's Avatar
Like I sead some day I'm going run across it so I like to get the adapter.
Old 07-08-2005, 07:13 AM   #7
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
I can use the large nozzle in my Dodge but I have to put the fuel in very slowly, even then sometimes it will shut off. Flying J has the small nozzle for autos at the RV island, this is what I try to use.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 07-15-2005, 12:21 PM   #8
1994 30' Excella
I solved this problem in such a simple manner it is embarrasing that I even posted the question. After taking a good look at the restricter I saw there was just a thin strip of metal holding it out. I bent that back and flattened the restricter. Now the opening is large enough for any size nozzle even the big boys at the truck stops. I never leave it unattended while filling so I do not think I will have a problem with overflowing.
Chaplain Kent
Engine Revving Problem winner Mechanics Corner - Engines, Transmission & More... 19 02-08-2010 10:05 PM
Kohler Fuel shutoff problems rdm Mechanics Corner - Engines, Transmission & More... 5 11-12-2002 07:11 PM
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 12:59 PM
Electrical problem resolved davidz71 Electrical - Systems, Generators, Batteries & Solar 5 08-12-2002 08:21 PM
fuel pressure PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 3 06-09-2002 08:40 PM
