04-15-2010, 11:05 AM
1972 23' Safari
NSB
fuel fill and vent problems
So we've had our Argosy MH long enought to put fuel in it twice, at different stations. It doesn't want to take fuel unless it's at a painfully slow pace or the nozzle clicks off. I'm assuming it's a vent problem and air rushing out the fill neck is doing it. Where do I look for the vent?
thanks
04-15-2010, 11:21 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
I have the same problem with one of my Suburbans. I have found that if I back the pump nozzle out about an inch, it runs fine without clicking off.
Brian
SuEllyn & Brian McCabe
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
04-15-2010, 11:25 AM
1972 23' Safari
NSB
I tried that allong with every possible angle with no luck.
04-15-2010, 12:22 PM
Kmpro
1984 31' Airstream310
Lubbock
Fuel Fill and Vent Problems
My 310 is a Dog to try and fill too. I have to get just the right angle, and then I can fill full bore otherwise it will click off. Its a pain to find the right place.
Mike
A Man has got know his limitations-Dirty Harry
That's Some Bad Hat Harry-Jaws 1978
04-15-2010, 02:07 PM
1972 23' Safari
NSB
Does anyone know where to access the vent?
04-15-2010, 07:27 PM
Silver Bullet
1986 34.5' Airstream 345
choctaw
, Oklahoma
I have to barely put the end of the nozzle in the fill tube and set it at the slowest fill notch on the nozzle. The vent/fill hose is in plan sight on the Silver Bullet. I replaced the fill tube in an RV park after I noticed I was putting gas on the ground on one fill up.
mel
04-15-2010, 08:15 PM
1982 28' Airstream 280
Port Angeles
I'm not sure on the Argosy but on our AS the vent goes into the fill hose fitting just inside the side of the coach. If you lay on the ground looking up you will see the hose. Make sure there are no kinks in the hose.
04-28-2010, 12:04 PM
1972 23' Safari
NSB
So on mine the fill access is towards the front end of the tank, an elbo behind it, a hose running to the back of the tank, and another elbow going into the tank. A previous owner seems to be the problem. The hose is at least 6" too long and has a belly in it that I'm sure is full of gas Now it's a question of whether I can reach it well enough to shorten and reinstall the hose without dropping the tank.
04-28-2010, 07:27 PM
1984 28' Funeral Coach
Belleview
Just a thought but why not try to shorten the vent hose where you can reach it. As it's just a vent / return you could splice with an appropriate insert without trying to reinvent the wheel. Next time you have to drop the tank you can do it right.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
04-28-2010, 08:31 PM
Ajo
Mike
It's a odd deal; some fuel stops, no problem on auto-fill, others I have to hand pump. It is the angle, though.
04-29-2010, 09:37 AM
1972 23' Safari
NSB
I'm sure my problem (well my fuel vent problem) is the belly in the fill hose. It's severe enough to be full of fuel and won't let air pass. All the tank vents are on the other side. Hopefully I can reach it either from underneith or from the top through the cover under the dinette. thanks
05-17-2010, 06:38 AM
1972 23' Safari
NSB
05-17-2010, 03:43 PM
2000 31' Land Yacht
Central
Loved the pictures, they help explain why after a fillup when I spilled fuel around the outside neck, I smelled fuel inside for two days.;-(
05-24-2010, 08:36 PM
Richmond
, Kentucky
Its interesting that so many are having trouble filling their tanks. I guess I'm fortunate that I can stick the nozzle in, set it and walk away if I want to. This is on our 310, I've never put gas in the Argosy yet so I don't have any idea whats going to happen there.
1975 24' Argosy Motor Home
