Old 04-15-2010, 11:05 AM   #1
projector's Avatar
1972 23' Safari
NSB , Florida
fuel fill and vent problems
So we've had our Argosy MH long enought to put fuel in it twice, at different stations. It doesn't want to take fuel unless it's at a painfully slow pace or the nozzle clicks off. I'm assuming it's a vent problem and air rushing out the fill neck is doing it. Where do I look for the vent?
thanks
projector is offline   Reply With Quote
Old 04-15-2010, 11:21 AM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I have the same problem with one of my Suburbans. I have found that if I back the pump nozzle out about an inch, it runs fine without clicking off.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 04-15-2010, 11:25 AM   #3
projector's Avatar
1972 23' Safari
NSB , Florida
I tried that allong with every possible angle with no luck.
Old 04-15-2010, 12:22 PM   #4
Kmpro
kmpro's Avatar
1984 31' Airstream310
Lubbock , Texas
Thumbs down Fuel Fill and Vent Problems
My 310 is a Dog to try and fill too. I have to get just the right angle, and then I can fill full bore otherwise it will click off. Its a pain to find the right place.
Mike
A Man has got know his limitations-Dirty Harry
That's Some Bad Hat Harry-Jaws 1978
kmpro is offline   Reply With Quote
Old 04-15-2010, 02:07 PM   #5
projector's Avatar
1972 23' Safari
NSB , Florida
Does anyone know where to access the vent?
Old 04-15-2010, 07:27 PM   #6
Silver Bullet
choctawmel's Avatar
1986 34.5' Airstream 345
choctaw , Oklahoma
I have to barely put the end of the nozzle in the fill tube and set it at the slowest fill notch on the nozzle. The vent/fill hose is in plan sight on the Silver Bullet. I replaced the fill tube in an RV park after I noticed I was putting gas on the ground on one fill up.
mel
choctawmel is offline   Reply With Quote
Old 04-15-2010, 08:15 PM   #7
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I'm not sure on the Argosy but on our AS the vent goes into the fill hose fitting just inside the side of the coach. If you lay on the ground looking up you will see the hose. Make sure there are no kinks in the hose.
Old 04-28-2010, 12:04 PM   #8
projector's Avatar
1972 23' Safari
NSB , Florida
So on mine the fill access is towards the front end of the tank, an elbo behind it, a hose running to the back of the tank, and another elbow going into the tank. A previous owner seems to be the problem. The hose is at least 6" too long and has a belly in it that I'm sure is full of gas Now it's a question of whether I can reach it well enough to shorten and reinstall the hose without dropping the tank.
Old 04-28-2010, 07:27 PM   #9
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
Just a thought but why not try to shorten the vent hose where you can reach it. As it's just a vent / return you could splice with an appropriate insert without trying to reinvent the wheel. Next time you have to drop the tank you can do it right.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 04-28-2010, 08:31 PM   #10
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Mike
It's a odd deal; some fuel stops, no problem on auto-fill, others I have to hand pump. It is the angle, though.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 04-29-2010, 09:37 AM   #11
projector's Avatar
1972 23' Safari
NSB , Florida
I'm sure my problem (well my fuel vent problem) is the belly in the fill hose. It's severe enough to be full of fuel and won't let air pass. All the tank vents are on the other side. Hopefully I can reach it either from underneith or from the top through the cover under the dinette. thanks
Old 05-17-2010, 06:38 AM   #12
projector's Avatar
1972 23' Safari
NSB , Florida
I finished the install over the weekend. Here are the before pictures. The sag in the hose wasn't as severe as shown because the hanging straps are loose. One was broken when I started, creating the sag. The hose is a marine exhaust/water hose and was clamped on to a pipe thread end on the tank end and stuffed into the fill neck at the other end. The copper tubing is a home-made fuel pick up tube for the generator.
Name:	fuel fill before 1.JPG
ID:	102702Click image for larger version
Name:	fuel fill before 3.JPG
Name:	fuel fill before 4.JPG
ID:	102705Click image for larger version
Name:	fuel fill before parts.JPG
Here are the after pictures. The inlet on the tank and the fill neck are 2 1/4" diameter. From NAPA I got 3 2 1/4" fuel fill hose elbows, 1-45 deg and 2-90 deg, and a piece of exhaust tubing. I elongated the hole in the floor to clear the curve of the elbow to keep it as high as possible. I wanted it to run more down hill but the tank end wouldn't allow it.
Name:	fuel fill after1.JPG
ID:	102712Click image for larger version
Name:	fuel fill after 2.JPG
Name:	fuel fill after 3.JPG
ID:	102714Click image for larger version
Name:	fuel fill after 4.JPG
Last will be installing the sending unit I'm having rebuilt and reattaching the generator fuel line...then off the gas station to see the difference.
Old 05-17-2010, 03:43 PM   #13
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Loved the pictures, they help explain why after a fillup when I spilled fuel around the outside neck, I smelled fuel inside for two days.;-(
Old 05-24-2010, 08:36 PM   #14
Its interesting that so many are having trouble filling their tanks. I guess I'm fortunate that I can stick the nozzle in, set it and walk away if I want to. This is on our 310, I've never put gas in the Argosy yet so I don't have any idea whats going to happen there.
Moho Fuel problems doorgunner Mechanics Corner - Engines, Transmission & More... 20 09-15-2008 11:08 AM
Everybody go fill up. rebel beck Our Community 20 07-06-2006 08:24 PM
Fuel delivery problems on 1990 LY MH smily Mechanics Corner - Engines, Transmission & More... 17 04-14-2004 06:49 PM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 10:16 AM
Kohler Fuel shutoff problems rdm Mechanics Corner - Engines, Transmission & More... 5 11-12-2002 07:11 PM
