I have seen this topic discussed and I am sure some of you have replaced these. maybe with grease-able Units ?
I also just remember reading One of your Posts that Airstream added a heavy duty front sway bar to the P-30 chassis when putting together these units at the Factory. ?
Is that correct.
Thank You for your Help.
Or maybe there is a newer, heavy, Better unit to install. ?
The PO of my 310 installed a Roadmaster sway bar which has urethane bushings. It is definitely more solid on the road than any other P30-chassis MH I have driven.
Wayne Wells to RMI, me
show details May 12 (11 days ago)
John,
I would want to get our part number 1109-116 which is 1 5/8” front bar and rear bushing kit the rear bar is large enough to handle the weight of that unit but you bushing are most likely needing to be replaced.
The install for those part are very easy installs with complete instructions, so you would have no problems with the install of them. I would recommend you go to Supersteer to also get a rear Tracbar.
You can reach them at 888 898-3281 x313 John, you can also get the 1109-116 from them they are one of our better dealers. Let me know if you have any other questions.
