Old 01-16-2004, 02:07 PM   #1
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Front Right Jack Won't Come Down
I was going through my weekly running of the 345 (I try and run her up the highway once a week to keep things in operation through the cold months by taking most of my office to lunch in it on day a week) and thought..."boy I haven't cycled the jacks in a while" so I tried them.
Three out of four came down but not quite 90 degrees to the frame and the front pass side didn't come down at all. These all used to work this summer.
My [no experience with hydraulics] mind thought...looks like its low on fluid. But I don't even know where the resevoir is located.
Any suggestions on where to start?
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 01-16-2004, 03:02 PM   #2
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
I would try cussing and screaming. Might not get the jack to work but might save you from picking up the lunch tab.
Rog
Rog0525 is offline   Reply With Quote
Old 01-16-2004, 03:19 PM   #3
Rog0525's Avatar
Images: 11
ok, I apologize
But I do have a hair brained idea. Try a generous application of WD-40 on everything that moves or has friction.
My daughter recently had a prob with her HP printer and even the local computer repairman couldn't fix it. I sprayed a little WD-40 on both ends of the carriage and now it works fine.
I'm not being stupid on purpose, Your jacks are probably victims of extended non-use . Alternatively, you might take the RV to a local muffler shop and have them lube everything.
Rog
Old 01-16-2004, 03:48 PM   #4
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
I believe the fluid reservoir is in a next to impossible place to get to. Pop up the dog house and look towards the rear. There should be a horizontal tube/can/tank with a cap on the top.
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 01-16-2004, 04:09 PM   #5
87MH's Avatar
1978 31' Sovereign
Images: 292
"Impossible to get to"
It appears as if Fred's been there and done that.
I found it easier to attack it from underneath. The cap isn't TOO hard to get off, but I have no idea of how you could visually check the fluid.
I just stuck my finger in (middle digit dipstick) after removing the cap, as long as there is fluid a couple of inches from the top, you should be OK.
To add fluid, you might try a good flexible hose and funnel.
I have a .doc file on recommended fluid somewhere, I'll see if I can find it.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 01-17-2004, 05:02 AM   #6
87MH's Avatar
1978 31' Sovereign
Images: 292
Info - couldn't find the .doc
http://www.airforums.com/forum...&threadid=3723
Steven,
The fluid in hydraulic system of the Xeppelin is red, and gives every indication of being transmission fluid.
Should I ever have to top the fluid level off, it will be with transmission fluid.
Dennis
WBCCI # 1113
AirForums #1737
Old 01-17-2004, 05:13 AM   #7
LOST , Hawaii
To fill it try something like this. It is also good for rear axles and all those other hard to get locations. You should be able to find a similar one at a parts store too.
John
74Argosy24MH is offline   Reply With Quote
Old 01-17-2004, 07:03 AM   #8
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
i had the same problem. the drivers side. i tapped the jack housing with a brass hammer. havent had any more problems. that jack will take your breath away when you ask for a price.
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 WB , Pro Pride P-3 hitch
centramatics wheel ballancers 300-556
wb13798 is offline   Reply With Quote
Old 01-17-2004, 08:03 AM   #9
RivetAddict
swebster's Avatar
thanks!
Thanks all! I went looking through my pile of documents again last night and sure enough I have the installation manual for the A&E jacks. (should have checked before posting)
Here is a listing of recommended fluids from the installation manual:
SAE 5W Non-detergent Motor Oil
SAE 10W Non-detergent Motor Oil
SAE 5W Light Hydraulic Oil
Type A Transmission Fluid
Type B Transmission Fluid
WARNING: Never use Brake Fluid, Hydraulic Jack Fluid or Type F Transmissions Fluid.
The procedure for checking the fluild level is:
All Jacks in the retracted position
Remove breather plug in the pump/resevoir assembly
Fluild level should be 1" from the top of the resevoir
There is also an adjustmentsand troubleshooting section that's decent. Its only 12 pages so if someone needs a copy let me know.
Steven Webster
AIR 1760
